Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7L Performance Parts Discussion
6.7L Performance Parts Discussion Discussion of Performance Parts For the 6.7L Trucks Glacier Diesel
Old 07-18-2009, 01:43 AM   #1 (permalink)
For a good time- Smarty
dad2bike's Avatar
Tom's Smarty Journal
I got the Smarty yesterday. Today updated to the DR14ME software.
That process was relatively painless and quick.
Since my machne is Vista, it loaded the drivers automatically. Also being Vista and having 4 processors, I could keep right on with all my internet while it was updating.
Next hurdle the hardware on the truck.
My setup:
4" H&S Turbo to muffler delete
O2 sensors connected
EGT sims still installed
Intake valve & cooler valve unplugged
EGR plunger removed (EGR NOT blocked off)
Smarty installation:
Connected unit and immediately read/cleared codes TWICE. (just cuz)
I then went straight into the install after the last clear.
Decided to install the SW#3 default at this time.
Took about 5 minutes. No clock to look at. While updating the ECM the radio clock is blank.
I was sure to have the doors closed and the radio off during the update. It was interesting to see every indicator light on the dash lit up during this process.
With it being exceptionally Hot here in Vegas, I took Liz for a ride to pick up some milk shakes.
First impressions:
Timing Rattle... OMG does that thing have timing rattle.
Using my PMT Gauges I was able to see the EGT's in the ECM are being fooled by the Smarty software. Mine were locked at about 951* If the ECM were reading the EGT's it would have been 1200 for my SIMS.
I can see the boost is a little subdued on the bottom part of throttle. I can see how that would help MPG's.
Once I was a little up in the RPM's I could feel the torque. Very zippy.
I'll take it out for a highway drive to see how things run.
I want to Thank Bob Wagner for this Smarty in order to do the testing. I appreciate the opportunity.
More to come tomorrow.
Thanks to Andy (Onelongshot) for the following helpful info us all to use.
Here is the link for the tech article.
Need Help with a Smarty, Look inside
Here is the link to the mads site.
http://www.madselectronics.com/downl...stallation.pdf
These are documents that all Smarty owners should read:
Smarty REVO Settings
Installation Instructions
Added points from later updates:
On my 1st short road trip I noticed increased trans temps from stock. About 10-20 degrees more. (N/M came back down with lower outside airtemps)
Now running SW#5 w/VGT2- OMG this is a monster.
Noticing Boost is very aggressive compared to previous. Also seeing boost readings or 3-4 now during Ebrake usage.
SW5 w/VGT3 is very strong and controllable. Pulls great in the mid-range.
Snap test on SW5 results in a big puff of smoke. (Not rolling coal)
Observations so far:
Simplistically speaking
SW 2/3 appears to be equivilent to PMT-Tow
SW 4/5 appears to be equivilent to PMT-Performance
SW 6/7 appears to be equivilent to PMT-Extreme
Well, Not quite.
Put SW7/Default on. It appears to have a deeper stronger power than 5's quick snappy power. I notice when on the freeway w/cruise the boost is low, 2-3 psi.
MY last tank was mixed driving and assorted settings and getting used to the Smarty. I still got a whopping 18.1 mpg. Pretty good for what I've been doing to this truck. I'll do my best to keep my ADD in check and stick it out for this tank with SW7.
I am due to do all my fluids over this weekend and next. I don't expect that to have much effect on my results.
SW#1 appears to be the Economy tune I'm looking for. More testing to come.
SW#0 is a real dog. IMHO it was meant to be. Has the timing rattle like the other tunes. Uses more boost for cruising. Seems to be for use in emission test trips. That's what I'll be using for mine.
n/m sw#1 just isn't cutting it for me. I'm going to run thru this tank on SW#3. Once I got used to the power and holding back, the lower levers just seem limp.
VGT 4 is extremely Aggressive for the Boost & fuel Pressures. on sw3 I'm seeing boost of 10psi cruising and FP of 15 or more cruising as well. Not for the faint of heart.
Added notes from my 1800 mile trip 08/09:
I lasted only 50 miles before changing from SW3 up to SW5/v3 to tow my 6000 trailer. This really worked very well. Pulled some very long/large grades without any effort. My MPG for the trip ended up at a little under 14mpg. This included quite a bit of 4x4 dirt roads and some towing as fast as 70mph.
Even/Odd levels:
We've been discussing how things works using the even vs odd sw levels. It is curious the HP listed is the same, yet the even has stock timing.
Some are testing sw4 w/ Timing2. I'm running sw2 default for awhile. Very little rattle yet still very strong. Looking to see the economy at that setting.
SW5 with Timing1 is NOT a good combination. Causes surging on grades when the RP hits 20Kpsi or more.
Evolution of deletes Testing:
My plan is to test the following:
#1 Stock exhaust w/EGR unplugged & CEL
#2 Stock exhaust w/EGR unplugged Code clearing w/PMT
Stock DP & stealth DPF & NOx, EGT & PS Sims. EGR unplugged w/CEL Dropped from the testing
#3 Stock DP & stealth DPF & NOx, EGT & PS Sims. EGR unplugged, code clearing
Stealth exhaust complete, EGT & PS Sims. EGR unplugged w/CEL Dropped from the testing
Stealth exhaust complete, EGT & PS Sims. EGR unplugged code clearing Dropped from the testing
#4 Stock DP & Stealth DPF/NOx, EGT & PS Sims. Smarty loaded SW5 default
I'll keep track of when/if regens occur thru this run of tests.
My testing Starts from the base.
As of Now I"m back to stock exhaust w/ EGR unplugged & P0405 Code
Date- 10/12/09
Step #1 results:
Just finished 200 miles on EGR unplugged only
Fuel 14.8 gal
MPG calculated- 16.4MPG For the remainder of the test, THIS IS MY BASELINE MPG.
Step#2 Results:
10.5 gallons = 15.9 mpg. I would call that about a wash on the code clearing w/ egr unplugged only (no DPF delete)
The regen was very painful again. Lightning bolt and a P0106 MAP code. The regen occurred at only 125 miles this time. Interesting.
IMHO The Butterfly gear must stay in unless there is a DPF delete & code clearing.
Step#3 Results:
11/11/09 421miles/23.5 gallons= 17.91
Tom
2008 Quad-Cab,LB, 2500, 6.7L, 4X4, White/Kaki, Big-Horn, 3.73 Auto, AS flash, K&N Air Filter, no baffle, Testing in progress- step 4, Stealth DPF, Smarty sw3 PMT gauges. Mag-Hytec Pan & Diff covers.Toms smarty Journal ....... DIY Deletes How-To
Stealth is the WORD!
dad2bike is online now   Reply With Quote
The Following 17 Users Say Thank You to dad2bike For This Useful Post:
-lenny- (08-06-2009), Bob Wagner (07-19-2009), BOOOST (07-18-2009), bthanks (07-18-2009), CANYONBIKER (08-12-2009), cockdiesel (07-25-2009), cumminser (07-25-2009), Daddy'O (07-18-2009), Dodgeram082500 (07-20-2009), ilovemydiesel04.5 (09-10-2009), Low Budget (09-15-2009), MCummings (10-04-2009), nightmaredodge (09-17-2009), Onelongshot (07-19-2009), Punisher 67 (Today), Rocksolidcummins (09-02-2009), strokethis6.7 (10-16-2009)
Old 07-18-2009, 02:12 AM   #2 (permalink)
BOD
rbmedic75's Avatar
I wanted to be the first to say in your thread dad I definately am subscribed. I think this ( if we can keep on topic) will be a very informative post that should probably end up a tech sticky. Try and get us some of the HP info to as well as mileage. I think Marco and bob made a smart call.
08 quad SB 6 stick time to:SMARTY 14ME, BOD Intake. BOD EWG. BOD @ http://www.rollinsmokediesel.com/
Parts on the shelf waiting--- Isspro EV2, 6" twin Aussie's, Banks Intercooler, Toyo OC MT 37 13.50 R 17,
rbmedic75 is offline   Reply With Quote
Old 07-18-2009, 05:04 AM   #3 (permalink)
Boom27's Avatar
So I don't know if it is just my truck but when I shut down the truck turns off HARD if that makes sense. The truck shacks real bad any idea's ???
07 6.7 BigHorn, 6spd man. 4x4 2500 ! air baffle gone. 7" stacks , Go Rhino Dominator 2 steps, XDI CAI, S67ME
Boom27 is offline   Reply With Quote
Old 07-18-2009, 07:55 AM   #4 (permalink)
bunga's Avatar
Subscribed for the knowledge and learning experience.
2008 Dodge 6.7 Cummins 3500 Mega 4X4 auto, Laramie, Black, 100% stock . . . . . so far!
bunga is online now   Reply With Quote
Old 07-18-2009, 08:29 AM   #5 (permalink)
Survivor of Menopause
Daddy'O's Avatar
Good deal. Looking forward to your reports.
Wayne
08, 2500 Reg Cab 4X4, 6.7, G56-AE, 3.42, AP Flash, S&B CAI, 4" Flo-Pro TBE, H&S-XRT-60HP, Valair Kevlar 3400 SD, Best MPG to date......21.65 MPG
Daddy'O is offline   Reply With Quote
Old 07-18-2009, 08:38 AM   #6 (permalink)
trbizwiz's Avatar
Mine doesn't have a smarty, but it seems to shut down real hard too. I should have my junior Monday I ordered it from bob Thursday. I'll comment back then. Sorry for jacking a mod's thread, but I share a symptom and i am curious as to the cause.
I drove big diesels and some of them did this. But my 05 duramax did not?
2006 Mega Cab 2500, Cummins 5.9, G56,airaide intake and filter, awesome sound from a resonater thanks Wally, Quadzilla boost fooler, KMC rockstar 20's, goodyear MT/R 35's with kevlar
trbizwiz is offline   Reply With Quote
Old 07-18-2009, 09:27 AM   #7 (permalink)
dad2bike's Avatar
I did notice that letting off the gas with the EB on it seemed way stronger on the braking. Might have something to do with the slightly increased Torque settings.
Today I'll be doing some highway driving. Our temps are hitting the roof. 115* expected. That means by noon I'll be done with my out work on cars. The father's mechanic shop is never closed.
Thank you to y'all for reading in here. I hope it can be of some use to others.
Tom
Old 07-18-2009, 09:39 AM   #8 (permalink)
dad2bike's Avatar
No mod here. Just another member wanting enjoy my truck. While I'm journaling my results everybody is free to throw in anything that can help others. Dunno what a Junior is. Does that unit work on a 6.7L?
Tom
Old 07-18-2009, 09:44 AM   #9 (permalink)
Daddy'O's Avatar
His sig indicates he has a 5.9 & is most likely speaking of the Smarty Jr. tuner.
Thanks,
Wayne
The Following User Says Thank You to Daddy'O For This Useful Post:
dad2bike (07-18-2009)
Old 07-18-2009, 10:33 AM   #10 (permalink)
Si vis pacem, para bellum
BroncoHound's Avatar
All Cummins shut down that way. It's a product of the REALLY big internal engine componenets shutting down in a sparkless combustion system. Dmax's are kinder, gentler, and more ladylike. Big C's shake, rattle, vibrate, and generally beat the hell out of the frame and suspension. Learn to embrace the horror, and you might even find yourself loving it after a time.
Oh, one more thing. Both of you have manual transmissions. Hold your clutch in when you shut it down. That will calm the shaking a little bit. The aluminum casing of the G56 transmission tends to amplify the shutdown shimmy. Disengaging the clutch removes the transmission from the equation.
Tom, good thread so far. Look forward to seeing your continued impressions and data logs.
'08 QCSB 4WD G56 3.42: 6000k HIDs, HBS Leveled, Carli-valved 5100s, Thuren track bar, SSSSS, 325/70R17 Nitto TGs, Ride Rites, ISSPRO EV2 Boost/EGT, Smarty, GHD, Shaved BlueTec badge
"Certainly there is no hunting like the hunting of man and those who have hunted armed men long enough and liked it, never really care for anything else thereafter."
BroncoHound is offline   Reply With Quote
Old 07-18-2009, 10:54 AM   #11 (permalink)
Barney's Avatar
I want to also subscribe and see the results as well........I have put the 14me on mine this past week and seems like with mine with the EB on there is lots of whine which is normal but it seems like I also get it under a slight acceleration as well.......I mean I can give it a little throttle and the noise is their off and on almost like a boost leak.
JIM
2008 Mineral Grey Big Horn 4X4---Auto---Rhino Lining---Recon Cab & Tail Lights--Hell Bent 2" level kit--Cooper 315's--Edge Insight----H&S EGR delete----Bilstein 5100
Smarty & 5" TBE from Rollin Smoke
Barney is offline   Reply With Quote
Old 07-18-2009, 10:58 AM   #12 (permalink)
Hey Tom, I've heard another guy mention "timing rattle" what is it, and is it bad detremental to the engine?
jason250r is offline   Reply With Quote
