Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7L Cab & Chassis
6.7L Cab & Chassis Discussion of performance, powertrain, and non-powertrain on Cab & Chassis Trucks.
Old 09-12-2009, 12:33 PM   #25 (permalink)
Jcard's Avatar
After running my 4.88 geared 5500 for 24,000 miles I am extremely skeptical of mileage reports over 13. I get 7-12, stock, with egr unplugged.
Jcard is offline   Reply With Quote
Old 09-12-2009, 01:07 PM   #26 (permalink)
Recovering Post Whore
HardcoreDiesel's Avatar
Post
If you look at the mods in my signature then you might see that it is possible to get better than "stock" milage with a 6.7L truck. My overhead reads 18.8 mpg and that ends up being 15.5 actual. You gotta do more than deletes to really increase the mileage with these.
HardcoreDiesel
2009 5500 C&C Laramie QC 6.7L 4X4 G-56 4:44's and ALL THE**B.S. DELETED @ ONLY 18 MILES** H&S XRT@175H.P., 5" Turbo Back Magnaflow Exhaust, Banks Intercooler & Tubes, AFE Stage II CAI, 3 Dipricol Guages, Accuride 19.5's & Valair 3800# SFI Billet/Bronze Insert DD Ceramic/Solid Hub/12 Button
HardcoreDiesel is offline   Reply With Quote
Old 09-12-2009, 03:29 PM   #27 (permalink)
My overhead reads 22 to 24 with cruise set on 70mph, but I am getting around 17.
I still can not see how he can be getting better than fuel mileage then me with having 4.88 gears and weighing almost 5-k more than I do unloaded. Hell my 2000 F-550 with 4.88's with tons of extras and a 6speed only get 14@65mph.
2007 Dodge Ram Quad Cab 3500 C/C, 6.7 Cummins, auto, 9'-4" CM Hauler bed, Frontier replacement bumper, XRT w/delete Kit, S&B INTAKE KIT! thanks to K2, H&S this truck is fun to drive now!
nostroker is offline   Reply With Quote
Old 09-16-2009, 12:25 AM   #28 (permalink)
Thanks for the info I ordered a MP-8 today. I also wanted to know if anybody knows why dodge put such a small intercooler on the 4500, would it be a good thing to upgrade to a stock 2500 or 3500. Thanks Dareld.
4500? is offline   Reply With Quote
Old 09-16-2009, 12:51 AM   #29 (permalink)
Post
They want the truck to run hot so the EGR & DPF function better. The pickups got the same intercooler as the C&C did in 09 so you need a older version or aftermarket to increase capacity.
HardcoreDiesel
Old 09-16-2009, 11:37 AM   #30 (permalink)
skirsman's Avatar
My goal with MPG is to put 20 MPG w/o wind and run 22.5 wheels.... the big issue is 4.88.. after 100km/h is not easy to keep it. I think the 4.88 are so low even in 30% mountain with nice load in the trailer... So if we have guy pulling 30k with 3500 3.73 ... SO buddies let get some $$$$$$ overpower those 6.7 with those big DANA.... and get 22.5 direct bolt...
SK
Ram 4500 08' CC STD 4.88's with 30'GN AFE intake stage 2, DPF delete. South Bend 3250. BD intercooler. Quad Boost fooler. Shibby EGR/cooler Delete. Airdog II woke up my hidden power. PMT I hate IT waiting for HS Black MAXX and $$$$ to buy it.
skirsman is offline   Reply With Quote
Old 09-16-2009, 06:14 PM   #31 (permalink)
So would 22.5 wheels make the 4.88's into 4.44's or 4.10's?
Joe
Joezilla is offline   Reply With Quote
Old 09-17-2009, 12:15 AM   #32 (permalink)
skirsman's Avatar
the 22.5 will make it 4.09 somthing
check here
Rickson Truck Wheels and Accessories
31" to 37"
Old 09-19-2009, 05:53 PM   #33 (permalink)
floridagc's Avatar
The best mileage is @ 62 mph no more no less thats the sweet spot in my truck.
floridagc
2008 2500 Sport 4x4
2008 4500 Utility Box
2008 5500 utility box
floridagc is offline   Reply With Quote
Old 09-20-2009, 10:09 PM   #34 (permalink)
Originally Posted by floridagc View Post
9 with the bed and tools, with just the c&c 3 it will beat your kidney's to death. I really like the truck except the steering its a little touchy and likes to wander if you keep correcting the steering(my 2500 does the same thing), I and my employees have learned to let the truck go were it wants in the lane.
I think that I will get rid of my 2500 4x4 sport and get a 4500 with a bed conversion, I am waiting until the speed limiter is corrected. I am going to remedy the weight problem by adding a 500-800 gallon custom flat tank in the truck bed.
flgc
I have the wander problem with my truck too, I understand lots of Dodges have this problem. A steering stabilizer bar is about the only way to fix it.
I'm surprised you have 4.88 on your 4500. If you had the 4.44 gears you might get 2mpg better...
2006 white quad cab Dodge dually, G56, True Flow XDI air filter system, FilterMag, am/fm/cd/sirius, Fluidampr, LineX bedliner, 3.73, gooseneck hitch, Mag-Hytec rear diff cover, rear bags w/ in-cab controls, P235/80R17 Michelin LTX M&S on stock wheels
Moparman is offline   Reply With Quote
Old 10-04-2009, 12:23 PM   #35 (permalink)
djdc's Avatar
I'm running a 07 3500, G56, QCab.
I'm thinking of trading up to a 4500 with an auto.
Here's my question:
Those of you that have the 4500 or 5500 with the auto.
1) What gears do you have.
2) Whats your RPM say at 65 MPH.
3) When you are loaded ( pulling a trailer) do you just shift into DRIVE or O/D and go, or do you have to drive in a lower gear.
2007 DRW, QC, G56, 50 gal ATTA AUX Tank, Banks Cold Air, AMSOIL in everything, Dual Remote Bypass System, B&W Turnover Ball, Longhorn 40' GN, 24K
Stand Back, somethings gonna break.
djdc is offline   Reply With Quote
Old 10-05-2009, 02:47 AM   #36 (permalink)
G56 w 4.44s knocking out 14-14.4 MPG empty with the truck weighing just under 10K lbs empty. Only basic deletes. I have the good stuff waiting for install and hoping to get just under 20MPG running empty. Lots of toys in waiting for install when the engine finishs the break in period.
08 5500 4x4 G56 4.44s In the works. SB 3250 dual disc, aux trans, XRT
95 2500 4x4 G56 913 pump, injectors and more....
burnin oil is offline   Reply With Quote
