Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7L Performance Parts Discussion
6.7L Performance Parts Discussion Discussion of Performance Parts For the 6.7L Trucks Glacier Diesel
Old 11-06-2009, 05:27 PM   #13 (permalink)
BOD
rbmedic75's Avatar
right because the "less" aggressive the TM the more it will allow the near 100% of fueling that the pedal is calling for. example if you major restrict TM like a -2 if you will, you would be at full pedal and high RPM's before you would reach 100% fueling but when you decrease the restrciton on the TM the quicker you hit that 100% fueling ratio. DOes that make sense. As we increase the TM on the smarty 1 then 2 then 3 then 4 the less MANAGEMENT is done thus lower rpms the sooner the power comes in. So basically when ya tap the little skinny pedal it is balls to the walls 100% fueling right now or there close. Whihch is why the TM is harder on trannies than say 1 or 2 at higer RPMS the trannies are already moving and not as much immediate force applied against them. Like a locomotive hell to get started but once its going easier and less stress on the drivetrain to maintain it.
Edited for
Speed is also a programmed consideration with more TM the truck does not fuel as hard at lower speeds
08 quad SB 6 stick time to:SMARTY 14ME, BOD Intake and EWG. BOD @ http://www.rollinsmokediesel.com/
Parts on the shelf waiting--- Isspro EV2, 6" twin Aussie's, Banks Intercooler, Toyo OC MT 37 13.50 R 17, BOD 90 HP injector Nozzles
rbmedic75 is offline   Reply With Quote
Old 11-06-2009, 05:42 PM   #14 (permalink)
Originally Posted by ken white View Post
I thought all it did was to change the sensitivity of the fly-by-wire signal associated with the skinny pedal...
this wouldnt explain the higher egts as you raise the torque management level....but the quicker fueling would since the truck is not taking rpm and boost into as much consideration when adding fuel hence the quicker throttle response, but i still believe there is more to it than fueling
2007 Mega Cab 3500 dually 4x4, 6spd, 3.73, afe mega cannon, 5in tbe, egr delete, egr cooler delete, isspro ev2 gauges, Smarty ME
atlas59 is offline   Reply With Quote
Old 11-06-2009, 07:51 PM   #15 (permalink)
BOD
rbmedic75's Avatar
Correct here is a highlight out of the below article
As with current petrol engine management systems, the driver no longer has direct control over the injected fuel quantity. Instead, the movement of the accelerator pedal is treated as a torque request and the actual amount of fuel injected in response is dependent on the engine operating status, engine temperature, the likely affect on exhaust emissions, and the intervention by other car systems (eg traction control).
here are a couple decent articles with some explanations of things
Browser Warning
Browser Warning
Not sure why these show up as browser warnings but they are autospeed articles
Old 11-06-2009, 08:04 PM   #16 (permalink)
This was my understanding and experience with my previous '06 with a SmartyCR, as full throttle runs felt identical regardless of the TM level. But then again that truck has a manual transmission, so maybe that plays a factor.
Does anybody have a dyno graph that actually shows any difference between the TM levels, as I haven't seen one?
'09 3500 MegaCab Laramie 4x4
MegaBOMB is offline   Reply With Quote
Old 11-06-2009, 08:14 PM   #17 (permalink)
lesbian at heart
elephantrider's Avatar
here is my dyno with tqm on 2. getting the
one with tqm on 3.
jason
04.5 6sp qclb whiskey tango foxtrot, over
elephantrider is offline   Reply With Quote
Old 11-06-2009, 08:44 PM   #18 (permalink)
What are your mods?
2008 Dodge 3500 SRW QC LB 4x4, Auto, 3.73, 6.7L. Lorenz springs. Thuren TB, HID's. All deletes. Smarty. 4040XL. Banks SuperScoop. RockCrusher diff guards. Defiant steering support & stone shield. Goerend TC. WCC intake & boost tube. No grid heater. King 2.5" shocks, Carli CA, Yokohama 37", Flex-a-lite fan, Carli Sway bar, Sulastic shackles, MHP trans tune
milo12 is offline   Reply With Quote
Old 11-06-2009, 08:49 PM   #19 (permalink)
lesbian at heart
mods ? we dont need no stinkin mods...
jason
Old 11-07-2009, 04:27 AM   #20 (permalink)
Diesel freak!!
cockdiesel's Avatar
I thought of the torque management setting as a filter. The lower the setting the less torque would go through the tranny to the rear wheels. I'm probably wrong on this but I thought this was what the user applied to save their tranny or clutch. Just my understanding but could be wrong.
2008 2500 SLT Sport 4x4,Black, 6.7L, 68RFE, 3.73 Lsd, heated leather buckets, AFE stage 2 pro dry, Bully Dog Watchdog, SMARTY R15s, Isspro boost, Stock Exhaust and EGR Intact for now....
cockdiesel is offline   Reply With Quote
Old 11-07-2009, 09:35 AM   #21 (permalink)
AUTOBOX TRANSFORM!!!
SkinInc69's Avatar
You tell'em Jason!
2007.5, 6.7L 2500 4x4 LARAMIE 68RFE- H&S Performance Hot Damn 175 ATT, Industrial Injection Stage 2 CP3, FASS 150/150, H&S 5" TBE straight piped, Snow Performance water methanol injection, Capped fuel rail, EGR & Cooler delete, AFE Mega Cannon, Black Op's Diesel intake horn, 3.5" Shibby boost tube, DiPricol Gauges, 3" BDS lift, Bushwacker flares, 20x12 iON-Forged Terminators, 33x12.5 Nitto Mud Grapplers, RDX Billet Grill, Line X, 20% Tint w/ 9" brow, 10,000K HID Hi/Low, Fogs. www.hsperformance.com
Old 11-07-2009, 12:33 PM   #22 (permalink)
BOD
rbmedic75's Avatar
Higher TM will sve your tranny but only because it reuires thigs to be moving more and puts less stress on it after its moving than applying it all at once. Try power Braking your truck with the TM set at stock then turn yor smarty up to 4 and see the difference. Its not because its more power its because the truck ECM wont allow high percentage fuel ratios until the truck is rollin with the TM on. Think of TM as releasing the beast its always there just harnessed on a short leash until you dial up 2 ,3 ,4 on your smarty. TM also automatically defuels the truck on autos in between shifts
Old 11-07-2009, 12:39 PM   #23 (permalink)
lesbian at heart
medic - but there is no torque management from the factory
on the standards, correct ? so how does tqm work on
the manny trannys.
jason
Old 11-07-2009, 12:48 PM   #24 (permalink)
BOD
rbmedic75's Avatar
there still is the same TM on the factory sticks which is what i drive, its just less noticeable because we control the shift points at the RPMs we want. which is why on a stock clutch you can smoke it fast on Level 4 it still allows the truck to fuel closer to the 100% thus bringing the power band in sooner. Imagine what would happen if there was no TM on are trucks as soon as you floor the pedal it would be 100% fuel at once you would break stuff and couldnt keep tires on her.
