Go Back   Dodge Cummins Diesel Forum > 07.5 and Up 6.7 Liter Cummins > 6.7L Non-Powertrain
6.7L Non-Powertrain Discussion of Accessories, Interior, everything not power related...NO ADVERTISING
Old 11-19-2009, 08:17 AM   #1 (permalink)
Hired Gun's Avatar
Diesel Fumes coming from HVAC
This morning when I left for work my HVAC system was pouring diesel fumes smells through the ducts. It smelled like raw burnt diesel bad. I had to shut the heat off it was so bad. I tried all settings on the heater like floor, chest, and defroster. They all smelled. Then after about 35 miles it was cold and fogging up so I had to turn the defroster back on. It smelled for a few seconds bad, but then got less and less with each second until it was normal. So I ran it like that the rest of the way.
I got my daughter dropped off at school, and then tried the heater on High with and without recirculate on. It as well cleared up the smell.
This morning I started the truck to warm like I have for all my trucks, and this is the first time it has happened on anything. Any ideas what has happened?
Hired Gun
2007 6.7 Automatic 6 speed DRW
Smarty, 5 Inch Magnaflow turbo back
Hired Gun is offline   Reply With Quote
Old 11-19-2009, 08:36 AM   #2 (permalink)
Hemicross's Avatar
Second that mine does it sometimes too on and off, someone bump if they know what it is please?
Hemicross is offline   Reply With Quote
Old 11-19-2009, 10:37 AM   #3 (permalink)
Rockwerx's Avatar
I have seen some gaskets fail on the EGR cooler. Check the one at the rear to see if the nuts are tight. Sometimes you can see some carbon build up if it is leaking also. It could be a cracked EGR cooler or manifold.
2008 3500 Laramie QC 4x4 LB DRW 6.7 CTD Auto LSD 3.73 EJA EPP 5" TBE AFE CAI Shibby-EGR 3.5" BOOST TUBE AirDog 150 H&S RWX
Most wanted mods: WCC Intake,Twins
Rockwerx is offline   Reply With Quote
Old 11-19-2009, 11:17 AM   #4 (permalink)
I smell fumes often also, will check that this weekend, thanks.
2009 SLT QC SRW 4x4 • 6-speed-auto • 3.73 gears • 285 BFG-AT tires • All Stock • Wanna see? CLICK ME
SouthernBoy is offline   Reply With Quote
Old 11-19-2009, 12:00 PM   #5 (permalink)
Hired Gun's Avatar
I called my dealer, which is excellent and they have not heard of this before, and will look at it tomorrow. I told them I would check it today on the way home to see if it happens again. Who knows?
Thanks I will look as well.
Hired Gun
Old 11-19-2009, 12:51 PM   #6 (permalink)
trlr prk's Avatar
I'd check over the cooler area. I've heard of the gaskets leaking and coolers cracking.
08 2500 QCLB 6.7. 4x4. 68RFE. Gen 1 5" SS. EGR & Cooler Gone. Hot Edge. Single Amsoil Bypass. Remote Fuel Water Sep. and 2 Micron Filter. Marathon Seat Covers.
trlr prk is offline   Reply With Quote
