if your not noticing any knocking or missfiring i wouldnt worry about it,
ive done injector performance tests on brand new trucks and have seen those numbers, they vary with engine temp...
i have also done that test with 2 bent pushrods on the same cylinder and have seen 88% - 90%,
do not trust that test, only use it with other ways to determine faulty injectors...
but like mopar-mechanic said in the other post, re-check your valves....
03 Ram 3500 4x4 Q/C 6 spd SRW Conversion, South Bend Clutch, BD X-Tuner, BD X-Power, BD Super B Turbo, Stage 1 CP3, Intake, Exhaust, 17" KMC Spy's
