Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7L Performance Parts Discussion
6.7L Performance Parts Discussion Discussion of Performance Parts For the 6.7L Trucks Glacier Diesel
Old 11-07-2009, 12:54 PM   #25 (permalink)
BOD
rbmedic75's Avatar
notice when you take off from a dead stop the power band starts to come in at around 1200 rpms and progressively gets stronger up to a point that point that it peaks which is where the ECM TM is set to reach 100% fueling. because as the rpms and speed climb even if we are at WOT the ecm only allows a small percentage of the fueling we are asking for and then progressively more and more fuel until it gets to the 100% with the smarty settings (higher it shortens the time frame that the ECM takes to get form 20% fueling to 100% so it is mucher quicker to reach the max fueling. I dont know how much TM level 4 leaves in the ECM but if it were to turn it off completely it would be totally in out control WOT is immediate 100% fueling and would roal coal until she got wound up. also part of the reason the "SMOKE SWITCHES" work it is telling the trucks MAP sensor that we are getting more air than we really are and allows for more fuel thus the smoke at lugging conditions until the rpms and airflow actually come up to match the fuel flow the switch told the truck it needed
08 quad SB 6 stick time to:SMARTY 14ME, BOD Intake and EWG. BOD @ http://www.rollinsmokediesel.com/
Parts on the shelf waiting--- Isspro EV2, 6" twin Aussie's, Banks Intercooler, Toyo OC MT 37 13.50 R 17, BOD 90 HP injector Nozzles
rbmedic75 is online now   Reply With Quote
Old 11-07-2009, 01:20 PM   #26 (permalink)
Originally Posted by rbmedic75 View Post
Higher TM will sve your tranny but only because it reuires thigs to be moving more and puts less stress on it after its moving than applying it all at once. Try power Braking your truck with the TM set at stock then turn yor smarty up to 4 and see the difference. Its not because its more power its because the truck ECM wont allow high percentage fuel ratios until the truck is rollin with the TM on. Think of TM as releasing the beast its always there just harnessed on a short leash until you dial up 2 ,3 ,4 on your smarty. TM also automatically defuels the truck on autos in between shifts
So a higher number (1 being low, 4 being higher) for tqm will help the trans. I'm just trying to get a grasp on how this works.
'08 2500 mega, laramie, 5" TBE, Smarty, S&B CAI, Stage III W/M injection, ISSPRO EV2's, egr delete, 2" hbs leveling kit, Thanks to RSD and a little
dirtmovr is online now   Reply With Quote
Old 11-07-2009, 01:20 PM   #27 (permalink)
ken white's Avatar
If the sensitivity (gain) is reduced, and time constant increased slightly, of the fly-by-wire signal, then it will take a much greater pedal stroke to reach 100% throttle in a slightly greater period of time.
If the sensitivity (gain) is increased, and time constant decreased slightly, of the fly-by-wire signal, then it will take a much shorter pedal stroke for the same 100% throttle in a slightly shorter period of time.
I am almost 100% sure the system gain is linear, or nearly linear in nature, or it would be very difficult to control the vehicle while in traffic - surging and bucking...
There may be other variables associated with TM that the driver can't control, but ultimately torque control must be a driver function for reliable vehicle operation.
__________________________________________________ ______________________________
2008 Quad Cab 3500, 4x4, Long Bed, DRW, G56, 3.73's, Line-X, P3, lots of camper upgrades...
ken white is offline   Reply With Quote
Old 11-07-2009, 01:24 PM   #28 (permalink)
BOD
rbmedic75's Avatar
No bud it actually with the smarty works backwards 1 is allowing the most TM management safest for tranny 2 is a litle less managment, 3 is even less then 4 is little to no managment (not sure how much Marco unleashed the beast)
Old 11-07-2009, 01:33 PM   #29 (permalink)
Thats what i thought, but I got a little confused. Kinda seems as though there isn't a pattern to the settings on the smarty. eg. 4 is not always greater than 1. Thanks for clearing that up.
Old 11-07-2009, 03:15 PM   #30 (permalink)
The new 4BT Cummins Prius
mattpopp's Avatar
Yes it is. ON the Smarty its all the same.
0 is default
1 is Stock
2 is a little more aggressive then stock (same as Default)
3 is more aggressive
4 is the most aggressive
Its the same on Timing, Torque Management, Rail Pressure, and the Turbo.
So if your TM is on 4 its going to be the most aggressive fueling at low throttle response. Very simple concept.
07 l 6.7 l .75 ton l MC l with stuff on it and a new head gasket
96 l 5.9 l .75 ton l EC l with not much on it
Be VERY skeptical of information you read on the internet.
mattpopp is offline   Reply With Quote
Old 11-07-2009, 04:19 PM   #31 (permalink)
BOD
rbmedic75's Avatar
Mattpop is right its alway1 mild 4 wild with smarty its just the way we think about the TM that makes it confusing some times. We think of the higher the number the more its adding when with the TM the stock settings are the highest "MANAGMENT" of torque so they restrict it the most, as we dial up the TM numbers 1-2-3-4 we are removing the higher restriction by lessening the "management of or torque" ie releasing the beast that has always been there just held at bay with the factory management restrictions
Bottom line is MARCO is a genius and has allowed us to choose the way we want or trucks to respond to our driving habits
Old 11-07-2009, 06:21 PM   #32 (permalink)
Nope I believe he may be slightly wrong....Not that it matters in this discussion, but didnt Marco say that on the vgt settings that 2 is more than 3? I believe this is because vgt 3 was designed for towing because it will not build as much boost as 2 or 4....at least on my truck with ME14
2007 Mega Cab 3500 dually 4x4, 6spd, 3.73, afe mega cannon, 5in tbe, egr delete, egr cooler delete, isspro ev2 gauges, Smarty ME
atlas59 is offline   Reply With Quote
Old 11-07-2009, 06:33 PM   #33 (permalink)
BOD
rbmedic75's Avatar
correct for the VGT 2 and 3 are a little different 3 being for towing and 2 being a little more responsive for playing. Not sure why it was set up that way but it is forgot about htat one good catch man
Old 11-07-2009, 07:20 PM   #34 (permalink)
JWChadwick's Avatar
i am with the crowd that believes tm is managing torque sent to the rest of the drivetrain.
#1 being stock, may only allow 500ft lbs
#2 a bit stronger may allow 650
#3 maybe 800,
#4 unlimited.
I am just guessing as well, but from what I can wrap my feeble mind around, it is set up in that manner. Obviously I just threw some numbers out, which are of course inaccurate, but that is how I think it is. This would explain how it affects manual and auto trannys in the same way. Once again, this is the shoulders down trying to get in on a shoulders up conversation.
2008 3/4 QCSB 6.7 AUTO 4X4 TS MP-8; K&N; BFG T/A 37X12.5-17; AMSOIL; SMARTY 5" RSD straight
JWChadwick is offline   Reply With Quote
Old 11-07-2009, 07:38 PM   #35 (permalink)
Camotanker's Avatar
Originally Posted by milo12 View Post
It would be nice if the vanes in the TC were adjustable but that is not the case right now.
AFAIK torque management is just looking at the output from the tranny and keeping the fuel within certain limits. That is designed to save the tranny. In Smarty the higher the TM number the more it ignores the limits.
Ding!
don't even get me started with the 2003 ECM/PCM combo.
Monster Rig - (Website Click Here)
2003 CTD - REBORN
Camotanker is offline   Reply With Quote
Old 11-07-2009, 08:24 PM   #36 (permalink)
mikeshauling's Avatar
Are these VGT settings the same for the S and the ME ? If so , then should i set mine to 3 since i tow alot and heavy, i currently run sw#3 and all default. If i use the at VGT3 , can i leave the rest default or should i adjust the others to help this ? SORRY TO HIJACK
09 QC 4X2 BIGHORN DRW G56 3:73 INFERNO RED Timberens B&W GN Dipricol Optix ga.(boost,fuel pr. EGT) , CAT 2 mic remote F/F Smarty17S, stock exhaust in tact.
mikeshauling is offline   Reply With Quote
