Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7L Non-Powertrain
6.7L Non-Powertrain Discussion of Accessories, Interior, everything not power related...NO ADVERTISING
Old 02-20-2009, 10:54 PM   #13 (permalink)
VAautotech's Avatar
oh and the resistor will flow a small amount of current until there is no mor current to flow......the drain does slow down as the voltage across the cap gets lower
2008 Dodge Ram 2500 Mega Cab, 4x4, nav, alpine headrest monitors, Clarion DVD, Line-Xtra, deletes up soon.......
VAautotech is offline   Reply With Quote
Old 02-20-2009, 11:32 PM   #14 (permalink)
WTB Black Maxx....
Sapling's Avatar
This would be sweet with my remote start!
Have you run it at all to see that it works well?
08 6.7....EGR gone, DPF???? DPF-R in its place, full SS TBE, Edge/Att Hot unlock, Power puck, Zilla Boost fooler! OEM remote start, High idle engaged, 9005 Silverstar Ultra fogs.....Need more fuel gauges, and an Airdog, Brite box to come!
Sapling is offline   Reply With Quote
Old 02-20-2009, 11:45 PM   #15 (permalink)
VAautotech's Avatar
i have it all hooked up now but was just testing/checking everything out in the garage. will be taking the truck in the morning so i will actually have some run time on it, but everything looks good so far
Old 02-20-2009, 11:54 PM   #16 (permalink)
Originally Posted by KodiakConstruction View Post
I think there is a time delay that it takes to turn off. I know if I turn the truck off and then start it back up quickly (within a minute) the brake will still be on.
No..... When ever I start the C&C the brake switch is on???
2007 3500, c&c single rear wheel. 2" HBS, Truck Craft Alumium Flat Bed Dump, MEYER 8.5 LOT PRO Plow,
2008 3500, 4X4, Black, Quad cab,
Plow Man is offline   Reply With Quote
Old 02-21-2009, 02:02 AM   #17 (permalink)
no the battery is unaffected because it is a switched power source that is hooked to the truck, so if the truck is off no power is applied to the relay
yeah! my bad. looked at the schematic again saw the ignition. my monitor at work is blurrrrrry. good work man! thanks.
07.5 6.7L Ram 2500 Cummins BigHorn Quad Cab, 4:10 axle, 6 spd auto, EGR, S&B, Edge/Att, MP8, Rize @ 37x20, Eclipse nav., Smarty, Thuren Fox SS, Amp Research Steps, MHP Modified tune, 8" Spirson rear leaf
tob_e is offline   Reply With Quote
Old 02-21-2009, 03:43 PM   #18 (permalink)
Silentbob76's Avatar
I know nothing about wiring! If this works would you still be able to turn it on/off with the EB switch?
2007.5 Dodge 2500 Big Horn Edition 4x4 Quad Cab powered by the 6.7 Cummins. Inferno Red. BADP 5" TBE with muffler, AFE Mega Cannon, Edge Juice with attitude, MP-8, Blocked EGR, and FASS-150
Silentbob76 is offline   Reply With Quote
Old 02-21-2009, 09:34 PM   #19 (permalink)
JUST LEARNING
Boogiex's Avatar
Sounds good, cant wait to see the results
07.5 3500 Mega Cab 4x4 DRW, 3:73 gearing, ATS 68RFE Tranny W/ ATS 5 Disc Torque Converter, TS MP-8, Fuel Rail Shimmed, Edge Att W/ Hot Unlock, FASS Fuel Pump, AFE Mega Cannon Air Intake, EGR Unpluged, Fleece Turbo Controller,BADP 5'' Stainless Turbo Back,Smarty S-67ME
08 2500 Quad Cab 4X4 SRW, 3:73 gearing, G56 6 Speed, EGR Unplugged, PPE Xcelerator, Mp-8, AFE Mega Cannon Air Intake, BADP 5" Stainless Turbo Back
Boogiex is offline   Reply With Quote
Old 02-22-2009, 05:31 PM   #20 (permalink)
VAautotech's Avatar
ok, have run everything for a while now and everything seems good. bob, yeah u can still operate the switch like normal, only difference is it turns on automatically when you start the truck.
Old 02-22-2009, 07:05 PM   #21 (permalink)
bdavis466's Avatar
So for those of us that don't understand the wiring diagram, how do you do it and how hard is it?
2008 3500 Crew Cab long bed, 8" lift with 37" Toyo M/T, XRT with a $2000 BADP exhaust pipe
bdavis466 is offline   Reply With Quote
Old 02-23-2009, 12:16 AM   #22 (permalink)
B-rock's Avatar
subscribed!
'08 6.7L 4 door 4x4 LB. Mineral gray. Lorenz bilstein leveling kit with DP leafs. SRT hood.
5" TBE, EGR & cooler delete, Edge w/ATT, CAI, Airdog 150, Frants oil filter. Smarty S-67ME 120HP fireball injectors.ARP 425 studs to 135#, II 64/71 Stage 2 VGT Turbo
B-rock is offline   Reply With Quote
Old 02-23-2009, 10:56 AM   #23 (permalink)
66jj's Avatar
ditto or how much$ for a easy to install pre wired deal?
what about the tow button can you do the same thing? I am allways towing and have to turn those two on.
Also want to leave my lights on too!!
08 6.7 4x4 Dually Crew always towing. 5"ss turbo back, PMT gauge, Smarty. AFE intake, mp-8, Wing master wing, 90 gal. auxilary tank/tool box,fire stone bags in back, on board air comp. Card custom intake horn and 3.5 tube! Air Dog 150
66jj is offline   Reply With Quote
Old 02-23-2009, 07:22 PM   #24 (permalink)
VAautotech's Avatar
ok well it does take a little time and some components to do but not really that bad, 1 standard automotive relay, i used three 10000uf capacitors (thats microfarads), 1 diode, 1 10K ohm resistor and a 10 ohm resistor. I will try to get some pics of everything up soon. you have to pull off the center bezel around the radio to access the exhaust switch. For switched power i just used the blower motor connection because it is easy to get to. you can ground it anywhere thats convenient. once again i will try to get pics up soon.
