Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7 Liter General Discussion
6.7 Liter General Discussion General Chit Chat About the Future Cummins Diesel Nut Motorsports
Old 05-26-2009, 11:24 PM   #37 (permalink)
I talked to the service center at the dealership that I bought my truck from and they said that they do not have the technology to change the span and or percent range of the transmitter within the tire. What he did say was that if I buy a tire with the same load rating, in most cases "E", that the rated tire pressure will be the same. The key is that you place the transmitter in the exact same place. I dont know for sure but the 35" toyo mud terrain that I like is definitely a 10 ply with the E load rating. Am I to assume that the rated max pressure is 80psi. If it is then there should be no problem getting to the same pressure as the stock tires thereby satisfying the TPMS right?
Walt70 is offline   Reply With Quote
Old 06-07-2009, 06:32 PM   #38 (permalink)
yes they can. they just dont want to look for it in the star scan. had them do that with my cousin's truck when i put on bigger tires for him. i sat and looked through every option with the tech and found it for him when he looked passed it. and the guy you talked to is wrong. just because it is a load range E does not mean that it is 80 psi. those that are 80 psi are labled E1 in reallity. E2 is 65. D1 is 65. D2 is 50 ect but yes if its E1 then you can satisfy the TPMS
MINE:2003 3500 cummins SO,auto 4x4 QCLB,4"MPRB,edge ez,Smarty POD,AirDog 100,75 horse Jammer injectors(gone),Goerend TC,VB,Input,Suncoast clutches/steels
DADS:2008,2500 SLT 68rfe 4X4 QCSB,BONE STOCK
'91cummins6gun is offline   Reply With Quote
Old 06-07-2009, 10:00 PM   #39 (permalink)
It is most certainly possible with the StarScan. BADP Trucks changed my tires pressure limits to 50psi, to satisfy my D rated BFGs.
2008, 4x4, QC, LB, Manual Tranny, AO Flash, 315 H2's, A-pillar triple guages, Air Raid intake, BlackTech, S67
Bando is offline   Reply With Quote
Old 08-07-2009, 06:48 PM   #40 (permalink)
HELLO
I think if you did 65/50 during the day it might just be high enough once cold to keep the TPMS happy.
It is a real pita here in the desert. We have large temp swings and the sun heats up the tires on one side from parking orientation. This makes the pressures uneven and trips the alarm as well. And like the Emission $hit
BYE
steven
view for free communication
steven4321 is offline   Reply With Quote
Old 08-07-2009, 07:34 PM   #41 (permalink)
For a good time- Smarty
dad2bike's Avatar
Originally Posted by steven4321 View Post
HELLO
BYE
steven
I have my best results setting LL in 1st thing in the morning. After sitting overnight and cool. I do not go as hi as you are suggesting. The uneven pressures from the direct sun & high temps are just too much. I do 60/45 cold for LL. Then I just accept the dam light after driving awhile.
Tom
2008 Quad-Cab,LB, 2500, 6.7L, 4X4, White/Kaki, Big-Horn, 3.73 Auto, AS flash, K&N Air Filter, no baffle, Testing in progress- step 4, Stealth DPF, Smarty sw3 PMT gauges. Mag-Hytec Pan & Diff covers.Toms smarty Journal ....... DIY Deletes How-To
Stealth is the WORD!
dad2bike is offline   Reply With Quote
Old 09-08-2009, 11:45 AM   #42 (permalink)
Originally Posted by brett08 View Post
Dont forget your spare tire!!!! It has a senser too.
Agree with dad2bike - spare doen't come into play until mounted & rolling. Service manager said check the spare - checked with the tech he said on some trucks yes but not the 2500. Big temp swings here in Nebraska lately 30+ degrees in a day....have always been able to get my tpms warning light to go out - couldn't get it to go out this last time. So trk is in for it's first new turbo today @ 21.5 k...AND also getting a new TPMS control module.
foster1 is offline   Reply With Quote
Old 09-08-2009, 11:55 AM   #43 (permalink)
dad2bike's Avatar
Slip the tech a $100 bill and see if he'll turn the TPMS off. Couldn't hurt.
Tom
Old 10-15-2009, 08:15 PM   #44 (permalink)
Tazz3069's Avatar
My truck did not come with sensors. Can I purchased these from the dealer or somewhere and have it programed into the truck?
2007 Dodge 2500 Mega Cab Diesel. 20x9 Extreme Alloys 6001, Pro Comp Tires 35/12.5R20, 4" Superlift with Sterring Stabalizer, Alpha spray in bed liner. Banks Exhaust and CAI, Edge with Juice, Full tinted Windows
Tazz3069 is offline   Reply With Quote
Old 10-16-2009, 07:49 AM   #45 (permalink)
07 dont have them,,, lucky,,,, its mandatory on 08 and up
08 6.7l 4x4 qc sb auto....
warlock06 is offline   Reply With Quote
Old 10-28-2009, 12:45 AM   #46 (permalink)
I don't knowif I'm doing something wrong when trying to activate it or not. When I push the button it flashes five times and then goes out. Is the light supposed to stay lit once activated?
Comparatif mutuelle sante complémentaire |Devis complémentaire comparatif mutuelle sante
atatehug is offline   Reply With Quote
