Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7 Liter General Discussion
6.7 Liter General Discussion General Chit Chat About the Future Cummins Diesel Nut Motorsports
Old 10-13-2009, 03:02 AM   #1 (permalink)
robinson2070's Avatar
Another voltage drop?
Today, for the first time since I've had the truck i got the voltage drop that many have talked about. The voltages went up higher than 14 which was strange and then dropped back down alot ( in about 10 second intervals). My lights dimmed and everything. The weird part is I had to sit and weight for the heater to warm up before I started and this morning it was near 60 degrees. What's even weirder is the first crank it was like my battery was dead, the second crank the truck fired but it shut back off after about 5 seconds. Tried to start it again, wouldn't start just sat there and cranked. Gave it a minute and the thing fired right up like no problem at all. But I did Get a CEL. Does anyone know what this could be?
robinson2070 is offline   Reply With Quote
Old 10-13-2009, 09:23 AM   #2 (permalink)
I am not sure about your CEL, you will need to find the code for the CEL. This will tells us what the issue is.
Per your owners manual the GRID heaters will become active at 60F and lower. You need to wait before starting your truck until the grid heater symbol is off. You can then start the truck and the grid heater will cycle on and off until either of these events occur. One the engine is warmed up enough for the grid heater to turn off. The other condition that will turn the grid heater off, is to engage the transmission and drive.
There is a lot of information in the O and M guide that will help you own and operate your CTD.
2008 3/4T, Mega Cab SLT, 6.7L CTD 68RFE,Optix Gauges Pyro, Boost, Trans Temp A Piller mount, Mag-Hytec Trans Pan, Front & Rear Diff cover,Smarty, MBRP Exhaust, Silver, Westin Side Steps, Line-X Bed Liner, Bed Cover, Prodigy BC, 15K Reese hitch and pulling a 11K 5er
Jim W is offline   Reply With Quote
The Following User Says Thank You to Jim W For This Useful Post:
robinson2070 (10-13-2009)
Old 10-13-2009, 09:52 AM   #3 (permalink)
For a good time- Smarty
dad2bike's Avatar
Pretty much covers it. Good post.
Tom
2008 Quad-Cab,LB, 2500, 6.7L, 4X4, White/Kaki, Big-Horn, 3.73 Auto, AS flash, K&N Air Filter, no baffle, Testing in progress- step 4, Stealth DPF, Smarty sw3 PMT gauges. Mag-Hytec Pan & Diff covers.Toms smarty Journal ....... DIY Deletes How-To
Stealth is the WORD!
dad2bike is offline   Reply With Quote
Old 10-13-2009, 10:30 PM   #4 (permalink)
that's what baffled me is that the grid heater symbol was off went I started it the first time.
08' 2500 6.7L CTD Laramie, Black, Automatic, mainly stock, EGR Unplugged, DPF/EGR gone!!. Straight Piped.
Old 10-13-2009, 10:33 PM   #5 (permalink)
Thanks for the help though guys. The CEL has went off by itself since then. I guess it quiting on me was just a flub. I'll let you all know if it happens again.
Old 10-16-2009, 02:20 AM   #6 (permalink)
well, it happened again this morning. did my normal thing, waited for the grid heater symbol to go off. Tried to crank the truck and it acted as if the battery was dead, waited a few seconds until it got closer to 14 volts and it started up. It ran for a whole about 3 seconds, and the truck shut itself back off. Tried to start it back up and acted as if the battery was dead again. Waited a few more seconds for the batter needle to climb a little closer towards 14 and the thing started right up and stayed running. It's like when the grid heater is on it sucks out all my battery life or something. Do I have a bad battery or could it be somethin else? Thanks for the help guys?
Old 10-16-2009, 02:27 AM   #7 (permalink)
Espeefan's Avatar
You could very well have a bad battery. The best way to figure that out would be to load test each one, separately. Be sure to disconnect the cables that tie them parallel to one another. If you don't have a load tester, check around for a battery retailer, or auto parts store that might be able to do the tests for free. Or take it to the dealer.
One bad battery will definitely drag down a good one. I hear these trucks are really sensitive to low voltages.
That's the first place I would look.
Also, just a little tid bit. Ocassionally the heater grids will cycle a short while, even on warmer days then 60 degrees. Just kind of depends how cold the previous night was, how long since the truck was started, and other little variables. In 60 degree weather, you really don't need to let the grid cycle at all, if you don't want. If you have a bad battery, starting the truck as soon as you put the key in, to avoid the heat cycle should result in a fast start up, if one or both of the batteries are getting dragged down to much by the current draw of the heater grid. Let us know what you find out.
2001.5 Ram, 24 valve H.O. Cummins 6 speed manual, 4x4
2009 Ram, 6.7 Cummins, 6 speed manual, 4x4
Espeefan is offline   Reply With Quote
The Following User Says Thank You to Espeefan For This Useful Post:
robinson2070 (10-16-2009)
Old 10-16-2009, 11:16 PM   #8 (permalink)
Yeah, I already changed one battery a few months ago I guess it's time to change the other one. That's all It is I'm pretty sure. Thanks for the help.
Old 10-16-2009, 11:32 PM   #9 (permalink)
kevinc2004's Avatar
You should change the batteries at the same time. If one is dying from old age, The other one is not far behind it. As soon as I get my first slow start, I will replace both batteries in my 2007 with the largest ones that will fit in the boxes.
2007.5, 6.7 turbo 3500 drw 4X4 (6X6)quad cab longbed. Bone Stock
kevinc2004 is offline   Reply With Quote
The Following User Says Thank You to kevinc2004 For This Useful Post:
robinson2070 (10-17-2009)
Old 10-17-2009, 10:55 AM   #10 (permalink)
ken white's Avatar
Check and clean your battery and ground connections too...
__________________________________________________ ______________________________
2008 Quad Cab 3500, 4x4, Long Bed, DRW, G56, 3.73's, Line-X, P3, lots of camper upgrades...
ken white is offline   Reply With Quote
The Following User Says Thank You to ken white For This Useful Post:
Old 10-17-2009, 06:17 PM   #11 (permalink)
Ok, Thanks for the help guys I'm gonna clean my terminals and such and wait for another cold start to see if it happens again, If it does i'll just get another battery. If it still does it then I'm not done with you all yet haha.
Old 10-17-2009, 10:19 PM   #12 (permalink)
Always replace batteries in pairs and promptly one bad battery can kill the other.that kinda sucks when you are in the middle of a cow pasture and alone
1:07 3500 6.7L G56 4x4 dually quad cab 2"hbs leveling kit DPF-R gutted downpipe converter & qaudzilla boost fooler,255/80/17 bfg km2's
2:07 3500 5.9L auto 2wd dually mega cab silencer ring mia
48kenworth is offline   Reply With Quote
The Following User Says Thank You to 48kenworth For This Useful Post:
robinson2070 (10-18-2009)
