Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7L Non-Powertrain
6.7L Non-Powertrain Discussion of Accessories, Interior, everything not power related...NO ADVERTISING
Old 10-30-2009, 12:41 AM   #25 (permalink)
Take Your Chrome Home.
K5Cruz's Avatar
This is 32', about 7k unloaded. Filled with tools and chains, and the dozer weighs between 9000-9500 pounds. Its not enclosed, but it is shaped like... well... a bulldozer. Pulls just fine, no airbags or anything, just a good brake controller.
I've also pulled a 28' bumper pull enclosed several times, no problems there either. With a good hitch I think you'll be fine.
2007 6.7 2500 Crew Cab 6 Speed Manual. Black, Black Rockstars, Mud Grapplers, H&S 4", MBRP, PMT, AFE, Valair DD, AD150, MP-8. 458hp/941tq.
Chrome wont get you home and it only takes 13 months to get a Road Armor.
K5Cruz is offline   Reply With Quote
The Following User Says Thank You to K5Cruz For This Useful Post:
winn99 (10-30-2009)
Old 10-30-2009, 12:42 AM   #26 (permalink)
Drew G.'s Avatar
Originally Posted by winn99 View Post
Thats for the link slowlt1. I have a question. If I just used like a regular B&W ball or something similar and put something like this on the trailer "Popup Gooseneck nine inch trailer extension for shortbed trucks, Horse Trailers, gooseneck hitch, Race Car Trailers, shortbed hitch, short bed truck hitch, Popup Hitch,short bed hitches, short bed truck hitch extention solution for your gooseneck tr would that not work?
i use one on my aluminum stock trailer and i have been in plenty of real tight spots and i have never hit the cab
btw here is the trailer
'03 Dodge 2500 QC CTD H.O. 6 sp 4" exhaust with 5" tip. official beat $h!t down posse member #1
Drew G. is offline   Reply With Quote
Old 10-30-2009, 12:46 AM   #27 (permalink)
Drew, Do you have any pictures showing the hitch setup in the back? Thanks!
Black 2008 Dodge 2500 QC 6.7L - Hypertech Max Energy
winn99 is offline   Reply With Quote
Old 10-30-2009, 12:55 AM   #28 (permalink)
slowlt1's Avatar
Im not saying it cant be done but with that adapter but you are just making the hitch longer you are not moving the pivot point at all. I have pulled full with trailers with a short bed and can say i dont like it to much. I just wanted to give you information on what would allow you to back up and turn the most. Contact with the cab is expensive, in my opinion more money up front on a hitch is better than paying to have the roof of your cab re worked. I think converting it to a 5th wheel and using a sliding hitch is the best route and would provide the sharpest turning angle. You could also get the trailer made with a angled front box.
slowlt1 is offline   Reply With Quote
Old 10-30-2009, 01:05 AM   #29 (permalink)
I don't know much about goosenecks is why I'm asking all these ???'s. I appreciate the help. I'm not wanting to have a sliding hitch in the back of my truck all the time is the reason I don't want to go that route. Also, I found a trailer for a great price that is exactly what I want just want to find out what I need to tow it. This is confusing
Old 10-30-2009, 01:08 AM   #30 (permalink)
I tow a trailer similar to that, but our race trailer is 44ft with living quarter in the front. They are tounge heavy so you will definetly want air bags. you will want a slider hitch or else you will hit the cab trust me i learned the hard way.. no need for a dually our trailer pulls like a dream. they make a slidder hitch that automatically cambers it away from the cab when turning, it would be money well spent. my fifth wheel hitch is on a rail system so you can un pin the hitch and your bed is clear no hitch, I also have a goose neck adapter that fit on the rail so i can pull both types
09 Dodge mega cab larmine 6spd auto mfg date 12/08 . h&s black max, h&s 5" tbe , h&s egr & cooler delete, Afe.
98.5 dodge reg cab 5 spd manual. edge attitude with hot
brindley is offline   Reply With Quote
Old 10-30-2009, 01:17 AM   #31 (permalink)
slowlt1's Avatar
thanks im just speaking from personal experience. Im not trying to be a dick.
Old 10-30-2009, 01:18 AM   #32 (permalink)
I'm really not wanting a slider hitch. Way to expensive IMO and hate how they take up the whole bed pretty much. I'm not sure if this trailer has a 5th wheel or gooseneck. Guess I will just have to find out in the morning. The picture looks like its a 5th. If it was I guess I could just get the adapter so it would hook up to a ball.
Also would something like this move the pivot point far enough back to clear the cab?
Hitch Solutions The Rapid Hitch
Old 10-30-2009, 01:34 AM   #33 (permalink)
slowlt1's Avatar
The further back the pivot point the better, but you have to do so without moving the gn plate rear of the axle. I think b and w make a 6in offset ball.... but i think they call for the hitch to be installed closer to the cab then some other brands you will just have to figure out what setup allows the pivot point furthest back.
Old 10-30-2009, 01:39 AM   #34 (permalink)
Drew G.'s Avatar
no i sure dont but it puts the trailer a good 10 inches back. the only problem i would see with it is with this hitch is you cannot haul it with a flat bed truck as it wont fit in the hole unless the bed has the goose neck trough.
Old 10-30-2009, 01:44 AM   #35 (permalink)
Drew G.'s Avatar
also that extender makes it a million times easier to unhook the trailer without having to squeeze my arse into the bed.
Old 10-30-2009, 02:04 AM   #36 (permalink)
How close does it come to your cab?
