Go Back   Dodge Cummins Diesel Forum > 07.5 and Up 6.7 Liter Cummins > 6.7L Non-Powertrain
6.7L Non-Powertrain Discussion of Accessories, Interior, everything not power related...NO ADVERTISING
Old 10-20-2009, 08:44 PM   #1 (permalink)
Tony G.'s Avatar
Door Rattle
Just curious but are anyone else's doors rattling? The plastic on the inside, not the actual door in the frame. I only have 16,500 miles on the truck, i think its a little too soon for it to start rattling.
08 Bighorn 2500 4x4, 6.7, 6spd auto
Tony G. is offline   Reply With Quote
Old 10-20-2009, 09:05 PM   #2 (permalink)
blackmega3500's Avatar
I had the same thing happen mine was the lower front passenger door it was pretty annoying and then I just noticed the other day it went away
09 Black mega 3500 3.73 DRW 6.7l auto. Smarty sw9, dpf mia, S&B dry, Edge for gauges, Shibby stg 2 intake horn, Shibby boost tube, Airdog 2, Shibby Throttle valve delete, bod ewg, MHP stg 2, Shibby grid heater delete, rail plug
blackmega3500 is offline   Reply With Quote
Old 10-20-2009, 09:15 PM   #3 (permalink)
Tony G.'s Avatar
Mine just started and its driving nuts, I am think I am going to ask the dealership if there is anything that they can do but I really doubt it. It goes away when the window is down, even if its just cracked. I am probably stuck with it though.
Old 10-20-2009, 09:18 PM   #4 (permalink)
smoke everyday's Avatar
mine rattles to...people get in my truck and start lookin around and tell me i thought it was new lol....
08 cummins 2500 6.7,Inferno red, 4:10 6sp auto 4x4, 2" levelin kit, 35" toyos, black max 175hot damn agg. turbo gutted dp 6" tip and: lovin me some smoke
smoke everyday is offline   Reply With Quote
Old 10-20-2009, 10:16 PM   #5 (permalink)
Shagginwagon's Avatar
The rattle in my door is from the door locks. I bought those aluminum ones at Genos and they really rattle when I hit a bump or if the subs are poundin'.
'07 2500 5.9L Mega, Black, Laramie, 4X4, 48re
Isspro's, AFE Pro Dry, BMK-11, AMSOIL fluids, Debadged, CFM+
S-06, Mag-Hytec Covers
IAFF Local 1159
Shagginwagon is offline   Reply With Quote
Old 10-21-2009, 10:02 PM   #6 (permalink)
mine does the same.. Some of it is the door locks, but a lot of the noise is from the plastic door panel rubbing against the metal door frame.. What I did was outlined the door panel and then removed them.. After they were off, I took some clear tape and followed the line on the door itself I just traced all the way around, re installed the door panels, and now no more rattling.. There's probably other things you could use, but at the time it's all I could find and it heavy tape like you use for moving boxes and it's clear so you can't tell it's on there if you get outside your line a little bit.. Anyway it worked and my truck is A LOT quiter now.. It still rides like a lumber wagon and there's some other rattles, but the major rattling in the doors is gone.. Good luck.
deer123 is offline   Reply With Quote
Old 10-21-2009, 10:26 PM   #7 (permalink)
I forgot to mention that all my doors have Dynamat installed. I had it put in when the system was installed. So it's just the door locks on my rig that rattle.
IAFF Local 1159
Old 11-19-2009, 07:53 PM   #8 (permalink)
I have an 08 3/4 2wd. The front drivers door rattles like crazy! pass door a little. I'm not even going to waste my time bringing it in to the dealer, they couldn't even get the front end align. right.! Mine doesn't do it that bad if I crack the window too. Kevin.
08 2wd longbed. 6.7 with gutted dpf,downpipe, and cat. Egr blocked. edge juice w/attitude w Hot unlock . 6spd. No muffler. Intake baffle removed. Hogged out factory intake horn. No heat grid.
dr.olds4554 is offline   Reply With Quote
Old 11-20-2009, 11:58 AM   #9 (permalink)
czecher's Avatar
this is nuts, i just thought it was my truck! my front passenger door rattles like crazy. i kept thinking there was a flashlight or something rolling around in the little storage slot and always told myself i would check it out when i stopped but always forgot....then i finally looked and there was seriously nothing in there. then i thought maybe it just wasnt closed well, but it was.
6.7l lonestar edition 2500 LWB-- inferno red. stock engine for now, 2.5" HBS leveling kit, 17x9 black rock type 8, dick cepek mud country 35x12.50r17
czecher is offline   Reply With Quote
Old 11-20-2009, 12:38 PM   #10 (permalink)
I put some 6x9 speakers in the doors that are a lot heavier than the stock ones. The dealer will use that against me although it did it before. The speakers did make it worse though. Look at the top of the door at the glass squeegee when the window goes up(electric). The door flexes like crazy. The sheetmetal is very flimsy. I'm going to pull the panels back off and see if I can put something aroung the panels.
Old 11-20-2009, 12:48 PM   #11 (permalink)
ZDiesel's Avatar
uh, there's 1.5inch knob up on the dash just to the right of the steering wheel. if the stereo is on just turn the knob to the right/clockwise until the rattling goes away. j/k
2008 BLK 2500 Quad 4x4 SLT, 6.7L, Auto, 2in Leveling Kit, 325/70R17 Toyo ATs
ZDiesel is offline   Reply With Quote
Old 11-20-2009, 01:01 PM   #12 (permalink)
jason250r's Avatar
yeah, mine does it too, i have an '09, and i thought it was from some body damage that had to be repaired ,but the front driver and passenger door do it. this is ridiculous!
jason250r is offline   Reply With Quote
