Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7L Performance Parts Discussion
6.7L Performance Parts Discussion Discussion of Performance Parts For the 6.7L Trucks Glacier Diesel
Old 11-06-2009, 09:45 AM   #1 (permalink)
Let's discuss Smarty revo settings....Torque Management
I guess since most of us know what the timing and vgt settings do for making power I want to discuss what the torque management settings actually manipulate on these trucks. I understand that the higher the setting the faster it builds torque....that's a given. I want to know whats being changed that makes the truck build the torque faster. I am pretty sure that each torque management setting is adding more fuel to the equation but it has to be doing more than that...I notice the higher torque setting I use the higher my cruising egts are....Or is it just extra fueling and I am thinking to hard about it.
2007 Mega Cab 3500 dually 4x4, 6spd, 3.73, afe mega cannon, 5in tbe, egr delete, egr cooler delete, isspro ev2 gauges, Smarty ME
atlas59 is offline   Reply With Quote
Old 11-06-2009, 11:50 AM   #2 (permalink)
it all about the converter, put two fans in front off one another, turn on the rear one, the faster it spins the more it pushes the front, now slide them closer together, this is torgue managment, for the simple mind, you can only adjust about 40 percent of the total from the ecm, that is where the tcm comes in .. torgue managment just adjust the vane angle inside the converter to make it drive the output shaft sooner.
08 6.7l 4x4 qc sb auto....
warlock06 is offline   Reply With Quote
Old 11-06-2009, 12:02 PM   #3 (permalink)
i could be wrong but i dont thnk smarty effects the tranny....besides this would only be applicable to the autos and not the manuals
Old 11-06-2009, 12:19 PM   #4 (permalink)
It would be nice if the vanes in the TC were adjustable but that is not the case right now.
AFAIK torque management is just looking at the output from the tranny and keeping the fuel within certain limits. That is designed to save the tranny. In Smarty the higher the TM number the more it ignores the limits.
2008 Dodge 3500 SRW QC LB 4x4, Auto, 3.73, 6.7L. Lorenz springs. Thuren TB, HID's. All deletes. Smarty. 4040XL. Banks SuperScoop. RockCrusher diff guards. Defiant steering support & stone shield. Goerend TC. WCC intake & boost tube. No grid heater. King 2.5" shocks, Carli CA, Yokohama 37", Flex-a-lite fan, Carli Sway bar, Sulastic shackles, MHP trans tune
milo12 is offline   Reply With Quote
Old 11-06-2009, 01:57 PM   #5 (permalink)
rjp
rjp's Avatar
Are you trying to make a funny?
07.5 Mega Cab 6.7 4x4,68rfe,Air Dog 150,Dragon Fire cp3 Hamilton Cam,#110 Springs,Chromemoly Push Rods,Port & polished head, Firringed,custom DDP 120 Sticks,ARP 625's,Phat Shaft 66/71 External Wastgate,Sperco Intercooler,5" Exhaust,Suncoast TEST Transmission,W/Custom T.C.M, Mp8, Quad Boost Fooler, All Deletes and Gauges.WCC Intake Secret Tuner
Big thanks to Ron@Suncoast & Eric@BrownsDiesel http://s772.photobucket.com/albums/yy10/ronniepene/ ?action=view&current=dodge67015.flv
rjp is online now   Reply With Quote
Old 11-06-2009, 02:01 PM   #6 (permalink)
The new 4BT Cummins Prius
mattpopp's Avatar
That would be like having a Hydrostatic Transmission.
07 l 6.7 l .75 ton l MC l with stuff on it and a new head gasket
96 l 5.9 l .75 ton l EC l with not much on it
Be VERY skeptical of information you read on the internet.
mattpopp is online now   Reply With Quote
Old 11-06-2009, 02:01 PM   #7 (permalink)
bthanks's Avatar
So what about the non auto trannys?
2008 qcsb, southbend DD,airdog II,smarty,arson jr,afe mega cannon, SB66, boost tube, 5" tbe, BDS longarm 6" lift, helo maxx 8's w/35X13.50's
http://www.youtube.com/watch?v=tAkfRYekA-0- 6.7 Smoke switch
http://www.youtube.com/watch?v=a-6pZYH9pGY- Burn out!!!
www.rollinsmokediesel.com <--- Look For Black Ops Diesel!!
bthanks is offline   Reply With Quote
Old 11-06-2009, 04:54 PM   #8 (permalink)
BOD
rbmedic75's Avatar
probably should have sat on that explanation for a bit bud. Ok back on topic can we get an answer to the question I like undersatnding as much of the whys and hows my truck does stuff to. Where is MARCO have not seen him in a while. MARCO??????? No polo needed
here is my limited understanding of TM. TM will defuel the engine when certain boost, RPM, and speed parameters are not met. If the boost/RPM/speed are under certain levels the motor will not fuel to 100% until the proper conditions are reached. Adjusting TM will decrease the amount of Defueling done thus bringing the power on at even lower rpm and air flow levels
08 quad SB 6 stick time to:SMARTY 14ME, BOD Intake. BOD EWG. BOD @ http://www.rollinsmokediesel.com/
Parts on the shelf waiting--- Isspro EV2, 6" twin Aussie's, Banks Intercooler, Toyo OC MT 37 13.50 R 17,
rbmedic75 is online now   Reply With Quote
Old 11-06-2009, 04:55 PM   #9 (permalink)
08 Cummins
KhakiCummins's Avatar
My understanding of Torque Management is that it is the rate at which the ECM adds fuel up to whatever the demanded level is.
Here is a quick graph showing my understanding. The numbers are completely arbitrary. They are just there to represent my understanding.
2008 Ram 3500 SLT QuadCab LB SRW 4x4 6.7L G56 Light Khaki
DiPricol Optix(Pyro/Boost/Diff Temp), S67, SB 3250 DD, S&B CAI, Line-X, B&W Turnover Ball, ProTech, PacBrake Air Springs, HBS 2" leveling kit, MagHytec Rear, Willmore Wheel-to-Wheels, Condensor Guard, Jacobs EB switch
KhakiCummins is offline   Reply With Quote
Old 11-06-2009, 05:01 PM   #10 (permalink)
ken white's Avatar
I thought all it did was to change the sensitivity of the fly-by-wire signal associated with the skinny pedal...
__________________________________________________ ______________________________
2008 Quad Cab 3500, 4x4, Long Bed, DRW, G56, 3.73's, Line-X, P3, lots of camper upgrades...
ken white is offline   Reply With Quote
Old 11-06-2009, 05:05 PM   #11 (permalink)
lesbian at heart
elephantrider's Avatar
thats what i thought. example on a stock sw
setting, skinny pedal is at 50% you are getitng
50% fueling, but when tqm is increased you now
have 50% throttle, and maybe 75% fueling
i know when you turn tqm up, you can really tell
that the throttle gets touchy.
jason
04.5 6sp qclb whiskey tango foxtrot, over
elephantrider is offline   Reply With Quote
Old 11-06-2009, 05:19 PM   #12 (permalink)
MattTN23's Avatar
I don't think so, because on TM-2 you can be easing into the throttle and when it hits a certain RPM you can really feel the power kick in. It is like fuel was just automatically added all at once.
2007.5 Dodge Ram 3500 4x4 QC Dually Lonestar Edition, Silver with Bucket Seats/ AFE Stage 2 Pro Dry S Air Intake/ Edge Juice w/ Attitude+HOT-UNLOCK/ BADP 4" Downpipe and DPF delete w/ MBRP muffler delete pipe/ EGR delete CODE FREE Thanks to The SMARTY S67ME
MattTN23 is offline   Reply With Quote
