Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7 Liter General Discussion
6.7 Liter General Discussion General Chit Chat About the Future Cummins Diesel Nut Motorsports
Old 10-17-2009, 10:29 PM   #13 (permalink)
Ditto on replacing batteries in pairs. I've heard the above story play out many times with only one battery changed.
Connections can produce similar behavior, but if they are cleaned and tightened properly while changing both batteries, chances are it will put this type of issue to rest.
Charlie
RegenerationCompleted is offline   Reply With Quote
The Following User Says Thank You to RegenerationCompleted For This Useful Post:
robinson2070 (10-18-2009)
Old 10-18-2009, 03:14 AM   #14 (permalink)
robinson2070's Avatar
haha yeah kenworth I'd say so, One more thing, this is kind of off subject but a buddy of mine told me that on a duramax that you can only jump off of one certain battery, (the left or right I'm not sure), but he said that if you jump off of the wrong battery it can harm your ecm and other stuff. Is there any truth to this?
08' 2500 6.7L CTD Laramie, Black, Automatic, mainly stock, EGR Unplugged, DPF/EGR gone!!. Straight Piped.
robinson2070 is offline   Reply With Quote
Old 11-02-2009, 08:55 PM   #15 (permalink)
carisu's Avatar
Cool, I had this same problem too with the voltage drop (not the engine shutting down on its own) and found this thread in a search. One more question though, once the engine is running and the grid heaters kick on will I see the light on the dash or does it not come on when the engine its running? Thanks!
2007.5 Dodge Ram 2500 Quad Cab 4X4, 6.7L Cummins, DPF, EGR, butterfly valve deletes, Edge w/attitude, B&W flip over ball
carisu is offline   Reply With Quote
Old 11-03-2009, 03:13 AM   #16 (permalink)
Espeefan's Avatar
The heater grid symbol, on the dash, only lights up as the truck preheats the intake, just before start up. It won't come back on, after the truck is running, but you will probably hear the relay click on and off, you may see the lights dim a little, and you will probably notice a drop on the voltage gauge.
2001.5 Ram, 24 valve H.O. Cummins 6 speed manual, 4x4
2009 Ram, 6.7 Cummins, 6 speed manual, 4x4
Espeefan is offline   Reply With Quote
Old 11-03-2009, 10:46 AM   #17 (permalink)
inthenorth6.7's Avatar
"The other condition that will turn the grid heater off, is to engage the transmission and drive. "
mine still cycles while driving, lights dim etc.. is that abnormal then?
inthenorth6.7 is offline   Reply With Quote
Old 11-03-2009, 12:19 PM   #18 (permalink)
Espeefan's Avatar
That isn't abnormal at all. Both of my trucks will continue to cycle the heater girds, even while driving. I've had the heater grid kick on, even after the truck is fully warmed up, and I've slowed down to about 20-30 mph, at lower engine RPMs. Quite normal.
