Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7L Performance Parts Discussion
6.7L Performance Parts Discussion Discussion of Performance Parts For the 6.7L Trucks Glacier Diesel
Old 11-02-2009, 06:33 PM   #1 (permalink)
Moved front axle forward 3.5", forced to order Smarty and Pipe!
Dammit I was forced to order a Smarty and Pipe for my '09 Dually!!!
How it happened... I was installing a 3.5 inch lift in the front, and wanted the front axle moved forward as everyone knows the larger tires rub by the firewall. And as u lift the truck, the arms swing down and back...
Since I have a machine shop, I decided to run a 3.5" longer arm on top and a 3" longer lower... Well, I got the left side done, and realized that to get the right side upper arm out, ya have to remove the downpipe!!!
Crap! So all the exhaust came off, and while it was removed, it made sense to add the Smarty and pipe/egr.
I wanted to do it anyway, but not today!!!
So it's all ordered!!! Can't wait...
Damn, I hate it when I HAVE to buy upgrades for my truck!
I've also added the fender flairs off a 5500... and I'm going to run std offset front rims rather than the dually rims so the front tire will move out to fill the flares...
I'll post some pics when she's all done.
www.jd3.com Just build it!
238mph is offline   Reply With Quote
Old 11-02-2009, 06:50 PM   #2 (permalink)
agalaczy's Avatar
Did I understand correctly,you made your control arms longer by 3.5 inches to compensate for your 3.5 inch lift?
Reason i'm asking is that for a 2.5 inch lift the control arms are aproximately 1/2 - 5/8 inch longer than stock.I may be wrong.
2007 5.9 CTD QUAD SPORT,A/T,4.10 GEARS AFE STAGE 1,MBRP COOL DUALS,2 INCH SPACERS,TRACTION BARS,ISSPRO GUAGES,KATZKIN CUSTOM LEATHER,BUSHWACKER POCKET FLARES.YOKOHAMA GEOLANDAR AT/S 315-70-17.
agalaczy is offline   Reply With Quote
Old 11-02-2009, 06:56 PM   #3 (permalink)
cmns2500's Avatar
i hope them arms are super strong....they get lots of forces put on em....
CJ's truck....got a problem w/ your VP powered truck?? click===>>this link
02 5 speed/stock ish... w/ a Scan Gauge II monitorin stuff... TCW3 Two Stroke lubin er up...
Old 11-02-2009, 08:04 PM   #4 (permalink)
Agalczy:
You read my post correctly...
The upper arm is 17" and the lower is 19"
They make a different arc as they travel up and down.
The more u raise the truck, the faster the upper arc
pulls back towards the cab. So if u lift a truck, the upper
needs to be lengthened more than the lower.
Autocad/Solidworks is easy to map it in...
So the STOCK setup by Dodge sucks... the qrtr panel is too close to the door, and that's why no one makes a cutout fender flare for the Dodge. On top of that, the suspension is setup where the pivot point on a dually is pretty far inboard. So as you turn the tire hard one way or the other, the tire swings back into the cab area.
An easy fix for this is to move the front bumper out 2.5 inches... and then re-center the front axle in the new and wider wheel-well.
So I lengthen the upper 3.5" and the lower 3.25".
Since the arms are so cheesy to begin with, I use 2"x3/16 plate and add two fishplates on the INSIDE of the arms, and button weld through the two holes already in the arms, and then I box the entire outside of the arm with 3/16" plate.
Even if I wasn't going to extend the arms, I would have taken them off and boxed them in with heavier steel.
It's scary how thin the metal is that holds that front axle.
I will post pics when this one is finished.
As for my fab skills, I'm a mechanical engineer, and have a well equipped shop. Check out my website, Custom fabrication of Lifted Trucks and Jeeps. Just a hobby, but I build all kinds of vehicles, race cars, rockcrawlers, modified Jeeps, semi trucks etc.
I love all the stuff posted on here... can't wait to get my Smarty in...!
Old 11-02-2009, 08:12 PM   #5 (permalink)
Big Silver's Avatar
238mph After checking that web site out, you just keep doin what you're doin cause I do believe you have it all figured out as far as lifted trucks go.
2007 SLT Quad cab 3500, DRW, 6.7L, AZ flash, H&S XRT 60HP, S&B intake, 4" Flo Pro into 5" Silverline exhaust, Edge Insight, EGR and cooler gone. (Shibby boost tube waiting for install) http://www.hsperformance.com/ http://www.rollinsmokediesel.com/
Big Silver is offline   Reply With Quote
Old 11-02-2009, 08:13 PM   #6 (permalink)
ken white's Avatar
Post pictures for sure...
Your solution to a very mild lift is interesting to say the least...
__________________________________________________ ______________________________
2008 Quad Cab 3500, 4x4, Long Bed, DRW, G56, 3.73's, Line-X, P3, lots of camper upgrades...
ken white is offline   Reply With Quote
Old 11-02-2009, 08:15 PM   #7 (permalink)
txag09's Avatar
2007.5 Patriot Blue 3500 6.7L QC, 4X4, trippin gears w/ the 6 speed, 3.73, Smarty, Arson Jr, Valair DD, Airdog 150, 5" TBE, GHD,3.5" intercooler tube, EGR & DPF delete. KM2 255/80R17, 470hp-853 torque with smarty, 493hp-883 torque with XRT
txag09 is offline   Reply With Quote
Old 11-02-2009, 08:20 PM   #8 (permalink)
Sandaholic's Avatar
You got that right!!! Damn some of that chit is HOT!
Well I'm sure they are all quality builds, but The international, the jeep and the XR have got me
05' QCLB 4x4 NV5600,Spec DD clutch,S-06,5" TBE 6" aussie, airdog 150,modded fuel can.,CAI, techni-cooler,mag hytec rear diff. cover,6" lift on truck and fifthwheel,firestone airbags,16gal. of 200 PSI OBA 421HP/1009TQ moves 8000lbs to a 13.88@97.05 SSW
Sandaholic is offline   Reply With Quote
Old 11-02-2009, 08:25 PM   #9 (permalink)
Thanks Big Silver...
Ken White... I'm really correcting the mistakes that Dodge made, that's why I go to all the work. 20 hours of fab work for a 3.5" lift seems crazy, but no matter what I do it MUST be done right, and work perfectly.
I've lifted over 100 trucks in the last 20 years... from a 3" lift (seldom) to 24" if lift. NONE of my trucks have bumpsteer, death wobble, pull to one side or the other.
I've seen some really shoddy work out there... stuff I would never ride in.. even from some large manufacturers. So even though it seems like a lot of overkill for a simple 3.5" of lift, I know it will ride good, handle perfect, be much stronger than stock, and I won't ever have to worry about 37's rubbing even if I'm off-road at severe angles.
I enter all my measurements in Solidworks, and put them through motion geometry to make sure everything works well. Sad that a lot of companies with millions of big bucks don't do the same.
I saw one firm selling traction bars that do absolutely NOTHING, but I guess they thought they looked cool.
Sorry for the rant... but no matter what amount of lift is being done, it should be done right. And I'm pissed at Dodge for some of the crap I see under my truck.
I shouldn't have to re-engineer a brand new truck to make it safe.
Old 11-02-2009, 08:27 PM   #10 (permalink)
cmns2500's Avatar
what shocks you plan on runnin?? some Bilstein 2.5's or so??
Old 11-02-2009, 08:33 PM   #11 (permalink)
Sandaholic's Avatar
Do you have an opinion on Cal-trac's?
Old 11-02-2009, 08:33 PM   #12 (permalink)
ken white's Avatar
What type of axle upgrades did you do to the Rubicon? Did you 4-link the front and/or rear or are you still using a track-bar? Neither of these axles look to have been moved, it looks like you lengthened the frame center section instead, so is that why the steering wasn't upgraded?
I am in the process of rebuilding my Rubicon so it will be interesting to hear what you had to overcome.
