Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7 Liter General Discussion
6.7 Liter General Discussion General Chit Chat About the Future Cummins Diesel Nut Motorsports
Old 09-01-2008, 10:40 AM   #13 (permalink)
yoda's Avatar
that does stick out some, but not too bad. how hard was the install?
05 2500 qc, sb, 4x4, 6spd, 3.73, silencer MIA, afe stg 2 pg7, 4" dynomax bullet muffler to 5" turnouts, ranch hand bumper, HBS 2" leveling kit, prodigy controller, b&w goose neck, 300 HP/540 TQ feb 08, looking for donations
yoda is offline   Reply With Quote
Old 09-01-2008, 10:52 AM   #14 (permalink)
$.02 Contributor
slagburn's Avatar
The install is very straight forward if you're familiar with how conventional solid axles work, have a press, a torque wrench and air tools. The two most difficult tasks for me were getting the rotors unstuck from the old hubs (LOTS OF RUST, EVEN ON A 07.5) I had to use blocks of wood and a calibrated 5lb hammer to get mine off, and getting the brake caliper bracket bolts broken lose required the help of someone much stronger than I. (Wasn't able to get the impact wrench to them and they are torqued really tight at the factory.)
I have pictures of the whole thing on another PC.
07.5, 6.7, Auto, QC, 4x4, Lots of gauges - ISSPRO (Pyro, Boost, Trans Temp) PriCol Optix (Fuel Pressure Lift/Rail) AutoMeter (Oil Pressure) - Dynatrac Free-Spin Hub Conversion Kit - RETRAX bed cover - homebrew shaved bluetec badge - plugged up EGR - Baldwin BF1212 water separator and CAT 1R0750 fuel filter - MSD Dashhawk - Baldwin B164 Bypass Filter
slagburn is online now   Reply With Quote
Old 09-01-2008, 11:09 AM   #15 (permalink)
Local Rotor Head....
ah64id's Avatar
This is something I plan to do as well, for serviceability, 2lo, and any mpgs I might get.
05 3500 QC LB NV5600 4X4 SRW
Pricol Boost and EGT
Amsoil everywhere, BMK-11
GDP MK-2+ w/ Cat 2 mic
Smarty Jr Revo
ah64id is offline   Reply With Quote
Old 09-01-2008, 12:46 PM   #16 (permalink)
Who Needs a Semi ???
KodiakConstruction's Avatar
This is the kit on my 07 5.9. I have one for my 6.7 as well but this will give you an idea of what it looks like on a truck with bigger wheels/tires/lift. This is on an 18" wheels with 37" tires.
2007 6.7L QC DRW 4x4..... Custom Built 68RE by DPT ..... 5" BADP TBE, EGR & Cooler Delete, Edge w/Attitude, MP-8, Firestone Airbags w/ Dual Control, AFE Filter, 100 gal Transfer Flow Aux Tank, B&W G/N, Dynatrac Hub Kit, Warn 16.5 Winch, Optima Batteries, Triple Train Air Horn, Amsoil in & out, Full line of Smoked Recon's/Line of Fire/Big Rig Lights.....
KodiakConstruction is offline   Reply With Quote
Old 09-01-2008, 12:55 PM   #17 (permalink)
95whtzr2's Avatar
Looks good with the bigger tires. This is definitely on my wish list... probably after 3yr/36k miles... lol.
Tom
2008 Dodge 3500/SRW/manual 6spd/CC/LB, B&W tob
My Photobucket
95whtzr2 is offline   Reply With Quote
Old 09-01-2008, 01:01 PM   #18 (permalink)
Here is a full view of the truck with the kit on it. I had same kit on my 06 5.9 as well. That was a 6 speed manual with same size tires/lift and with the truck chipped there was about 1.-1.5 mpg increase. Not a big increase for the $2200 price tag
Old 09-01-2008, 01:30 PM   #19 (permalink)
Danderson's Avatar
Dynaloc hub option.
The Dynaloc option shaves a good 3/4"- 1" off the end of the hub. Much simpler and stronger too!
'07 2500 SLT,5.9,reg.cab.,G-56, 4wd,8' Northstar popup 24/7. Lorenz 2.25 SAW w/Carli long travel airbags. AFE Bladerunner. Smarty Sr. Revo.
Danderson is offline   Reply With Quote
Old 09-01-2008, 09:20 PM   #20 (permalink)
Cyberous's Avatar
Thanks for the pictures!
They don't look bad on a bigger rim at all. I have 17 x 9 Centerlines with a 4.5" back spacing on mine.
If it really were to improve the mileage 1 to 1.5 mpg and my truck currently averages 11 mpg that would be nearly a 10% increase! At $4+ per gallon I think $1375 for the kit seems like money well spent!
I think I'll go with the EMS kit for sure!
2008 Laramie Quadcab 4wd 3500 shortbed
Cyberous is offline   Reply With Quote
Old 09-01-2008, 09:48 PM   #21 (permalink)
95whtzr2's Avatar
I use this to figure out how much a mileage mod would help me...
But I am interested in it for the future cost aspect of rebuilding the axle as well as the 2LO... So its worth it to me. But she is gonna stay almost bone stock through the warranty
Tom
My Photobucket
Old 09-01-2008, 10:01 PM   #22 (permalink)
1BadOilBurnerN-Lv's Avatar
They stick out just like the old hubs on the dana 60's .No big deal but i sure as hell aint wastin that much money for 1.5mpg increase . After 200 thousand miles theyll pay for themselves
2000 2500 sport extended cab short box. 5 inch straight piped exhaust , silencer ring M.I.A. , B.H.A.F. 354 gears , 6 inch long arm rcd lift and 37's Superchips micromax tunner
1BadOilBurnerN-Lv is offline   Reply With Quote
Old 09-02-2008, 04:30 PM   #23 (permalink)
Originally Posted by Dawg View Post
IMO : it would have to save a whole lot of fuel to have to get out in a mud hole or rain to lock the hubs .
You're supposed to lock them BEFORE getting stuck.
2007.5 Big Horn 6.7L Ram QC 4X4 Auto A.R.E Tonneau
mileshuff is offline   Reply With Quote
Old 09-03-2008, 08:07 PM   #24 (permalink)
BlowingSmoke's Avatar
I loved the kit I had it on my 97 2500
I did the complete kit Bullet proof design If you are looking to save money on Milage I wouldnt buy it just for that, but as your non servicable factory bearing sets need replaced you
may want to jump on the kit then, Good luck
97 Dodge ram diesel (gone) I am gonna miss her.
08 Dodge SLT 2500 quad cab 8 foot bed, Diesel 4x4 manual gear box. Banks air box and exhaust DPF back. DPF delete needed
BlowingSmoke is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
