Go Back   Dodge Cummins Diesel Forum > 07.5 and Up 6.7 Liter Cummins > 6.7L Non-Powertrain
6.7L Non-Powertrain Discussion of Accessories, Interior, everything not power related...NO ADVERTISING
Old 09-12-2009, 11:29 PM   #13 (permalink)
wrench04's Avatar
Originally Posted by king nothing View Post
This is THE difinitive thread about a dodge quad cab stereo install. Check out his amp mounting solutions. He Used the area behind the rear seats and kept the vents uncovered
Dodge Ram install thread - DIY Mobile Audio
Thats a little overkill if you ask me... Most people are just looking to upgrade the sound system not rebuild and customize the entire interior of the truck.
There are some good ideas in there but I dont have either the time or material to customize it all. I just want to fit the basics into what little space we are delt with.
As for the Cap, I still believe it is a must with any large amp draws, that is unless you like your lights dimming every time your bass hits.
08 3500 6.7L, 6" Fabtech Lift, 37" Toyo M/Ts, CAI, 5" SS TBE, all deletes, Edge Race Juice w/a, Fleece, MP-8, Looking to trade Edge Race for Xrt...
wrench04 is offline   Reply With Quote
Old 09-12-2009, 11:31 PM   #14 (permalink)
wrench04's Avatar
It was a tight fit, but the rear speaker cross overs fit under the door panels. The fronts arn't so lucky and will be going under the dash on either side...
Old 09-13-2009, 12:39 AM   #15 (permalink)
it IS a car audio site. I basically wanted to show you that your amps can go on the back wall. They will fit. We will have to agree to disagree on the cap I suppose. use it if you want to, But its just a bandaid for an inadequate electrical system. I have Memphis Belle amps in both my mustang and my Cummins with NO dimming. 1400wrms in each vehicle
king nothing is offline   Reply With Quote
Old 09-13-2009, 09:12 AM   #16 (permalink)
Motelcambodia's Avatar
I am going to be installing a dual sub box, 2 amps, a capacitor, 4 sets of component speakers, and a 10 disk MP3 changer.
I was thinking of putting the changer under the drivers seat and was not quite sure where to install the amps, capacitor, and component boxes.
I was thinking behind the rear seat but not sure if theres enough room. Does anyone have any advise on the best locations to hide all this stuff?
I was told that CD's are not going to be used any more In high end radios any more. They made it sound like CD's are going out like cesset tape and 8 track and every one just uses a I pod .
I would just put every thing on a I pod type player. And forget the Changer.
08 Mega 3500 4x4 ,auto, 3.73, 09 remote start,maXbrake controler,43' X102" 19k toy hauler
North Idaho or Cambodiahttp://www.youtube.com/MotelCambodia
Motelcambodia is offline   Reply With Quote
Old 09-13-2009, 12:12 PM   #17 (permalink)
wrench04's Avatar
A cap is just a stored researve of energy for high amp draws. Is there a better way to fix the problem without using a cap?
Deep cycle batteries may help to an extent...
Old 09-13-2009, 02:35 PM   #18 (permalink)
Larger wiring, bigger alternator. really shouldnt need either on a cummins rig
Old 09-16-2009, 11:06 AM   #19 (permalink)
wrench04's Avatar
I mounted the amps on the back wall with self tapping screws. I was thinking after that this was not a good idea as I live in Northern Canada and there is alot of salt on the roads in the winter. I exposed the metal and invited in rust. Any suggestions of what to do about this issue would be great. There is not much room between the box and cab, I was thinking of unbolting the box to get to the back where the screws came through and sealing them somehow...
Old 09-17-2009, 08:11 AM   #20 (permalink)
probably a good idea. thats what I would do
Old 09-17-2009, 11:12 AM   #21 (permalink)
Sealing the screws is a good idea. When I did mine I epoxied a board to the back of the cab wall, then screwed my amp rack into that. The amp rack weighed well over 100#'s and hasn't budged.
slaterbj is offline   Reply With Quote
Old 09-17-2009, 11:56 AM   #22 (permalink)
You use a cap in a passenger car cause theres not alot of reserve power...
The best ways to fix the problem without using a cap are to put in larger alternator, or a 2nd battery, or better wiring...oh wait, we already have those....
08 2500 MC CTD Laramie 4x4: 5"TBE, Banks RamAir/Technicooler, Shibby Horn, XRT, EGR/Cooler Delete, BriteBox Lights, MagHytec Diff/Tranny pans, Amsoil Synthetics & Dual Bypass Filter, Carli Dominator 3.0 w/ Toyo MT 35x12.5R17
Fmt662 is offline   Reply With Quote
