Hi Stomp
What did you do t install the 370's, as Iwas told here the lines would not bolt up? I was also told also that the Ve pump would not run the 370's due to different POP pressures? Did yo umodify the injectors or pump for pressure?
Are you running two different sets of lines depending on injector?
What is the 14mm head and rotor off of? Is it readily available? and a striaght bolt on?
I probably have more questions but that will do to start ;o)
Thanx in advance for your time
Ken
Done.Almost, lol:93 5.9 cummins motor, hx35, hx55 twins, POD injectors, water to air intercooler, and air to air aftercooler, BOV, in-cab fully adjustable dual wastgates, alcohol/water injection, C6 full manual pullin tranny, Ford F350 1-ton 4x4 pullin machine.
