Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7 Liter General Discussion
6.7 Liter General Discussion General Chit Chat About the Future Cummins Diesel Nut Motorsports
Old 07-24-2008, 10:59 AM   #25 (permalink)
What I find funny is that on the Cummins website, they talk about testing this motor (with all the components we are complaining about) for the equivalent of a million + "customer equivalent miles." Yet, everyday when I sign on here, I read about people needing new turbos after 2,000 or 5,000 or 12,000 miles.
Who dropped the ball on this one? Dodge and Cummins aren't the first company to have an EGR system on a turbo diesel, why are these so prone to clogging? What about the turbo diesels going in big rigs that have the same emissions stuff on them? Are they blowing turbos every 5,000 miles?
2008 Ram 2500 Quad Cab 6.7L 4x4, Auto, Stock for now
CO6.7Cummins is offline   Reply With Quote
Old 07-24-2008, 11:35 AM   #26 (permalink)
$.02 Contributor
slagburn's Avatar
My own theory about why the problems are centered around Dodge / Cummins right now is simply the quantity of EGR going back through the engine.
From looking at my monitor for EGR valve position mine is 94.9% open almost all of the time from idle to empty highway cruising with is the majority of what I do. EGR flows seem to be less as the load goes up, on hills and running heavy there might be as little as 7% to 40% but every possible second that it can it is 94.9% open.
Ford and Chevy are both running EGR on their light / medium duty diesel engines but I believe the quantities are less - just from lurking around the various message boards related to those two products I've noticed that their DPF DeSoot cycles (regens) occur at least half as much as mine do. I also have data (not at liberty to disclose the source) that suggests that with the EGR capped off on the 6.7 and the DPF in the system the soot delta pressure increase (a basic measurement of DPF backpressure or how clogged it is) is over time is greatly reduced suggesting a huge soot load increase due to the EGR, however EGR reduction can have a seriously negative impact on the Nox absorber that our trucks have been blessed with.
It is possible that many of those million customer equivalent miles were high load miles on a load cell or something to simulate towing conditions and not light load miles like many of us do, or the EGR mapping was different during the testing, or they only meant that the 6.7 itself was tested for that long and then turned over to Dodge who programmed the whole mess - who knows how much factual data is behind what the propaganda machine at Cummins / Dodge spews out.
07.5, 6.7, Auto, QC, 4x4, Lots of gauges - ISSPRO (Pyro, Boost, Trans Temp) PriCol Optix (Fuel Pressure Lift/Rail) AutoMeter (Oil Pressure) - Dynatrac Free-Spin Hub Conversion Kit - RETRAX bed cover - Shaved Bluetec badge - homebrew water separator and 5 micron filter - MSD Dashhawk
slagburn is offline   Reply With Quote
Old 07-24-2008, 01:00 PM   #27 (permalink)
What you said definitely makes sense - maybe that's why guys who run the hell out of these trucks report little to no problems over the long haul. Whereas a large number of us aren't towing 10,000 lbs 24/7 or climbing 11,000 ft mountain passes on our way to work.
The more I hang around this site the more anxious I am to rip off the EGR and DPF.
Old 07-24-2008, 04:13 PM   #28 (permalink)
The turbo they replace with is the exact same one they put on at the factor. which is the cause of one of the problems... the metals they made the VGT out of are cheap.. they expand and don't operate properly under heat.
CanRam is offline   Reply With Quote
Old 07-24-2008, 04:20 PM   #29 (permalink)
GeoffGiggy8's Avatar
That is not a re-assuring comment and does not make me feel good about spending 45K on this truck.
2008 6.7 Auto Big Horn. AFE Pro Dry Stage 2, Edge Juice W/Attitude, TS Performance MP-8, H&S Performance Black Box 5 in. DIY TBE, HBS Level....More to come
GeoffGiggy8 is offline   Reply With Quote
Old 07-24-2008, 04:25 PM   #30 (permalink)
DPF & EGR Free = SMILEYS
jsnolan99's Avatar
I'm convinced.... DELETE, DELETE, DELETE! ! !
My blocker plates are being shipped from K2 next Monday and the following Monday I have an appointment at BADP for the 5" TBE Gen 1 with the Juice to clear the codes from the DPF & EGR.
It won't be long now.
07.5 3500 DRW,Crew Lonestar, 6.7, G56, 3.73 gears, Edge Juice with Attitude, BADP 5" TBE, Magnaflow 5" muffler, 6" tip, EGR delete, B&W hitch, Amsoil BMK-11 bypass filter, Condenser Guard, Cobra 29LTD Classic, Recon Smoked Fender & Cab.
Next on the list: CAI,Clutch, Lift Pump, MP8, and the list is growing.
http://www.myspace.com/jeromy99
91 D250 5.9 single cab, 5 speed, Icebox CAI
jsnolan99 is offline   Reply With Quote
Old 07-24-2008, 05:44 PM   #31 (permalink)
im pretty sure enough of you could take legal action against chrysler to keep your warranties if you can logically prove the deletes get rid of the problems.
Someone get an Etest before and after the deletes.. see what happens..
Old 07-24-2008, 05:52 PM   #32 (permalink)
i would be interested to see how badly the trucks fail the 2007 emmisions regs, after the deletes that is
2007.5 QC SWB 4x4
6.7CTD, 68RE, Inferno Red, Big Horn
Riddler6.7 is offline   Reply With Quote
Old 07-25-2008, 06:13 AM   #33 (permalink)
bluffs07's Avatar
2007.5 QC SWB 4x4
I think Riddler6.7 has nailed it. What are the differences are they extreme?
07' Red 2500 Laramie 4X4 6.7 auto, X-treme bed liner, Access bed cover, still under warranty, for now
bluffs07 is offline   Reply With Quote
Old 07-25-2008, 06:55 AM   #34 (permalink)
Awesome! Guess what I saw today? P2262!
On my way to work, the check engine light goes on, take it to the dealer and it's the dreaded P2262. Only 3,168 miles on the odometer.
The guy said they clean them first and if the code still pops up, they replace the turbo.
How many of you guys have seen zero problems after having the turbo cleaned? Should I drive the truck like a granny in hopes of clogging it again, getting a new turbo and then doing the deletes?
Old 07-25-2008, 07:13 AM   #35 (permalink)
thats what im going to do. If i ever get the dreaded code, im going to wait til they replace the turbo, then i will do the deletes directly after! Either way i will eventually do the deletes but that will decide when.
2007.5 QC SWB 4x4
Old 07-25-2008, 07:50 AM   #36 (permalink)
Dodgezilla's Avatar
So I guess there's no way to just reroute the EGR so that it's not going into the turbo????
08 Ram 2500 Mega 4x4,68RE,6.7l,Loaded Laramie,SRT10 hood, Sunroof, DVD, Nitto 285 Dura Grapplers, MOPAR Grill Guard, Some other stuff
Will Work For Fuel!!!
Dodgezilla is online now   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
