Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7L Performance Parts Discussion
6.7L Performance Parts Discussion Discussion of Performance Parts For the 6.7L Trucks Glacier Diesel
Old 06-30-2009, 01:16 PM   #1 (permalink)
modded VGT's
Who is all making them, and what sizes. Anybody running one of them that has any input?
2007.5 6.7l cummins,5in TBE, when did they put a EGR on a 6.7??? TS mp-8, S&B intake, Air dog 150, Smarty S67me Arson Jr, ARP's,MHP tune ATS Transmision & TC,. Suspended with carli starter kit, Thuren track bar, fox steering stabilizer
kwag707 is offline   Reply With Quote
Old 06-30-2009, 01:34 PM   #2 (permalink)
theicon2u's Avatar
Fleece makes an 66mm and Industrial Injection makes a 64mm. Im going to go with the 66mm from Fleece. Fleece told me that I would see a 250 drop in EGT's and make about 45 psi boost. I would have a drive pressure issue anymore. The exhaust brake will work better also. They also said it spools just as fast as stock. II told me the same but they where only seeing 150 drop in EGT's.
6.7L, 68RFE, Electric Blue, Suspended by Carli Starter Kit, Carli Track Bar, Flares, Window Vents, 4" TBE, CAI, H&S 175HD, Goerend TC, Soon: Fleece 66mm Cheetah VGT
Member of TeamIdiots.com
theicon2u is offline   Reply With Quote
Old 06-30-2009, 02:21 PM   #3 (permalink)
sounds pretty sweet
Old 06-30-2009, 02:24 PM   #4 (permalink)
How much are they charging for this upgrade? PM me if you dont want to post it up please.
2008 6.7 CTD, 6" superlift, PSC steering brace, 35's on 20's, 5" TBE, AFE intake, Smarty, Airdog 150, ATS Head studs, DPF/EGR deletes, Isspro Performax gauges, home built 3 1/2" intake tube
qualmq is offline   Reply With Quote
Old 06-30-2009, 02:25 PM   #5 (permalink)
send me a pm to if you don't mind, thanks
Old 06-30-2009, 02:42 PM   #6 (permalink)
theicon2u's Avatar
Pm's sent
Old 06-30-2009, 02:43 PM   #7 (permalink)
theicon2u's Avatar
How is your ATS trans holding up?
Old 06-30-2009, 04:36 PM   #8 (permalink)
bdavis466's Avatar
Can I get a PM as well? Thanks!
2008 3500 Crew Cab long bed, 8" lift with 37" Toyo M/T, XRT with a $2000 BADP exhaust pipe
bdavis466 is offline   Reply With Quote
Old 06-30-2009, 04:40 PM   #9 (permalink)
H&S Groupie
wildcummins's Avatar
send me a pm too, please!
08 daily driver 3500 qcsb laramie, g56 AFE megacannon, hot edge/attitude(most expensive gauges I've ever purchased!),XRT 175, south bend 3600 dd
97 puller 3500 dually cds ag governor pump and billet charger, and a south bend dd
wildcummins is offline   Reply With Quote
Old 06-30-2009, 04:58 PM   #10 (permalink)
bluecollar6.7's Avatar
can you send me one too please
2008 4 dr, G-56, sb 3250 dd, leveled, viair compressor, 35" pro comp mt's, aftermarket taillights, line-x bed liner, xrt, s&b cai, shibby stage 1 intake horn, boost tube, egr out, custom grid heater delete, stealth exhaust, isspro ev-2 gauges, train horns!
bluecollar6.7 is offline   Reply With Quote
Old 06-30-2009, 06:45 PM   #11 (permalink)
theicon2u's Avatar
PM's sent
Old 06-30-2009, 06:49 PM   #12 (permalink)
b1222white's Avatar
PM me please
2008 2500 6.7 4x4 SLT Lonestar 6spd auto, slightly modified...............
b1222white is offline   Reply With Quote
