Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7L Non-Powertrain
6.7L Non-Powertrain Discussion of Accessories, Interior, everything not power related...NO ADVERTISING
Old 10-23-2009, 10:56 AM   #1 (permalink)
35x12.5x17 Before Leveling?
I have my HBS leveling kit sitting there ready to install I just haven't had a chance to do it yet. My Cooper STT's in 35x12.5x17 are in and ready to be installed. I am putting them on the stock wheels. My question is can I have the tires put on before I install the leveling kit? A little rubbing will not be a problem since I plan on installing the kit this weekend. Thanks for any help.
08 Dodge 2500 laramie quad cab - light khaki metallic , manual trans: Tonneau, Spray in bed liner,2" HBS leveling kit, 35x12.5x17 Cooper STT on stock wheels
tgj101 is offline   Reply With Quote
Old 10-23-2009, 11:06 AM   #2 (permalink)
whitey70ss's Avatar
from what I've read on here some guys are putting 37's on stock suspension.
'08 2500 QCSB-Black-shibby egr/cooler delete-RSD 5"TBE-XRT-68rfe-leveling kit-315/70/17 BFG AT KO's-tinted.
whitey70ss is offline   Reply With Quote
Old 10-23-2009, 11:08 AM   #3 (permalink)
bthanks's Avatar
Yea guys are fitting 37s on stock so you should be ok as long as you are staying with your stock wheels
2008 qcsb, southbend DD,airdog II,smarty,arson jr,afe mega cannon, SB66, boost tube, 5" tbe, BDS longarm 6" lift, helo maxx 8's w/35X13.50's
http://www.youtube.com/watch?v=tAkfRYekA-0- 6.7 Smoke switch
http://www.youtube.com/watch?v=a-6pZYH9pGY- Burn out!!!
www.rollinsmokediesel.com <--- Look For Black Ops Diesel!!
bthanks is offline   Reply With Quote
Old 10-24-2009, 10:01 PM   #4 (permalink)
rs1404's Avatar
I have a hbs level kit but havent installed and i am running 35" cooper stts and they only rub a little on hard turns but nothing to worry about. so your good to go
2008 6.7L Mega Cab 4x4, S&B Cold Air Intake, Hell Bent 2.5" Level Kit, H&S XRT, 5" TBE DPF/EGR deletes from RSD, B&W Hitch, Frontier Replacements, 35" Cooper Discoverer STT
rs1404 is offline   Reply With Quote
Old 10-24-2009, 10:24 PM   #5 (permalink)
dieseltech's Avatar
35s fit just fine on my truck before i leveled it. go for it!
07.5 dodge 2500 6.7l cummins 6sp edge hot, mp-8, 2" leveling kit, 35" mtz, home made egr delete plates and shibby sims tester. 455hp 900tq at the wheels
dieseltech is offline   Reply With Quote
Old 10-24-2009, 10:42 PM   #6 (permalink)
AUTOBOX TRANSFORM!!!
SkinInc69's Avatar
Depending on what brand of 35's you put on will depend on how much they will rub at full lock on the control arms with the stock wheels.
2007.5, 6.7L 2500 4x4 LARAMIE 68RFE- H&S Performance Hot Damn 175 ATT, Industrial Injection Stage 2 CP3, FASS 150/150, H&S 5" TBE straight piped, Snow Performance water methanol injection, Capped fuel rail, EGR & Cooler delete, AFE Mega Cannon, Black Op's Diesel intake horn, 3.5" Shibby boost tube, DiPricol Gauges, 3" BDS lift, Bushwacker flares, 20x12 iON-Forged Terminators, 33x12.5 Nitto Mud Grapplers, RDX Billet Grill, Line X, 20% Tint w/ 9" brow, 10,000K HID Hi/Low, Fogs. www.hsperformance.com
Old 11-03-2009, 10:49 PM   #7 (permalink)
they will fit but they will rub without an offset wheel, i just went through this and put the rims on in signature,(18 mm offset).
07.5 Metallic Grey 2500 Mega Cab 4x4 SLT, 6.7l, 6 speed auto, 17" v-tec warriors, 35" BFG KM2'S
Rcxdm40 is offline   Reply With Quote
Old 11-04-2009, 04:27 PM   #8 (permalink)
firefighter863's Avatar
I have 355 60 20s nitto terra grapplers and thay r 36.8in tall and 14in wide acording to 4lo.com metric tire converson. My truck is stock and they rub a little but nothing to work about
2007.5 4door sb 2500, 6.7L 4X4 White Sport,H&S DFP Delete thanks to james @ rollinsmoke, 5in Tip, K&N CAI, Edge Juice W/Attitude HOT, 5in Window Tent, 20in Ultra Wheels, 355/60/R20 Nitto.. Terra Grapples....want mp-8 or dpp
firefighter863 is offline   Reply With Quote
Old 11-04-2009, 04:41 PM   #9 (permalink)
lesbian at heart
elephantrider's Avatar
i ran 35x12.50 cooper st's with no level kit.
jason
04.5 6sp qclb whiskey tango foxtrot, over
elephantrider is offline   Reply With Quote
Old 11-04-2009, 05:00 PM   #10 (permalink)
04SSHD's Avatar
should be fine with minimal rubbing
07.5 Dodge Ram 3500HD SLT 6.7L,11/06 build,5/08 delivery,PMT,DPF & EGR fell off,G56,4.10 (3.73 soon),C&C,HBS,5000k HID Solutions lights & fogs,14,000 miles to date,35" M/T,22.5's soon,Dyno at 445hp/907tq
04SSHD is offline   Reply With Quote
Old 11-04-2009, 06:29 PM   #11 (permalink)
bigbulls1954's Avatar
As long as you have the stock wheels you should have no problem...they have the correct backspacing...I ran Toyo MT's 12.50x35x17 before my Carli suspension without any rubbing problems...totally stock...
06 MegaCab 4x4 3500,Bully Dog Outlook,Carli 2.65 system with other Carli goodies.Toyo MT 35's
bigbulls1954 is offline   Reply With Quote
Old 11-05-2009, 04:40 PM   #12 (permalink)
SwampWater's Avatar
hmmmm, i was told even 33s would be a problem...
http://s90.photobucket.com/albums/k2...riversside.jpg 2007.5 MegaCab Laramie 4x4 6.7L all stock
2004 RSCB SLT Hemi Slammed, Shaved, Painted, Speedracer
SwampWater is offline   Reply With Quote
