HID Upgrade with Projector lenses.... - Page 2 - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > 07.5 and Up 6.7 Liter Cummins > 6.7 Liter General Discussion
6.7 Liter General Discussion General Chit Chat About the 6.7L 3rd generation Cummins - NO ADVERTISING
Old 10-24-2007, 05:00 PM   #13 (permalink)
SMMDTD's Avatar
I belive JKOPPE on the tdr site(How to HID - TDR Roundtable)
did a HID conversion using the lexus 430 projection hid light in the factory 03-05 housing real nice job if i remember right the thread was "how to hid" it show the resistors he used also. im going to try it on my truck soon
THE DODGE MAN COMETH
SMMDTD is offline   Reply With Quote
Old 10-24-2007, 05:16 PM   #14 (permalink)
Free parts distributor
LaMoparPower's Avatar
Originally Posted by Diesel_Nuts View Post
I am also interested in putting HID's on my truck, and would like to get some info too. lamoparpower, HID's actually run cooler than your factory headlights, and draw less power, so those projector lights will be fine. I want to do the same thing as you, and have done the research on the HID kits. Only problem is getting around the Dodge lighting problems, and I will have them on my truck.
HID's actually run hotter, but use less wattage.... i.e. your heating up gas instead of lighting a filament.... i thought the same thing... but less power doesn't necessarily mean less heat.... halogen and High Intensity Discharge produce their light in totally different aspects..... and i have had no problems with just the "bolt in" kit.... comes with bulbs and a Ballast/igniter.... plug your factory headlight plug into the ballast.... then plug the new gasbulb into the ballast....
2012 MCSB Laramie DRW, amp steps, H&S MM, Alligator EGR delete, DP and dpf &EGR delete pipe, OD software
Thanks Matt @ Alligator Diesel Performance!
2009 titan 40surv
Originally Posted by jmd025 View Post
Duke, can we get "official G2G backer - outer" put under his name?
LaMoparPower is offline   Reply With Quote
Old 10-24-2007, 11:35 PM   #15 (permalink)
Well, good and bad news...the good news, the lights work great when the truck is off...unfortunately, becuase the headlights are computer driven (see information in prior post) the will only work if you wire in an addtional relay.
The relay will pull power off of the battery when the truck is running and off of the electrical system when it is not...
So, I have ordered the relay harness and it should be here in the next day or so. Other than that, they look awesome.
Quick note though, make sure and have your lights readjusted as the light pattern is a but higher with the HID's as opposed to your normal halogen bulbs.
06RAMSPORT is offline   Reply With Quote
Old 10-24-2007, 11:37 PM   #16 (permalink)
One other quick note:
The cooler temps (i.e. 3000k ~ 5000k) provide many more lumens than the >5000k bulbs...but, if you get too cool, it is yellow and that is illegal, thus the white at about 3000k tends to provide the most useable light.
hope this helps.
Old 10-24-2007, 11:46 PM   #17 (permalink)
LRCanon's Avatar
Heck, I wired in a relay harness and they still flashed on me. I don't know why they are being so stubborn for me.
2006 Mega Cab 3500 SRW : Smarty SW?: AFE Stage II intake : 5" Pro Flow Exhaust :
LRCanon is offline   Reply With Quote
Old 10-24-2007, 11:47 PM   #18 (permalink)
LRCanon's Avatar
Yes the bulb itself is hotter, but the temperatures inside the housings are typically cooler. I tested it with my fog lamps. Put an HID in one side and a stock bulb in the other and the stock bulb by far projects much more heat out through the lens.
Old 10-25-2007, 12:10 AM   #19 (permalink)
076.76cylinder's Avatar
When you say $300 lights.... are you talking about the bulbs and such or the plastic housing.... NO WAY will you hurt the lights and kinda doubtful that you will harm the "casing" if they are Moded correctly.....
076.76cylinder is offline   Reply With Quote
Old 10-25-2007, 12:18 AM   #20 (permalink)
Originally Posted by turbodiesel3 View Post
damn guys, didnt expect this post to go this far...but hell yeah there is a lot of info now....thanks...i went to the recommended site (xenonlinks, i think) and found the ones i like....should i buy hi/low or just lows.????
If you get the 'good' kits (Hella / Bosch) the lows will run you about $200-300 and the high/low will be in the ballpark of $500-600........... Guess it depends on your checkbook... But heck, ive kinda been reading all your post and you have some really cool mods already... if you can get the high/low......
For other people that might read this thread as well... if you get the high/low you don’t have to mess with the yearly inspection (if your state requires them)... If you get the "low" HID you will not have a ** High/low** beam any more... and here in Texas we wont pass inspection... DONT WORRY about the 'low' not being bright enough AT ALL.... It will BLOW YOUR MIND!! I’m going to save a few bucks and rig my fog lights to be my "high" beams and I will pass inspection.....
Old 10-25-2007, 12:19 AM   #21 (permalink)
You need the resistor mentioned in the other post!
Old 10-25-2007, 04:45 AM   #22 (permalink)
EAST TEXAS VP
Diesel_Nuts's Avatar
I agree as I stated before that they do run cooler inside the housing. I have read this in many other posts, and also from knowing people that have HID's on their trucks and cars. I also used to have HID's on my old truck. The only reason I have not put them on the new truck, is this issue with the factory computer. Once that is sorted out, and I know exactly what I need to do, I will put them on. I would definitely go with the Hi Low kit.
Big Blue - SOLD....
Diesel_Nuts is offline   Reply With Quote
Old 10-25-2007, 05:02 AM   #23 (permalink)
i have had them on my truck since december.... i honestly do not know what problem it is ya'll are talking about??? I haven't had one lick of problems(besides a set of melted foglight housings...).... just plug n play.... did i just get lucky? i know my headlight kit pulls from an external power source... maybe mine has the relay built in? i'll look to see what brand mine are...
2009 titan 40surv
Old 10-25-2007, 05:23 AM   #24 (permalink)
LRCanon's Avatar
Yeah, some kits do have a capacitor or resistor built into them, you may be one of the lucky ones!
Powered by vBulletin® Copyright ©2000 - 2012, vBulletin Solutions, Inc.
