Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7L Non-Powertrain
6.7L Non-Powertrain Discussion of Accessories, Interior, everything not power related...NO ADVERTISING
Old 02-23-2009, 07:25 PM   #25 (permalink)
VAautotech's Avatar
Originally Posted by 66jj View Post
ditto or how much$ for a easy to install pre wired deal?
what about the tow button can you do the same thing? I am allways towing and have to turn those two on.
Also want to leave my lights on too!!
havent looked at the tow button or the lights. Tow button shouldnt be difficult but the lights might be another story as the headlight switch is always flowing power throught a resistor even when the switch is off so the tipm know the switch is plugged in and working properly, if you unplug the switch the tipm will turn on the low beam headlamps everytime the truck is started, but this also sets a body control trouble code
2008 Dodge Ram 2500 Mega Cab, 4x4, nav, alpine headrest monitors, Clarion DVD, Line-Xtra, deletes up soon.......
VAautotech is offline   Reply With Quote
Old 02-23-2009, 07:28 PM   #26 (permalink)
VAautotech's Avatar
oh and for a prewired deal, i will look and see how much these things costs and maybe a little plastic project box to mount everything in, and get back to you
Old 02-23-2009, 07:30 PM   #27 (permalink)
08 Cummins
KhakiCummins's Avatar
Good work VAautotech!!!
2008 Ram 3500 SLT QuadCab LB SRW 4x4 6.7L G56 Light Khaki
DiPricol Optix(Pyro/Boost/Diff Temp), S67, SB 3250 DD, S&B CAI, Line-X, B&W Turnover Ball, ProTech, PacBrake Air Springs, HBS 2" leveling kit, MagHytec Rear, Willmore Wheel-to-Wheels, Condensor Guard, Jacobs EB switch
KhakiCummins is offline   Reply With Quote
Old 03-04-2009, 12:21 AM   #28 (permalink)
do u need the capacitor or will it work with a smaller one ? i cant find 30000uf cap anywhere not even a 10000uf one
colin_467 is offline   Reply With Quote
Old 03-04-2009, 06:45 AM   #29 (permalink)
I just bought an 09 3500 to replace my 01 2500 so I might not be all that up to speed on the new ones yet, but it seems that I have read several posts here and on other forums that the C&C's are programed to retain their last setting of the EB. This leads me to believe that there might be a dealer "flash" that would give this option without any rewiring at all.
When I take it back to the dealer later this month for an unrelated issue I will ask if this is an option and report back unless someone has allready done this.
mrfeeney is offline   Reply With Quote
Old 03-04-2009, 09:04 PM   #30 (permalink)
Good Work Vaautotech !!! Could someone give me a hint to remove the switch black bezel ???
'08 2500, 6.7l, Electric Blue, 68RFE, 4X4, SLT, Big Horn Edition, QC, Unplugged EGR, Edge Juice with Attitude, AEM Brute Force HD, Air Horn Home Made setup with 2gal. tank, Automatic EB Switch
Amik is offline   Reply With Quote
Old 03-04-2009, 09:34 PM   #31 (permalink)
VAautotech's Avatar
Parts Express:10000uF 16V Axial Mini Electrolytic Capacitor
these are the ones i used, just tied the ends together making sure to keep the polarity the dame on all, sorry i havent been able to get pics up yet, been really busy the exhaust brake switch comes out through the back of the bezel, you have to pull the bezel off first, just like your trying to get to the radio, i didnt tap the wires or anything, just shoved my wires into the back of the connector on the eb switch. Works fine because its low voltage. Will do my best to get more info/pics up by the weekend....
Old 03-08-2009, 07:39 PM   #32 (permalink)
Ok guys, I did some work on the truck today since it was sunny and not to cold.
I used a small dc relay that we use in access control. It has a 6VDC to 24VDC input and 2 sets of NO and NC Contacts. So I used the power of the cigar lighter to power the relay and the NO contact to switch the EB. When you start the truck, the cigar lighter is NOT powered during the startup and cause the relay to make contact on the Common and NO. It makes the pulse you need to put the EB ''on''. I used a 15 ohm resistance in serie with the NO contact. And Voilą !!! The EB is On when you start the truck.
I hope everything is understandable....
I'LL post some pics tonight...
Old 03-08-2009, 08:15 PM   #33 (permalink)
Old 03-09-2009, 02:21 PM   #34 (permalink)
66jj's Avatar
either way anyone can help me do this I would be gratefull. all the stuff you two are talking about above is like chinese to me.
Thanks Jeff
pm me if you come up with something. the pics look like 4 wires hooked to the switch I assume you undid the oem ones? and the chinese stuff you talk about is inline with those wires?
I build and wire my race cars but Im no electrician etc.
I would really like the trans tow button on all the time also, or either just on a toggle on the dash.
the daytime run light kits they sell for canada I think will work for my head light needs I looked that stuff up once online but it seemed like most were only a percentage of the lights on.
Thanks Jeff
08 6.7 4x4 Dually Crew always towing. 5"ss turbo back, PMT gauge, Smarty. AFE intake, mp-8, Wing master wing, 90 gal. auxilary tank/tool box,fire stone bags in back, on board air comp. Card custom intake horn and 3.5 tube! Air Dog 150
66jj is offline   Reply With Quote
Old 03-09-2009, 05:47 PM   #35 (permalink)
Jeff,
no prob. man, I'll help you. Give me a few hours and I will post you some pics and will give info on where you can get the small relay.
Just for you to understand. The relay goes in parallel of the EB dash switch so you can control manually the EB. The switch of the EB is not just a regular temporary switch it has a built in resistor to give the ECM ( truck computer ) a definite amount of Voltage. It need's a pulse to work: so only a impulse of voltage and 0 Volt after. If you understand how the system works will be easier for you to work on it. Just ask me if you need more info.
Sebastien
Old 03-09-2009, 06:13 PM   #36 (permalink)
Hey Jeff,
Maybe I could come up with something for both EB and Tow/haul. I'll have to make some test... But I can tell you that the EB switch trick is working great !!!
