Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7 Liter General Discussion
6.7 Liter General Discussion General Chit Chat About the Future Cummins Diesel Nut Motorsports
Old 08-28-2008, 04:45 PM   #13 (permalink)
Originally Posted by smoke46 View Post
Anyone put it in a glass jar of diesel. Same ratio as a full tank of fuel. Then add numerous orings and gaskets to see what it does to the diesel and seals. Then base you're judgements from that.
Then put your $750.00 150/150 in, Any takers.....
06 Crew Cab, 4x4, Goerend Full Billet 48RE, 6.5' bed, level kit, 5" T.B Magnaflow, K&N big tube intake,Silver 64,Studded (625's), Big Stick(s),G.D.P belt L.P,Smarty Revo/tnt., Gauges, 3:73 ratio diffs., non-slip rear diff. Lead Foot.
2-2009 Silver Q.C 6.7 3:73 4x4 6.5' bed Stock .....
Laser Tech is online now   Reply With Quote
Old 08-28-2008, 04:56 PM   #14 (permalink)
What about the injectors?
coal400 is offline   Reply With Quote
Old 08-28-2008, 05:05 PM   #15 (permalink)
They dont really matter too much, cheap to replace...
Old 08-28-2008, 05:06 PM   #16 (permalink)
Illinois Chapter VP
Cumminsturbo22's Avatar
its the main ingredient in octane booster. my grandfather taught me that trick but he told me this when i had a gas vehicle. idk about diesel tho
2006 Ram 2500 6 inch lift, 37' BFG MBRP stacks 6" Mitre tips, AIRAID intake, Raptor 150, AFE Bladerunner, MP-8,Smarty!,
Why is there never enough time to do it right the first time,
But always enough time to do it again?
Cumminsturbo22 is offline   Reply With Quote
Old 08-28-2008, 05:18 PM   #17 (permalink)
That is true to a point. it is distilled though not the same as far as solvency is concerned.
Old 08-28-2008, 06:03 PM   #18 (permalink)
gearjammin6.7's Avatar
Does anyone know if the acetone and diesel will separate?
07.5 RAM 3500 C/C 6.7L, 4X4, 3.73, G56, DPF MIA, K2 EGR and Cooler deletes, Laramie Bumper, BFG 245-75R-17 AT KO, Di-Pricol Boost & Pyro, AFE Drop-n, Bully Dog PMT, TS MP-8 and SBC 3600 Dual Disc
gearjammin6.7 is offline   Reply With Quote
Old 08-28-2008, 07:09 PM   #19 (permalink)
Banned
Gonna go outside and try it out. I let you know.
smoke46 is offline   Reply With Quote
Old 08-28-2008, 07:32 PM   #20 (permalink)
Banned
After 20 mins of 3/4 red diesel and 1/4 acetone in this coke bottle (no advertisement here) all it's done was turn it hazy and somewhat thinner.
Old 08-28-2008, 07:58 PM   #21 (permalink)
Benchwarmer
pistazie2500's Avatar
Interesting discussion. Chemical compatability also has to be tested under dynamic conditions, as well as a bunch of other mechnical tests - just letting it sit in there in a jar for a couple of days won't tell you anything. You have to test for the particular application and develop tests to model long term application and suitability.
Don't know what the seals, o-rings etc. on a Dodge truck are made of but here is a chemical compatibility chart for O-rings and acetone. If the seals contain any natural rubber it will probably not be compatible under dynamic conditions.
eFunda: O-Ring Materials Compatibile with Chemical Acetone
But I don't know if those seals contain any natural rubber - I think benzene is even less chemically compatible with natural rubber than acetone...
2006 Dodge Ram 2500 Quad Cab 4x4, 5.9L. Lovingly girl-owned and maintained. Icebox and cool tube, Magnaflow TBE duals.
Superchips Cortex. ESPAR coolant heater, no HP but mmmmmm toasty!. 4-gauges w/above-mirror pod. BD Power stuff: Max Flow fuel lift pump, intake elbow, steering box stabilizer. Bit'o BLING thx to Chrome-It-Up, hey that looks good.
Foamy loves Cummins.
pistazie2500 is offline   Reply With Quote
Old 08-28-2008, 10:11 PM   #22 (permalink)
Let that set for a day or so, just curious. Thanks
Old 08-29-2008, 01:00 PM   #23 (permalink)
Banned
I even let it sit in the sun all this morning and it cleared up. It looked like it cut a tiny bit of water out of the fuel and settled it to the bottom. Though it may of just been the condensation inthe top of the bottle from sitting overnight. Going to cut up different oring and seal materials and drop them in and leave it out in the sun to waht happens.
Old 08-29-2008, 01:35 PM   #24 (permalink)
HB69DART's Avatar
Realize too that your mix ratio is 25% acetone. The recommended mix ratio's I've seen are more like 2 oz acetone to 10 gal diesel.... Just enough to break surface tension. This equates to just a hair over 1/10th of 1% (on a volume basis) of acetone in the fuel mixture.
2007 6.7 4x4 QC DRW, auto - 2" level, Dually Rockstars, Buckstop bumper, MBRP filter-back, S&B CAI, Amsoil bypass, de-badged, Bushwacker flares, Recon, Undercover tonneau
1969 Dodge Dart - 572" wedge
HB69DART is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
