TSB's for the 6.7l's - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > 07.5 and Up 6.7 Liter Cummins > 6.7 Liter General Discussion
6.7 Liter General Discussion General Chit Chat About the 6.7L 3rd generation Cummins - NO ADVERTISING
Old 06-17-2007, 08:48 PM   #1 (permalink)
avid's Avatar
Anyone know where to find them?
avid is offline   Reply With Quote
Old 06-18-2007, 10:19 AM   #2 (permalink)
gww
gww's Avatar
Sorry, what's a tsb?
gww is offline   Reply With Quote
Old 06-18-2007, 10:24 AM   #3 (permalink)
FTE Diesel
BBRam's Avatar
iTrader Score: 13 reviews
Technical Service Bulletin I believe.
Floor It CP3 MOD's & PPE Dual Fueler Kits
6.7 Race / Delete Pipes and Sims in stock!
Old 06-18-2007, 10:26 AM   #4 (permalink)
FTE Diesel
BBRam's Avatar
There may be something for you here.
http://www.cumminsforum.com/forum/te...ecall-support/
Old 06-18-2007, 03:19 PM   #5 (permalink)
Company Name
TSB 18-009-07 Latest 6.7L Cab and Chassis
TSB 18-033-07 Latest 6.7L Regular
Buddy Kunz
Not With Bully Dog Anymore
Bud Kunz is offline   Reply With Quote
Old 06-18-2007, 08:34 PM   #6 (permalink)
avid's Avatar
Is there a description of what these cover?
I'm going in tomorrow for the new flash. The guy at the counter was saying it's pretty big and was taking a while to download it to the module used to flash them. He wasn't the tech, so not sure if it's true or not, but they seemed like pretty decent guys. It's closer to work than the place I bought it from, and their customer service seems better too
Old 06-18-2007, 09:26 PM   #7 (permalink)
avid's Avatar
this is the best I've found for a description
Service Bulletin ("New" FLASH) of 6/12/'07 - TDR Roundtable
Old 06-20-2007, 01:22 PM   #8 (permalink)
Company Name
This is from revision A of 18-033-07 but the other one for the cab&chassis says the same thing.
SYMPTOM/CONDITION:
The vehicle operator and/or technician may experience one or more of the following
conditions and/or enhancements:
1. The technician may not be able to reprogram (flash) the PCM with new
application software.
2. ** The vehicle may fail an Emission Inspection Maintenance (I/M) Test because two or
more On-Board Diagnostic (OBD) monitors report that they are not ready for testing.
This condition may cause the customer vehicle to not pass an Emissions I/M test. The
following is a list of OBD Monitors that may report as not ready for testing:
a. Non-Methane Hydrocarbon (NMHC) Catalyst Monitor.
b. Nitrogen Oxide (NOx) Absorber Monitor.
c. Exhaust Gas Temperature Sensor Monitor.
d. Electrical Charging System Monitor.
e. EGR System Monitor.
f. Oxygen Sensor Monitor. **
3. ** After extensive idling of the vehicle engine or if an intake air leak is present, the
vehicle operator may experience a MIL illumination and/or an Electronic Vehicle
Information Center (EVIC) message alert due to one or more of the following DTC's:
a. P1451 - Diesel Particulate Filter System Performance.
b. P2463 - Diesel Particulate Filter - Soot Accumulation.
c. P242F - Diesel Particulate Filter Restriction - Ash Accumulation. **
4. The vehicle operator may experience a MIL illumination due to one of the following
DTC's:
a. ** P0106 - Manifold Absolute Pressure Sensor Performance. **
b. P242B - Exhaust Gas Temperature Sensor Circuit Performance - Bank 1 Sensor 3.
c. P245A - EGR Cooler Bypass Control Circuit - Open.
5. An intermittent rough engine idle and/or white smoke following initial engine start.
6. A throttle tip-in stumble at engine speeds of 1,300 to 2,100 rpm.
7. An engine hesitation at altitude of 5,000 feet between engine speeds of 1,200 to 1,600
rpm.
8. A turbocharger “chuff-like” sound during rapid deceleration.
DIAGNOSIS:
1. Connect the StarSCAN® to the vehicle Diagnostic Link Connector (DLC).
2. From the “Home” menu, select:
a. “ECU View”.
b. “PCM Powertrain Control Module”.
c. “View DTC's”.
3. Record DTC's that are present in the PCM.
4. Are any of the following DTC's present: P1451, P2463, or P242F?
a. If YES >>> then Section C - Exhaust System Aftertreatment Regeneration must be
performed AFTER Sections A and B (reprogramming the PCM for bootloader and
application software) of the Repair Procedure have been completed. Read the
following Cautions and Notes, then proceed to Section A of the Repair Procedure.
b. If NO >>> then Section C - Exhaust System Aftertreatment Regeneration should
NOT be performed. Read the following Cautions and Notes, then proceed to
CAUTION: Before the application software can be reprogrammed (flashed) into the
Powertrain Control Module (PCM), the PCM must first be reprogrammed
(flashed) with “bootloader” software. Failure to reprogram the PCM with
the “bootloader” software first, may cause the process of reprogramming
the PCM with the application software to fail. The PCM “bootloader”
software special flash procedures must be followed closely to prevent
damage to the PCM.
Buddy Kunz
Old 06-20-2007, 04:56 PM   #9 (permalink)
avid's Avatar
I've had this problem 3 times on mine. Hasn't happened in a few hundred miles though
Thank you!
Old 06-20-2007, 07:55 PM   #10 (permalink)
I know you have to get that flash for the new bully dog chip and it only takes about a 1/2 hour to do. I just got it yesterday.
Dskin86 is offline   Reply With Quote
Old 06-20-2007, 10:42 PM   #11 (permalink)
avid's Avatar
my dealer was having trouble with their star-scan. it makes them download the update each time (instead of saving it) and that was taking them ~ 2 hours.
The TSB does allot for a few hours, so you must have been lucky. They weren't able to flash mine the other day because of the star-scan unit, so hopefully later this week or next.
Old 08-03-2007, 08:32 PM   #12 (permalink)
I Bought the bully dog power pup for the 6.7 and nothing but problems!
`I have had nothing but Troblem from the new 6.7 power pup. Fist time i tryed it had a error of ( unknown vehicle 52305000AN ) so I call the tech and they said i needed the newest upgrade 2.0.8 - so i got it and still doesnt work - so i called them back and they said you need the TSB - 18-033-07 so i called my dealer and had them schedule it- Guess what still didnt work but had a new error code ( unknow vehicle 52305000AR ) so i called them back and they told me the dealer didnt install it. So i went and drove 2 Hours to a different dealership and had them install it and Guess what- Still DOESNT WORK !!! and still the same error code -can someone HELP ME !!
CumminsMonsterTruck is offline   Reply With Quote
Powered by vBulletin® Copyright ©2000 - 2012, vBulletin Solutions, Inc.
