Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7L Cab & Chassis
6.7L Cab & Chassis Discussion of performance, powertrain, and non-powertrain on Cab & Chassis Trucks.
Old 10-23-2009, 09:47 AM   #1 (permalink)
F-650 with cummins
does any one know the differences between the 6.7cummins offered in the ford f-650 and the dodge ram?
deadpool is offline   Reply With Quote
Old 10-23-2009, 09:58 AM   #2 (permalink)
Shibbyutman's Avatar
Bigger turbo . It runs the 431VE as opposed to the 351VE on our trucks. They have a way different fuel map in them as well, I think they only make something like 260 HP but 620 ft/lbs of torque. I've been wondering if the manifold off that truck will bolt up to ours without any engine compartment clearance issues. I do know the controllers communicate on the 431 when you plug it into a dodge.
2003 Dodge Ram 2500 4X4, PDR Cobra Stage 2 Twins, BD Power 90's, Studs, Springs, Autometers, Dual 7" Black Stacks/rain caps, Banks intercooler, Goerend Full Built Trans, Smarty set to Kill, MP-8, Full DIY CP3 Mod, Rail capped , FASS 150/150, and big line kit.
Shibbyutman is offline   Reply With Quote
The Following 3 Users Say Thank You to Shibbyutman For This Useful Post:
cmns2500 (10-23-2009), fast fras (10-27-2009), skirsman (10-23-2009)
Old 10-23-2009, 10:09 AM   #3 (permalink)
i think they make 325hp and 750tq? i wonder the price range for an f650, more towing capacity, beefier susp for a cheaper price than a well equiped 5500?? do these trucks have the egr crap and dpf?
Old 10-23-2009, 10:12 AM   #4 (permalink)
Yeah sorry, wrong HP numbers there, you're closer. I think they have a similar combo NOC/CAT/DPF unit that the C&C trucks get.
Old 10-23-2009, 10:13 AM   #5 (permalink)
Tom Diesel's Avatar
Originally Posted by Shibbyutman View Post
425 ft/lbs of torque.
Impressive!!!
07 6.7l 2500 Mega 4X4 auto, 3.73, EAGLE 114 CHROME, 305/55/20 Nitto A/T, De-badged, SMARTY, Volant PowerCore, 5" Magna Flow TBE, V-TEC
Tom Diesel is offline   Reply With Quote
Old 10-23-2009, 10:15 AM   #6 (permalink)
Originally Posted by Tom Diesel View Post
Impressive!!!
yeah, sorry, typo, lookin at the wrong truck how about this 260 and 620
Old 10-23-2009, 10:25 AM   #7 (permalink)
thats a 750 though , strange im seeing all kinds of different power numbers i wondor how much that thing can legally tow?
Old 10-23-2009, 10:30 AM   #8 (permalink)
https://www.fleet.ford.com/showroom/...specs.asp?EV=0
F650 base is only 200 and 520, LOL. Impressive! as Tom put it. My truck in 03 made better numbers than that, I think even the SO motor did.
Old 10-23-2009, 10:39 AM   #9 (permalink)
Ford F650 Hauler Cummins - Aquasun Motorsports
i found a link theres an apparent difference between the 07 and 08+ power output
Old 10-23-2009, 10:40 AM   #10 (permalink)
Tom Diesel's Avatar
So whats the deal with the bigger turbo if it's a lower output engine?
Old 10-23-2009, 10:44 AM   #11 (permalink)
i guess ur refering to the isb260 the isb325 gives out 325-750... 26000 towing capacity?? i wonder if this is cheaper or same price as a ram 5500
Old 10-23-2009, 10:44 AM   #12 (permalink)
It's all in the fuel map and efficiency range. The 431 will spool a lot quicker at lower RPM which the ford models are tuned for. It has the capability for a higher mass rate because the impeller geometry is different as well. The inducer is pretty close to the same size but I think the exducer is larger.
