Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7L Cab & Chassis
6.7L Cab & Chassis Discussion of performance, powertrain, and non-powertrain on Cab & Chassis Trucks.
Old 10-26-2009, 09:48 AM   #25 (permalink)
Shibbyutman's Avatar
I'm pretty sure the Mercedes Benz OM603 is, I personally have had one with over 250K miles on it 1987 model year 300D
2003 Dodge Ram 2500 4X4, PDR Cobra Stage 2 Twins, BD Power 90's, Studs, Springs, Autometers, Dual 7" Black Stacks/rain caps, Banks intercooler, Goerend Full Built Trans, Smarty set to Kill, MP-8, Full DIY CP3 Mod, Rail capped , FASS 150/150, and big line kit.
Shibbyutman is offline   Reply With Quote
The Following User Says Thank You to Shibbyutman For This Useful Post:
fast fras (10-26-2009)
Old 10-26-2009, 09:59 AM   #26 (permalink)
Originally Posted by fast fras View Post
I applaud the effort but it’s a scary thought using aluminum heads on a high compression engine. But I wonder if there has been a diesel with aluminum heads before?
come to think of it i dont think there gonna handle well under a hot tune or constant everyday towing/idle. but i guess from every car corp perspective how would u be Able to make money if u built million mile motors?
deadpool is offline   Reply With Quote
Old 10-26-2009, 10:19 AM   #27 (permalink)
fast fras's Avatar
Ya, I’ll stick with the Cummins, unless Caterpillar starts putting engines in ¾ ton and 1 ton light trucks. I’m not including the F-fords 6 and 750’s they are greater then a ton.
fast fras is offline   Reply With Quote
Old 10-26-2009, 10:20 AM   #28 (permalink)
This was the problem with the mercedes. They ran like tanks all day in stock form, but as soon as you crimped the wastegate line for a little more power they'd crack heads like it was their job.....
Old 10-26-2009, 11:48 AM   #29 (permalink)
The new 4BT Cummins Prius
mattpopp's Avatar
But does anybody believe that Ford just rates the 6.7 at a different rpm to give the 260hp/620ftlbs. Like they are using the hp from the same rpm that they read the 620ftlbs from. Unlike how our engines hp is rated at this rpm when the torque is rated from another rpm? Not sure why you would do this but it could make sense why it is so low.
07 l 6.7 l .75 ton l MC l with stuff on it and a new head gasket
96 l 5.9 l .75 ton l EC l with not much on it
Be VERY skeptical of information you read on the internet.
mattpopp is offline   Reply With Quote
Old 10-26-2009, 02:56 PM   #30 (permalink)
Joshua Lee's Avatar
If I was gona buy a non-factory motor it sure wouldnt be this Cummins... Doesnt make any sence, buy the CAT and forget about it.. No bullchit DPF
'07 6.7L Cummins, 6 speed Manual, 5" TBE
Joshua Lee is offline   Reply With Quote
Old 10-26-2009, 03:25 PM   #31 (permalink)
fast fras's Avatar
Ya, but the EPA winninies would screw the one up, too.
Old 10-26-2009, 04:48 PM   #32 (permalink)
mattpopp's Avatar
How Dare you say that. Shame on you
Old 10-26-2009, 05:12 PM   #33 (permalink)
BOOOST's Avatar
The Cat doesn't have DPF?
No thanks, I'll take the cummins over the Cat! Cat has all but thrown in the towel on the 07+ trucks. IN our fleet, we have had more problems with Cat's than any of the other post 07 emissions tractors. Leader in MPG wars and reliability right now is a Cummins 525hp ISX in an 09 Pete 386 @ 7.3mpg!
08 6.7L MEGA 2500 SLT 4X4 68RFE l DIPRICOL OPTIX BOOST/PYRO/TRANS l KORE CHASE l FOX 2.0 RR l CARLI LINKS l CARLI RESEVOIR MOUNTS l TINTED l TS MP-8 l 5" TBE l EGR DELETE l TEKONSHA P3 l LINE-X l PE JACKRABBIT l AFE MEGA CANNON l SMARTY S67PoD l 285 TOYO MT l
BOOOST is online now   Reply With Quote
Old 10-26-2009, 09:13 PM   #34 (permalink)
Joshua Lee's Avatar
Havent had a lick of problems from ANY Cat we have ever ran.... I guess its a odds race but in my race Cummins isnt ahead but, Im not bashing them at all I love Cummins
Old 10-26-2009, 10:07 PM   #35 (permalink)
Not buying a cummins!? Thats a crime all by itself.
Cummin'Not Stokin' is offline   Reply With Quote
Old 10-26-2009, 10:12 PM   #36 (permalink)
mattpopp's Avatar
I think the only way you will see CAT engines after 2010 is going to be in the International trucks but that won't be a true CAT. Its going to be a hybrid of International and CAT. On the high way that is.
