Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7 Liter General Discussion
6.7 Liter General Discussion General Chit Chat About the Future Cummins Diesel Nut Motorsports
Old 01-02-2009, 11:45 AM   #13 (permalink)
For a good time- Smarty
dad2bike's Avatar
Originally Posted by brett08 View Post
Dont forget your spare tire!!!! It has a senser too.
That doesn't come into play until you mount it and start rolling. The rolling motion is what activates the transducers.
Tom
2008 Quad-Cab,LB, 2500, 6.7L, 4X4, White/Kaki, Big-Horn, 3.73 Auto, AS flash, K&N Air Filter, no baffle, Testing in progress- step 4, Stealth DPF, Smarty sw3 PMT gauges. Mag-Hytec Pan & Diff covers.Toms smarty Journal ....... DIY Deletes How-To
Stealth is the WORD!
dad2bike is offline   Reply With Quote
Old 01-02-2009, 01:06 PM   #14 (permalink)
6PackCharlie's Avatar
When the light load switch is functioning properly, will it stay illuminated or will the light go out? Does the TPMS light have to be on for the switch to function? Just trying to figure this out. I've had my tires set at "max load" pressures for quite some time because I couldn't get this switch figured out. I'm trying to see if I'm doing something incorrectly or if the switch is bad somehow.
I finally got my light load switch (LLS) to work. It stays illuminated continuously and no TPMS warning light.
My TPMS light was on when I bought the truck (about a month ago). The dealer aired it up to 60 front and 45 back. He said the the light should go off as soon as the truck learned the correct pressure??? I tried airing up the back tires to 60 and the TPMS light still stayed on. I finally said if the TPMS light is going to stay on, I was going to lower the pressure in the back so the truck didn't ride so rough. When I lowered the pressure back to 45, turned on the key but didn't start the truck and pushed in the LLS, the TPMS dash light went off, the LLS light stays lighted and all is well.
Also did the same thing with my cousin's truck.
2008 RAM 2500 4X4 Quad Cab, 6.7L Cummins
6PackCharlie is offline   Reply With Quote
Old 01-02-2009, 02:55 PM   #15 (permalink)
08 Cummins
Como4076's Avatar
Question
Hey Brett, I have to say the spare DOES NOT come with a sensor valve in the spare !! Or at least mine did not. I checked mine out and there is none !!! I called the dealer and he said they don`t come in the spare tire. Maybe I am wrong anybody else have the same ???????
Como
08 2500 Silver SLT 4x4 QCSB Bilsteins on all corners,Line-X,Defiant Steering Brace,Defiant Steering Stabilizer,IceBox CAI,Seat Mod,Coming soon,Thuren Control Arms,Sway bar endlinks....
Como4076 is offline   Reply With Quote
Old 01-02-2009, 04:10 PM   #16 (permalink)
WTB Black Maxx....
Sapling's Avatar
I put my rims on from my 04 with studded tires on them and ....Yep I have a constant dinging and dash light.....PIA.... I wish I could just up hook the damn thing!
08 6.7....EGR gone, DPF???? DPF-R in its place, full SS TBE, Edge/Att Hot unlock, Power puck, Zilla Boost fooler! OEM remote start, High idle engaged, 9005 Silverstar Ultra fogs.....Need more fuel gauges, and an Airdog, Brite box to come!
Sapling is offline   Reply With Quote
Old 01-12-2009, 09:49 PM   #17 (permalink)
trlr prk's Avatar
Well, I didn't follow dad2bike's instructions to the t, which was where my problem was. I misunderstood the process of this switch. I talked to the dealer and the tires have to be at the light load pressures, or a few pounds within those numbers. I was under the impression that the pressures didn't have to be at the "light load" value, and I was trying to use it at a value in between max and light (65 all around). Then I set my front's set at 65, and dropped the rears to 45 and the light load switch worked. It didn't work at first, but the truck must have known that I was headed to the dealer to get the newest flash because the morning on the way to the dealer the swith decided to work and has worked since. Wierd, but at least it's working now. Thanks to all for your replies.
08 2500 QCLB 6.7. 4x4. 68RFE. Gen 1 5" SS. EGR & Cooler Gone. Hot Edge. Single Amsoil Bypass. Fleetgaurd Remote Fuel Water Sep. and 2 Micron Filter. Marathon Seat Covers. Some Bolt Ons For Looks.
trlr prk is offline   Reply With Quote
Old 01-12-2009, 09:53 PM   #18 (permalink)
Black Smoke Addict
RedRum's Avatar
Has anyone tried running nitrogen in their tires? I have heard they isn't such great differents in psi between the temperature differences. It might help out if its true.
2007 3500 QCLB, 5.9, ISSPRO, AFE Stage 2, AF1 intake horn, Smarty, SB 3600#, Straight Piped with 6" Mitres, 6" lift, Bilstein 5100s/dual steering stabs., trac bars 37" BFG M/Ts, CUMMINS FORUM STICKER!May 2009 ROTM-Thanks to James @ RSD for stepping up!
2006 3500 QC Bighorn, 6 speed, No silencer ring, B&W turnover, other than that, stock
"I Caught that diesel thing, now it stings when I pee"
RedRum is offline   Reply With Quote
Old 01-12-2009, 10:09 PM   #19 (permalink)
6.7L OneTon's Avatar
Is TPMS only on 2500's?
2006 Mega 4x4 Laramie, 5.9, 48re, Banks 6Gun Bundle, KORE 3" Race Suspension
R.I.P. or Burn in Hell...2007.5 3500 SRW 6.7L
6.7L OneTon is offline   Reply With Quote
Old 01-12-2009, 11:57 PM   #20 (permalink)
dad2bike's Avatar
No. I understand it is on all 2008 up to the 2500. 3500's don't have it.
Tom
Old 01-13-2009, 02:04 AM   #21 (permalink)
good to know in case I end up in a new 08 or 09 in the buyback.
Old 01-13-2009, 11:16 AM   #22 (permalink)
BOOOST's Avatar
I ran it in my 06, and yes there was very little fluctuation due to temperature. My tires were always about perfect.
I didn't liek the nirogen because....
I had them put 45 in ther ear tires and 60 in the front. When I wanted to tow something, I had to air them up a bit, if I did so, then I had nirto and air in my tires and it cancelled out the benefits of having the nitro. So if your gonna do Nitro, try to pick a Psi that you won't want to or have to change frequently. I should have had them fo 60 in the rear, and I later did, but that extra 15 psi sure made it ride rougher.
That being said, I plan on doing it to my 08, and just doing 60 all around, once my new tires are mounted.
08 6.7L MEGA CAB 2500 SLT 4X4 AUTO l DIPRICOL OPTIX BOOST/PYRO/TRANS l KORE CHASE l FOX 2.0 RR l CARLI LINKS l CARLI RESEVOIR MOUNTS l TINTED l TS MP-8 l 5" TBE l EGR DELETE l TEKONSHA P3 l LINE-X l PE JACKRABBIT l AFE MEGA CANNON l SMARTY l 285/75/17 TOYO MT l
BOOOST is offline   Reply With Quote
Old 01-14-2009, 12:33 AM   #23 (permalink)
blubyou's Avatar
Nope. I'm rolling around on a spare right now on the back right corner because I had a blowout Saturday morning, and my TPMS light is on and there is no sensor at all in the spare wheel.
'08 PB 6.7L Ram 2500, QC, G56 6-speed, 5" RC lift/Dual-steering stabilizer/Shocks, 20x10 Ion Forged Termi's, 35x12.5 Toyo M/T, Bushwackers, Eyelids, DPF/EGR/Muffler delete w/5" tip, QZ Boost Fooler, Isspro gauges, Tint, 8K HIDs, Pioneer/Alpine/Fox-A/MTX
blubyou is offline   Reply With Quote
Old 01-16-2009, 03:29 PM   #24 (permalink)
dad2bike's Avatar
I did a bit of research into the wiring diagrams. I was able to defeat my TPMS at this time. I will post up how after I get some miles on it to be sure there are no related issues.
Tom
