Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7 Liter General Discussion
6.7 Liter General Discussion General Chit Chat About the Future Cummins Diesel Nut Motorsports
Old 06-30-2008, 05:28 PM   #25 (permalink)
Based on that then you would assume that wires 6,7 & 8 control the opening and closing, 2,3 & 4 are position indication and 1 & 5 supply the power to the sensor. The next obvious question would be what combination of each tell it to open or close.
Is the electronic version of the manual you pulled from on this site?
Last question (for Slagburn)-- did you do the EGR delete on your truck
2007.5 2500 4X4 Quad Cab 6.7L
Len
LSmith is offline   Reply With Quote
Old 06-30-2008, 05:43 PM   #26 (permalink)
$.02 Contributor
slagburn's Avatar
That is from they call the "Service Information CD" which can be purchased at various places on the net.
Not yet.
07.5, 6.7, Auto, QC, 4x4, Lots of gauges - ISSPRO (Pyro, Boost, Trans Temp) PriCol Optix (Fuel Pressure Lift/Rail) AutoMeter (Oil Pressure) - Dynatrac Free-Spin Hub Conversion Kit - RETRAX bed cover - homebrew shaved bluetec badge - plugged up EGR - Baldwin BF1212 water separator and CAT 1R0750 fuel filter - MSD Dashhawk - Baldwin B164 Bypass Filter
slagburn is offline   Reply With Quote
Old 06-30-2008, 07:09 PM   #27 (permalink)
Thanks for the info!!
Len
Old 07-01-2008, 05:43 AM   #28 (permalink)
Shibbyutman's Avatar
It isn't the fact that we want to tell it to open or close. It is that we want to mimic what it provides as a load on the ECM and what it provides as feedback. You can measure the resistance between the three "control" pins. The control is set up by the ECM at a very high rate of speed. Each pin can be used as either a power or ground for either coil. So depending on current direction and the pin it is applied it pulls the motor further around. There are three "hall effect" sensors on the sensor board at the end of the EGR valve. These sensors follow a 12 pole magnet around and switch polarity each time a differing pole goes by producing a square wave output depending on the speed of the movement. That is what we want to imitate.
2003 Dodge Ram 2500 4X4, Banks Big Hoss Bundle, K&N FIPK, 5" Turbo back Expand-It exhaust, Goerend Full Built Trans, Smarty REVO, DIY Fuel Control Actuator Mod, FASS 150/150 and custom big line kit.ABS Brake Specialist-You've got questions, I've got answers.
Shibbyutman is online now   Reply With Quote
Old 07-01-2008, 06:50 AM   #29 (permalink)
1st 6.7 with Twins
Compcowboy's Avatar
I dont think i understood a single part of that post Shibby. Good thing i didnt try my own.
??? Hp ???? Tq - 2007 6.7 TWIN TURBO 2500 Bighorn 4x4 6-spd Manual, Airdog 150, ARP Head Studs, Bullydog PMT, TS MP-8, Airbags with Dual Control Air Comp., H&S Delete & Downpipe, What EGR?, Valair Dual Disk, Amsoil Bmk-11 Bypass, 295/70/R17 Toyos on Walker Evans Wheels,6" Aussies & Hushpower Muffler & DiProcol Gauges & 120HP nozzles (on the way) Thanks to Wally At FTEDiesel!!!!!
Compcowboy is offline   Reply With Quote
Old 07-01-2008, 11:25 AM   #30 (permalink)
HUH???????
2007.5 6.7 auto 3500 SLT Quad Cab DRW - Stock -2006 Honda Civic Hybrid = 2004 Suzuki XL-7 = 2001 Pathfinder SE 4x4
txrlk is offline   Reply With Quote
Old 07-01-2008, 11:32 AM   #31 (permalink)
Exactly, now you know why there is no code free delete yet...
Old 07-01-2008, 05:00 PM   #32 (permalink)
I understand all of that, but position wise there is a point where the valve is closed, whatever the 1's and 0's are. And I'm not suggesting code free. I just want to figure out the combination to those 6 wires to keep the valve shut, from an external source. If the ECM sees it can't control the valve, but it knows it's position, logically it would respond with all of the other variables to allow the engine to run. Yes, it will set a code because it can't control the valve, but the code "shouldn't" be more severe than unplugging the EGR valve all together.
It may not work, but I won't know if I don't try!
Len
Old 07-01-2008, 06:32 PM   #33 (permalink)
If you have some way of making a PWM signal of approximately 80% duty cycle you can apply that 12v signal to pin 6 and 7 and make 8 to ground that would get you pretty close from what I have seen. The stepper motor appears to be powered througout operation of the engine to prevent just what we have said here, shifting from boost. It is these PWM signals that maintain a little force on the valve and allow it to remain closed.
Old 07-01-2008, 08:05 PM   #34 (permalink)
12 Volt DC PWM -- that may be a little difficult.........
If we knew the current draw required, you could size a diode to shunt the voltage spike. Then you could just send it a 12VDC signal. May be more trouble than it's worth...
Len
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
