After you reset the voltage you must. relearn the ecm, as follows. Turn key to on position then push petal to floor slowly and let up slowly. I do this 3 times. If you end up needing a relacement sensor I can help you out, but I won't any for a week or so.
Anatomy of an APPS - the SEQUEL! - TDR Roundtable
2001,QC,SB 5sp,smarty,drag comp,SB con OFE,HTT62/12,aeromotive A1000 fuel pump,4"
magna flow,isspro,FP,pyro,boost gauges. 522hp/1027tq!
