Go Back   Dodge Cummins Diesel Forum > 07.5 and Up 6.7 Liter Cummins > 6.7L Performance Parts Discussion
6.7L Performance Parts Discussion Discussion of Performance Parts For the 6.7L Trucks
CumminsForum.com is the premier Dodge Cummins forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 08-07-2009, 12:31 AM   #1 (permalink)
Air Dog question
I am getting ready to upgrade to an Airdog filter setup. I am confused as to the difference between the Airdog 150 and the Airdog 2. The Airdog 2 says it is preset to 5 psi. Is that a good thing? I'm confused because the Airdog 150 says it is preset to 15-17psi. Is the Airdog 2 worth the extra money?
Here is a link
K2 Diesel Performance : Fuel System Upgrades
2008 Dodge 3500 SRW QC LB 4x4, Auto, 3.73, 6.7L. Thuren springs. Thuren TB, HID's. All deletes. Smarty. 4040XL. Banks SuperScoop. RockCrusher diff guards. Defiant steering support & stone shield. Goerend TC. WCC intake & boost tube. No grid heater. King 2.5" shocks, Carli CA, Yokohama 37", Flex-a-lite fan, Carli Sway bar, Sulastic shackles, MHP trans tune, 3 - Hella 4000's w/55W HID's on Defiant bar.
milo12 is offline   Reply With Quote
Old 08-07-2009, 01:57 AM   #2 (permalink)
Banned
I have the Air Dog 2 165 and it was preset at 21psi. The 165 comes with an adjustable regulator which is nice if you see different climates like I do.
Sean
Silver Pig is offline   Reply With Quote
Old 08-07-2009, 02:28 AM   #3 (permalink)
A Mason's Avatar
I researched this for a while before buying a month ago! For the extra $100.00 for the AD II you get a adjustable psi regulator & low return fuel due to the AD II only drawling as much fuel as the motor demands. So you can use the original return line without cutting into the filler neck for the return line fitting.Also due to the low amount of return fuel you get less fuel foaming(a.k.a hot fuel). For the extra $100.00 bucks i took advantage of the AD II since i was already going to spend $500.00 for the AD 100 or AD 150. As for FP i set mine to 17psi for my VP44 i don't know what your 6.7 calls for. Go with the AD II & set it to what ever you need.
01' 2500 SLT+ QC/SB 4x4 Auto,Isspro Gauges in 3 Pod A-Pillar (EGT,Fuel,Trans),Airdog II,Quadzilla XZT+,4"#304 SS Silverline Turbo Back,S&B Intake,Line-X Coated Bed & Rockers,20" KMC XD's in 305/55/20 Nitto Terra Grapplers
A Mason is offline   Reply With Quote
Old 08-07-2009, 10:43 AM   #4 (permalink)
lrw_cummins's Avatar
What are the limits to the PSI settings (ie low 5 psi and high 40 psi)? I saw a new unit from airdog that delivers 30psi all the time. Wicked Diesel said that if you supply more pressure to the cp3 it will last longer not to mention give a little boost in power as well.
08 2500 QC SB AT 4X4 W/ BANKS INTERCOOLER & INTAKE, WCC AIRHORN, EGR COOLER DELETE, 5" TBE TO 6" DUAL MITRE STACKS, BLACK MAXX, BMK-21, AND FUEL UPGRADES TO COME LATER.......DYNO'D at National Speed 414 RWHP and 778 RWTQ
lrw_cummins is offline   Reply With Quote
Old 08-07-2009, 11:36 AM   #5 (permalink)
im new here. what exactly does the air dog improve i know it gets rid of the air in your gas. im new to all this and i was just wondering what exactly does that do?
Austinj675 is offline   Reply With Quote
Old 08-07-2009, 11:57 AM   #6 (permalink)
Smoked Ya!
Rollin Smoke Diesel's Avatar
iTrader Score: 5 reviews
Well, it a aftermarket fuel pump system that had water/fuel filters for increased filtration and cleaner fuel. It runs 1/2 fuel hose from your tank straight to your CP3. The AirDog is preset at 15-17 psi or can be adjusted on the AirDog II.
I run the AirDog and at wide open throttle the psi never drops like it will on a factory setup when the throttle is mashed.
James
RSD
Monday-Friday 9am-5pm CST, online ordering 24/7
Proudly Serving the Cummins Forum since 2006
We are your Diesel Performance Store....Honest, Fast and Friendly Service!
Authorized H&S Performance, Smarty, AirDog, FASS, ARP, Hamilton Cams, EFILive, Grand Rock Stacks, Edge/Superchips, Quadzilla, Isspro, Diablosport, Spartan Tech, South Bend Clutches, S&B Filters, Flo Pro and many of the leading names in the industry!
Rollin Smoke Diesel is offline   Reply With Quote
Old 08-07-2009, 12:12 PM   #7 (permalink)
bthanks's Avatar
Im running the airdog 2 and its nice cause you can set the psi you want and it elemnates any 1/4 tank issues that you could face with the regular AD. I run mine at 23 psi and on a wot run it will drop to the lowest 20 psi. So its pretty stable.
If you want your truck to be cheap and fast it wont be reliable... If you want your truck to be reliable and cheap it wont be fast... If you want your truck to be fast and reliable it wont be cheap...
bthanks is offline   Reply With Quote
Old 08-07-2009, 06:06 PM   #8 (permalink)
would the dealer care about adding one of these to your truck?
Learath is offline   Reply With Quote
Old 08-07-2009, 09:14 PM   #9 (permalink)
Smoked Ya!
That will depend on your dealer.
James
RSD
Old 08-08-2009, 12:16 AM   #10 (permalink)
cumminser's Avatar
Is there any increase in MPG with AD1 or AD2? and Is there a Stock Fuel Pump & Filter delete kit available?
2007.5^6.7L CTD^4X4^MC^BLACK^3.43^AUTO^EDGE INSIGHT^AFE STAGE2 PG7 SI^EGR BLOCKED-> SMARTY-S67me,DPF DELETE:
cumminser is offline   Reply With Quote
Old 08-08-2009, 12:20 AM   #11 (permalink)
cowpunch's Avatar
Good question. Guess it all depends on your mods you have with it and of course driving habits.
07 6.7 Dynoed at 696 HP 1356 ft/lbs
In no way stock
cowpunch is offline   Reply With Quote
Powered by vBulletin® Version 3.8.5
