Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7L Non-Powertrain
6.7L Non-Powertrain Discussion of Accessories, Interior, everything not power related...NO ADVERTISING
Old 08-07-2008, 10:37 AM   #1 (permalink)
2" Level and tire wear
Hey Guys. I installed a 2" Hell Bent level kit and 35" BFG mud terrains. Got it aligned 2x, and am starting to see the outer edges of the front tires wearing a bit more than the inside edges with only about 3k miles on the tires. Inside of tire still has a sharp edge, but outside is getting rounded off. Anyone else noticing this?
Truck drives straight, but does pull one way or the other depending on the crown of the road...which I assume is normal considering the width of the tire.
2007 2500 6.7, 2" level, 35" bfg's
libeachbum is offline   Reply With Quote
Old 08-07-2008, 10:48 AM   #2 (permalink)
Mine did that too. I got it aligned and the problem went away, so I don't know if you are having the same issue. My front passenger tire was wearing, but the driver side was fine. I think that has to do with the fact that the axle is pushed to the passenger side a little because the trackbar is now too short. Maybe you should try a drop bracket or adjustable trackbar?
07 6.7 3500 4x4 G56, baffle delete, HBS leveling kit, AFE cai, Edge J/A, H&S 4", K2 EGR plates, Toyo 35x12.50 M/Ts on the stock rims, 18k
94 in the barn waiting for more goodies and a bombed 95 put out to pasture
shooter_d is offline   Reply With Quote
Old 08-07-2008, 02:52 PM   #3 (permalink)
kupecda's Avatar
This could be driving habits to. If you tend to corner faster the weight transfer to the outside tire can cause the tire to roll over a little more and wear quicker. I tend to drive this way and I do notice that my tires do wear a little more on the outside than the inside. I rotate every 5K miles and it has never been a big problem for me.
2008 Ram 3500 SLT QuadCab LB SRW 4x4 6.7L G56 Light Khaki
DiPricol Optix(Pyro/Boost/Diff Temp), Line-X, B&W Turnover Ball, ProTech, PacBrake Air Springs, HBS 2" leveling kit, MagHytec Rear, Willmore Wheel-to-Wheels, High Idle enabled, 276hp 510ft-lb
kupecda is offline   Reply With Quote
Old 08-08-2008, 07:09 PM   #4 (permalink)
04SSHD's Avatar
i haven't driven enough on my HBS kit to notice tire wear, maybe I should get it aligned now...
07.5 Dodge Ram 3500HD SLT 6.7L, 6 speed manual, Hypertech Max Energy, Pos. Crankcase Vent, 4.10, reg cab, C&C, HBS 2" leveling kit, 5000k HID Xenon headlights & fogs, Hard wired Valentine V1, 2200 miles to date, DPF & EGR bites the dust soon
04SSHD is offline   Reply With Quote
Old 08-08-2008, 07:14 PM   #5 (permalink)
Smokin'
Hot Stuff's Avatar
Actually the front axle is pulled towards the drivers side cause the Track Bar is too short.
'03 Black 2500 QC LB 4x4, H.O. 6 speed BHAF, 2" lift, not leveled, black H2's, 35" BFG MT's, B&W turnover, Juice w/ Attitude, 5" str8 pipe, BD lift pump, spin on fuel filters
Hot Stuff is offline   Reply With Quote
Old 08-08-2008, 07:18 PM   #6 (permalink)
I suggest rotating the tires front to back everytime you change your oil. This will even out the tire wear. I always did on my F350 and it exteneded the tire life, I am doing it now on my 95 cummins.
95 Cummins 5spd, 4 inch dual exhaust, Amsoil filter BHAF, 90 horse injectors, #5 Fuel plate full forward. Modified AFC, HTT 62/71/13 installed 05/06/08. Tapped the KDP from the front !!
BUCK2 is offline   Reply With Quote
Old 08-14-2008, 08:45 AM   #7 (permalink)
I just installed a HBS 2" leveling kit. is there any way to fix the "track bar too short and axle sticking out the driver side" problem without ordering a $300 adjustable track bar? Thanks for the help.
2008 2500 6.7L, 4x4, manual tranny, quad cab, short bed, SLT, Bighorn Edition
schloe is offline   Reply With Quote
Old 08-14-2008, 08:54 AM   #8 (permalink)
Need more money 4 habit!
Talon4u2nv's Avatar
you can get a 20-50 dollar track bar relocation braket.
I had a BDS one on my last 2500...it was pertty pricey. I know that Top Gun Customz sells one for like 20 for 0-3" level kits and another for i think it's up to 5"
hope that helps yah out schloe.
2000 Ram 2500 QC Sport
K&N Intake with Amsoil filter, 5" soot pipe, Autometer boost/egt/fuel/trans temp, Airdog150, Boost Elbow and Edge COMP with BD Stealth Plate, 3G wheels with 285/70R17 BFG AT KO tires.
Save'n for a Goerend with all the goodies and some DDP sticks
Talon4u2nv is offline   Reply With Quote
Old 08-14-2008, 09:00 AM   #9 (permalink)
foghornBIGHORN's Avatar
Ditto
Also runnin the 2" HBS. Have 285/70/17 BFG AT's at the moment but they were worn all to hell before I put it on. Lookin at 35" cooper STT's now. Whoever's runnin bigger tires with a levelin kit, what else have ya'll done to fix the outside wear problems besides an allignment? Anything short of orderin a new track bar?
And what's a drop bracket?
Ricketts
Silver 2006 Quad SLT 2500 CTD 5.9L : 2" HBS : ICEBOX w/ Amsoil Nano 4091 : BD Intake Elbow : FBD 5" Exhaust : Smarty JR: KIA Grid Heater/Kitty/Silencer :
foghornBIGHORN is offline   Reply With Quote
Old 08-14-2008, 09:01 AM   #10 (permalink)
guess im a little too slow
sounds like a plan talon
Old 08-14-2008, 11:33 AM   #11 (permalink)
Thanks Talon. I found a bracket for 3-5" lifts but not one for a 2" lift. I'll have to give them a call.
Old 08-14-2008, 01:19 PM   #12 (permalink)
Smokin'
Hot Stuff's Avatar
I've never seen a bracket for less than 3" of lift. And that'll just make the axle stick out the other side. Either just don't put any bracket on it or order a adjustable track bar. That's about your only option.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
