| 6.7L Cab & Chassis Discussion of performance, powertrain, and non-powertrain on Cab & Chassis Trucks. |
#13 (permalink) |
![]() Join Date: Nov 2008
[/quote] I have no bungs or anything attached to this new exhaust. It's installed just as it would be on a 5.9L truck. QUOTE] are thier no o2 sensors on the 5500 c&c ? i was sure i saw them on a couple i spy'ed at the dealer ? nice work otherwise. get some dielectric spray to clean and help protect the connections youve had open . the metal on the resistor leads is raw and will oxidize within a week and start to give poor signal transmission . at the very least id find or make some pins that will slide into the factory female connector and solder the resistor to the pins , heat shrink that leaving the pins poking out , plug that into the connector and heatshrink the whole deal. get a coulple of good drive cycles on it before you close it up real good . and let us know how it goes.
07.5 6.7 hd w/ airaid , track ready. SOLD 19/03/09 . enjoy my friend. soon to be replacing the dodge just waiting on end of auction and demilitarization paperwork for--- and yes it will have a 6.7 so im not going anywere.
#14 (permalink) |
Recovering Post Whore
![]() Join Date: Oct 2007
I have no bungs or anything attached to this new exhaust. It's installed just as it would be on a 5.9L truck. QUOTE] are thier no o2 sensors on the 5500 c&c ? i was sure i saw them on a couple i spy'ed at the dealer ? nice work otherwise. get some dielectric spray to clean and help protect the connections youve had open . the metal on the resistor leads is raw and will oxidize within a week and start to give poor signal transmission . at the very least id find or make some pins that will slide into the factory female connector and solder the resistor to the pins , heat shrink that leaving the pins poking out , plug that into the connector and heatshrink the whole deal. get a coulple of good drive cycles on it before you close it up real good . and let us know how it goes.[/quote] My truck only has the two pressure tubes and three temp probes as seen in the photo at the start of the thread. Thanks for the ideas and advice on the pins & resistors. I will probably run to radio shack and try to find some matching pins today!!
HardcoreDiesel 2009 5500 C&C Laramie QC 6.7L 4X4 G-56 4:44's and ALL THE**B.S. DELETED @ ONLY 18 MILES** H&S XRT@175H.P., 5" Turbo Back Magnaflow Exhaust, Banks Intercooler & Tubes, AFE Stage II CAI, 3 Dipricol Guages, Accuride 19.5's & Valair 3800# SFI Billet/Bronze Insert DD Ceramic/Solid Hub/12 Button |
#15 (permalink) |
well im gonna have to look at what ive seen up here . wonder if they make em strap extra stuff on the ones goin up here or if i was on crack that day . iether way that just makes life easyier . this means i just have to find the flash you folks are running on the c&c and make it work on a grocery getter and we can say goodbye to all the foolers. eeexxxcccelent. ima tear this mofo wide open once UPS gets me some goodys. i wonder how much trouble im gonna get into . lol
#16 (permalink) |
Here are a few more pics of my DIY DPF delete.... Here is the cheap & fast way to install the resistors in the factory plugs..I simply cut one prong off the connectors and soldered the resistor between the two and it plugs right into the female plug on the trucks wire harness. These conectors are the same size as the factory male connector so they fit nice and snug. I still have no related codes to the DPF delete! ![]() [IMG] [/IMG][IMG] [/IMG]Then I filled the voids with dielectric grease and heat shrinked the whole plug to seal them off. [IMG] [/IMG]Here is all three plugs finished..... [IMG] [/IMG]
#17 (permalink) |
Very nice work.
08 6.7 6-spd man Quadcab 4x4 EGR all gone, Shibby Grid Heater+Stage 1 Intake horn, 5" SS TBE, AFE intake tube, Airaid, Edge, Diablo EPP, Pure Performance 4", SBC DD 3600, 35/12.50x18s on Jesse James Lawless8's, Recon cab lights 487hp/972tq |
#18 (permalink) |
![]() Join Date: Mar 2008
sorry i am lost, which resistors did you use? 1. - ohm? 2. - ohm? 3. - ohm? for the pyros, i am having trouble finding the right combo.
2007.5 6.7 megacab, H&S XRT, edge juice w/attitude HOT UNLOCKED,Quad boost fooler, s&b intake,"CUSTOM EXHAUST" w/MBRP tail pipe w/6" tip, 3" lift, cooper stt 35X12.50, 2 Kicker 12L7's, Kicker 1200.1, JVC-AVX710, 3 monitors, Kicker door speakers,PS2. Big thanks to K2, WATCHDOGS=Autometer & Isspro |
#19 (permalink) | |
#20 (permalink) |
What temp reading does the 470 resistor send to the ECM? Do you have a PMT or anything to check that? Just curious.
2008 2500 6.7L, G56, 4x4, quad cab, short bed - 5" Expandit TBE w/ muffler, S&B intake, Shibby EGR & cooler delete, Valair 12.25" ceramic dual disk, Smarty 67, EV2 EGT gauge. |
#21 (permalink) | |
1.5k restistor =715 degrees start temp 1k resistor = 825 degree start temp 680 resistor = 960 degree start temp 460 resistor = 1067 degree start temp
#22 (permalink) | |
#23 (permalink) |
i am curious as to how the resistor = temp numbers are being figured? the larger resistor i put in the quicker the cel came on and the edge would read ex temp to high bank one, I dont remember the p code.
2007.5 6.7 megacab, H&S XRT, edge juice w/attitude HOT UNLOCKED,Quad boost fooler, s&b intake,"CUSTOM EXHAUST" w/MBRP tail pipe w/6" tip, 3" lift, cooper stt 35X12.50, 2 Kicker 12L7's, Kicker 1200.1, JVC-AVX710, 3 monitors, Kicker door speakers,PS2. Big thanks to K2, WATCHDOGS=Autometer & Isspro Last edited by blacksmoke6.7 : 12-31-2008 at 02:24 PM. |
#24 (permalink) |
where did you find the heatshrink big enough to fit around the connectors.
