| 6.7L Cab & Chassis Discussion of performance, powertrain, and non-powertrain on Cab & Chassis Trucks. |
#25 (permalink) |
They sell heatshrink in that size at harbor freight tools
07.5 Dodge Ram 3500HD SLT 6.7L,11/06 build,5/08 delivery,PMT,DPF & EGR fell off,G56,4.10 (3.73 soon),C&C,HBS,5000k HID Solutions lights & fogs,14,000 miles to date,35" M/T,22.5's soon,Dyno at 445hp/907tq
#26 (permalink) |
just fyi, the foolers on my H&S kit send about 1180 degrees to the ECM.
2008 2500 6.7L, G56, 4x4, quad cab, short bed - 5" Expandit TBE w/ muffler, S&B intake, Shibby EGR & cooler delete, Valair 12.25" ceramic dual disk, Smarty 67, EV2 EGT gauge. |
#27 (permalink) | |
IDAHO CHAPTER PRESIDENT
![]() Join Date: Jan 2008
-Nic - Idaho Oil Burners President Idaho Chapter 2009 3500 laramie mega cab electric blue, pmt as guages,xrt,mp8,5" tbe with 8" tip, egr (cooler) and dpf delete, afe stage 2, II stage 1 cp3 1996 12v sled puller "dominate this" |
#28 (permalink) |
I did all of this yesterday to my 2,300 mile, late 08 Dually. I am running the O2 sensor, no sim, and the resistors in the two temp probe plugs. Man, these 6.7s just don't have hardly any smoke. My old 90CTD was a terror as far as smoke. If these 6.7s only expel the little bit of smoke I have seen so far, then the DPF is just a waste of metal. I did get the soft codes, P242b P244a P0401 Nothing I'm concerned with. Yes, I did just only block off the EGR tube. The EGR tube was full of dust too. With a quick drive down the highway, the lie-ometer shows a 2 mpg increase. No, I didn't notice an power increase. |
#29 (permalink) |
For a good time- Smarty
![]() Join Date: Aug 2008
Has anybody found out the values of resistors used to fool the pressure sensor yet?
Tom 2008 Quad-Cab,LB, 2500, 6.7L, 4X4, White/Kaki, Big-Horn, 3.73 Auto, AS flash, K&N Air Filter, no baffle, Testing in progress- step 4, Stealth DPF, Smarty sw3 PMT gauges. Mag-Hytec Pan & Diff covers.Toms smarty Journal ....... DIY Deletes How-To Stealth is the WORD!
#31 (permalink) |
I have a question this post is removing the filter in the exhaust and rigging the sensors to make the engine computer to think it is still in place Am I right so far so I am a welder could I cut the pipe in a manor to which it would make it hard to see Then take out the filter and re-weld the original pipe back up so it looks like it was not touched Put back all the sensors and call it a day will this work can it be done what is the filter look like on the in side Just need so in put just bought a new 5500 sterling and wanted to know what to do to get the most fuel for the mile Thank you Bear |
#32 (permalink) |
How do you tell the o2 sensors from the ones you need to put the resistors accross? I have a dually. This is the first thread Ive seen on here that actually goes into detail with pics of whats what. Thanks.
08 6.7 4x4 Dually Crew always towing. 5"ss turbo back, PMT gauge, Smarty. AFE intake, mp-8, Wing master wing, 90 gal. auxilary tank/tool box,fire stone bags in back, on board air comp. Card custom intake horn and 3.5 tube! Air Dog 150 |
#34 (permalink) |
Why can't the O2 sensors (which are located on either side of the catalytic converter) be reinstalled in the straight pipe? Also, wouldn't the pressure sensors keep the ECM happy if reinstalled in a straight pipe? |
#35 (permalink) | |
#36 (permalink) |
Then how about installing the upstream "pre-DPF" pressure sensor in the straight pipe (where it will pickup exhaust pressure) and leaving the 2nd downstream sensor open to ambient? Should generate enough of a differential...
