Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7L Non-Powertrain
6.7L Non-Powertrain Discussion of Accessories, Interior, everything not power related...NO ADVERTISING
Old 10-31-2009, 06:23 AM   #85 (permalink)
B-rock's Avatar
I installed the bosh/tyco relay as described. Works great! now im looking forward to installing my factory remote start.
'08 6.7L 4 door 4x4 LB. Mineral gray. Lorenz bilstein leveling kit with DP leafs. SRT hood.
5" TBE, EGR & cooler delete, Edge w/ATT, CAI, Airdog 150, Frants oil filter. Smarty S-67ME 120HP fireball injectors.ARP 425 studs to 135#, II 64/71 Stage 2 VGT Turbo
B-rock is offline   Reply With Quote
Old 11-05-2009, 03:59 PM   #86 (permalink)
Help please.
I have the relay, wires and connectors. I went to Radio Shack and the closest they stock are 10 ohm. Would that work?
I live in a town of 5k, glad just to have a radio shack, but it is small.
Not sure if the resistor is to show some small load or if it is to reduce the voltage that is seen.
If 10 ohm won't work,
IIRC, resistance in series adds, but is there a way to divide it? I was thinking 2 in parallel and one in series.....but don't remember what happens when you put resistors in parallel.
2007.5 2500 mega cab 2wd auto budget dpf and egr delete, downpipe gutted, and egr blocked w/ butterfly removed.
a1953mdl is offline   Reply With Quote
Old 11-05-2009, 04:11 PM   #87 (permalink)
Originally Posted by a1953mdl View Post
Help please.
2 10ohm resistors in parallel is 1 5ohm resistor. For 15ohms put 1 in series with a parallel pair.
08 2500 MC CTD Laramie 4x4: 5"TBE, Banks RamAir/Technicooler, Shibby Horn, XRT, EGR/Cooler Delete, BriteBox Lights, MagHytec Diff/Tranny pans, Amsoil Synthetics & Dual Bypass Filter, Carli Dominator 3.0 w/ Toyo MT 35x12.5R17
Fmt662 is offline   Reply With Quote
Old 11-05-2009, 04:13 PM   #88 (permalink)
Thanks a bunch. That was what I was thinking, but it is foggy in the depths of my mind. lol
Lee
Old 11-05-2009, 04:31 PM   #89 (permalink)
CF Chapter President
scrappy's Avatar
Lee
if you don't mind waiting a little bit, send me your address and I'll send you one.
361hp/677tq. 20090220 2007.5 2500 QC/SB, ETJ/DG7, Silver, SLT Thunderroad, 3.73's, 37.5 13.5r20 Pcomp extreme A/T's, KMC XD 766 "Diesel" wheels, 6" fabtech lift, AFE Stg.2 Megacannon, Bullydog Power Pup. '05 tail lights
Gone!457hp/1002tq. 2003.5, 3500SRW, qc/lb
scrappy is offline   Reply With Quote
Old 11-11-2009, 05:06 AM   #90 (permalink)
tfilson's Avatar
Wow great maybe someone can market a kit?
2009 2500 HD Q/C 6.7
tfilson is offline   Reply With Quote
Old 11-12-2009, 02:03 PM   #91 (permalink)
US Army June 78-June 06
wildman4x4nut's Avatar
I just did this mod. There isn't a need for a kit. Just go to Radio Shack and buy the parts. If they don't have them order them and be done with it. The directions are right here and believe me YOU can do it.
Get the relay and the resistor and go for it.
WILDMAN
Cle Elum, WA wildman@4x4nut.com www.4x4nut.com 2008 Mega Cab, 6sp Man, H&S XRT, Edge Insight, True Flow XDI, Diablo Sport EPP, 5" TBE,
EGR & Cooler delete,Quadzilla Boost fooler, Fast Canuck Air Horn
No DPF/EGR/EGR Cooler/Butterfly Valve/Servo 03/07/09!!! Yep it's All GONE!!
wildman4x4nut is offline   Reply With Quote
Old 11-12-2009, 02:27 PM   #92 (permalink)
lasilver's Avatar
for taking the time to post up this mod with pictures and how to accomplish it. .(I was putting it on everytime I started the truck to begin with) It is Soooooooo nice now when I leave in the truck for the switch to actaviated allready.
2007.5, 2500,2WD, 6.7L, 6-Spd Automatic 68RFE, 3.73 Axle gears, Intake tube gutted, 2" shackle drop
http://www.bslca.com/
lasilver is offline   Reply With Quote
Old 11-12-2009, 04:20 PM   #93 (permalink)
Rockwerx's Avatar
Has anyone tried this mod to activate not only the ebrake on startup but also the heated seats? Would you need an extra relay circut for each seat? So three relays or can you just split off of one relay? I was thinking that a summer/winter (on/off) switch for each seat would be a good idea also.
2008 3500 Laramie QC 4x4 LB DRW 6.7 CTD Auto LSD 3.73 EJA EPP 5" TBE AFE CAI -EGR 3.5" BOOST TUBE AirDog 150 RWX
Most wanted mods: Wild Card Customs Intake Horn,Twins
Rockwerx is offline   Reply With Quote
Old 11-13-2009, 04:09 AM   #94 (permalink)
bushhawg's Avatar
OMG!!! Thank goodness someone has figured this out!!! It is SO much trouble to reach down and push that button!! It is so much trouble I quit running my engine brake in hopes that someone would figure this out!!!! Happy day!! Happy Day!!!!
2007.5 DODGE RAM 3500. FOUR DOOR 4X4 6.7 CUMMINS. 6 SPEED MANUAL. LEVELING KIT. AFE INTAKE. XRT, 5 INCH TBE, AND QUAD BOOST FOOLER.
bushhawg is offline   Reply With Quote
Old 11-13-2009, 06:34 AM   #95 (permalink)
EL WYOMING PRESIDENTE'
Giddyup5.9's Avatar
Projects - CTD rail project: On Hold, 68 D-100 Reg/short that needs a CTD
06 MCLB: BDTD/MP8/DDP90'S/ARSONIII/H11'S/HE351-A5K/5S TC/BILLET TRANS/AD165/4.5LIFT/20'S/35'S - 676hp. Thanks: Eric(ATS), Shane(Wicked), Danny(FTD), Tim, The BD Guru, Kenny and Levi-->
"Keep smoking people out, one day an angy prius owner will do a VERY QUIET drive-by on you!"
Giddyup5.9 is offline   Reply With Quote
Old 11-13-2009, 08:45 AM   #96 (permalink)
wrench04's Avatar
If you have command starts this works great as the truck warms up faster with the brake on. You just have to press a button the the remote, truck starts with brake on and is good to go. You should always run with the brake on anyways, its better for the engine.
08 3500 6.7L, 6" Fabtech Lift, 37" Toyo M/Ts, CAI, 5" SS TBE, all deletes, Edge Race Juice w/a, Fleece, MP-8, Looking to trade Edge Race for Xrt...
wrench04 is offline   Reply With Quote
