Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7L Non-Powertrain
6.7L Non-Powertrain Discussion of Accessories, Interior, everything not power related...NO ADVERTISING
Old 09-20-2009, 11:54 PM   #13 (permalink)
07 MegaCummins
Skyd Ram's Avatar
A level kit on top of your 5" kit will just make it ride worse and sit nose high. It will pull the front axle back which will increase the tire rub on the back of the fender. A 3" body lift is the more economical choice as far as parts go but are very labor intensive on our trucks. You would need about 10" of total lift to clear those 40's correctly so adding another 5" of suspension would also be very costly. The best thing may be to drop down to 37's and sell the 40's.
It all depends on how much more you are willing to spend on this project and if you plan to do any towing with the truck.
Your 3rd Gen source for products from:
Carli/Bilstein/Pure Performance/RIZE/Lightforce
BMF Wheels/Edge/SMARTY/Snow Performance/MBRP
AFE/Randy Ellis Designs/H&S/Dynatrac/Shibby Engineering
Addictive Desert Designs/S&B
888-886-2480
Skyd Ram is offline   Reply With Quote
Old 09-21-2009, 06:25 AM   #14 (permalink)
6.7 = lil bit of heaven
aaronesq's Avatar
sweet setup man.....as for fixing the problem I have a few suggestions....
I assume you've got aftermarket control arms to perfectly center the tires in the wheelwell? if not, I think they'd help..... Lorenz Industries makes them, and Don Thuren could make a set to the specs you need.
As for the front meats I think the perfect compliment to the unique look you've got going would be a pair of Glassworks Unlimited front fenders.
2006 to 2009 Dodge Ram Front Fenders. 4" flare 2" rise
IMO it's a better look compared to massive painted flares. They're not a ton more expensive and would give a unique, but really functional look.
finally just shim the front bumper & valance out an inch or so to clear the tires turning radius.
I might be all wet about that fixing your problem..... but it's an idea. And yes I second Skin....we need better pics
your setup makes me want to fit 40's on my 3in lift.....sheetmetal be damned!
'07.5 3500 SLT 6.7L G56 QC LB, Airaid CAI, PMT-1017g, T&CDiesel Fuel Rail, 5" TBE, DIY DPF/EGR/Cooler Delete, Lorenz 2.25 Suspension, Rollin on Stockers
aaronesq is offline   Reply With Quote
Old 09-21-2009, 10:03 AM   #15 (permalink)
Thanks guys !
Gonna check into the Fender Replacements.
the 2in rise and 4in flare may offset the rear stock dually flares and look good.
Good friend owns a Paint shop.
Will get more pics today for you guys.
Thanks for all the suggestions and ideas.
LNS-Vince is offline   Reply With Quote
Old 09-21-2009, 11:12 AM   #16 (permalink)
cleonard's Avatar
well vince looks like your in a situation if i were you i would ditch the 5" and go with a 8". only reason i say is because you really need a 6" to run 37's. and by the way truck looks sick. as stated abve you could probobally make 37's work with that lift, also looks like your wheels have a lot of backspacing. maybe try going with a lil narrower tire.
07.5 RAM 2500, EGR delete, DPF delete, 35's on 20's, SMARTY, extreme power puck
back to the good ole XRT
COLE
cleonard is offline   Reply With Quote
Old 09-21-2009, 02:17 PM   #17 (permalink)
Cummins Crazy
Cummins6speed's Avatar
Get some better pictures of where it rubs! I am not sure that fiberglass fenders will help at all but they would look cool
My truck: 06 5.9 G56 4x4 Quad Cab Short Bed Patriot Blue. Smarty TNT, Valair 3600DD, DiPricol's, Home made intake w/ amsoil filter, Straight Piped w/ 7" tip, silencer ring MIA, glove box sticker MIA 2/28/09-470hp/980tq
IBEW 551-PACIFIC COAST DIESEL
Cummins6speed is offline   Reply With Quote
Old 09-21-2009, 02:29 PM   #18 (permalink)
Diesel Junkie
Taquache's Avatar
I think the fenders would help a bit, they are designed to clear larger tires with less lift, and I x2 the need for more pics!
2007 FIAT 5.9L 2WD QC SB ELECTRIC BLUE Leather, Heated Seats, Sun Roof w/1st Republic of Texas Flag cover,BULLY DOG TRIPLE DOG Tinted Tailights {REMOVED: Intake Baffle, Silencer Ring, Badges, Kitty} <INSTALLED: Glass Pack, ICEBOX, 2" Drop Shackles, CFM+, custom stock grill, Dipricols, 6" Tip, GHD, Fiat Badging, AIR HORNS, custom interior, eyelids> 1/4: 15.2 @ 93.4 10-3-09 powered by Smarty
'80 Chevy Short Wide needs motor and trans. I'm long as an ant and tall as a snake
Taquache is offline   Reply With Quote
Old 09-21-2009, 02:36 PM   #19 (permalink)
Cummins Crazy
He will have more room to go up but it wont make much more room at the bottom rear of the fender and it certainly wont help it clear the bumper.
I think we need some more pictures to determine what he needs
Old 09-21-2009, 10:35 PM   #20 (permalink)
Im thinking im gonna order the front fenders to try and match the rear stock dually fenders for the overall looks category.
and then do a body lift for clearance ?
The huge tires look good.
Cant send them back.
Old 09-21-2009, 10:37 PM   #21 (permalink)
Old 09-21-2009, 10:56 PM   #22 (permalink)
bthanks's Avatar
How bad does it rub? Could you get away with trimming the fenders back? Thats what I had to do for mine but mine are just 35X13.50's with a leveling kit and 5 inches of backspacing...
2008 qcsb, southbend DD,airdog II,smarty,arson jr,afe mega cannon, SB66, boost tube, 5" tbe, BDS longarm 6" lift, helo maxx 8's w/35X13.50's
http://www.youtube.com/watch?v=tAkfRYekA-0- 6.7 Smoke switch
http://www.youtube.com/watch?v=a-6pZYH9pGY- Burn out!!!
www.rollinsmokediesel.com <--- Look For Black Ops Diesel!!
bthanks is offline   Reply With Quote
Old 09-22-2009, 03:21 AM   #23 (permalink)
AUTOBOX TRANSFORM!!!
SkinInc69's Avatar
Dumb question but did you take the front wheel daully spacers off? If not then you should for more clearance.
2007.5, 6.7L 2500 4x4 LARAMIE 68RFE- H&S Performance BLACK MAXX, Industrial Injection Stage 2 CP3, FASS 150/150, H&S 5" TBE straight piped, Snow Performance water methanol injection, Capped fuel rail, EGR & Cooler delete, AFE Mega Cannon, Black Op's Diesel intake horn, 3.5" Shibby boost tube, DiPricol Gauges, 3" BDS lift, Bushwacker flares, 20x12 iON-Forged Terminators, 33x12.5 Nitto Mud Grapplers, RDX Billet Grill, Line X, 20% Tint w/ 9" brow, 10,000K HID Hi/Low, Fogs. www.hsperformance.com
Old 09-22-2009, 08:38 AM   #24 (permalink)
DRT086.7's Avatar
Originally Posted by Brentc View Post
Last i checked leveling kits are cheaper then body lift's, plus if your going to be paying someone to do either one im sure the labor will be a bit cheaper putting on the leveling kit Vs. a body lift
Example
Leveling Kit- Dodge Ram 1500 2500 3500 2" Leveling Kit 1994-2008 2WD:eBay Motors (item 370246105555 end time Oct-15-09 05:00:00 PDT)
3" Body Lift- 07-09 Dodge Ram 2500 3500 Cummins Diesel 3" Body Lift :eBay Motors (item 300299742266 end time Oct-07-09 08:06:56 PDT)
Yeah i see what youre saying I was just answering the question asked. He will probally need both.
08 6.7 6-spd man Quadcab 4x4 EGR all gone, Shibby Grid Heater+Stage 1 Intake horn, 5" SS TBE, AFE intake tube, Airaid, Edge, Diablo EPP, Pure Performance 4", SBC DD 3600, 35/12.50x18s on Jesse James Lawless8's, Recon cab lights 487hp/972tq
DRT086.7 is offline   Reply With Quote
