Originally Posted by mibgron
I order a pumpkit to my 04.5 but when i start install it doesn't fit any well, it was to a 05 year, do I have to remove this stock pump on the filter or will the new pump push straight through the old one.
NO....it will not work pushing through the stock pump....give me you SN and STOP the install. You need to inventory the kit before you started the installation.
Chances are that your dealer sold you the wrong kit. What is the part number they sold you? Should be on the box. You need a 1003 Kit…..for a 98.5-04.5 year truck
Dan MacDonald
www.FASSRide.com
2001 2500, 4x4, Con OFEed, TBK, AFE Stage II kit W/ prefilter and 4" cowl mod. , FASS 150/150, Mach 2's, Drag Comp,
Currently running on B-100
'02 Jetta TDI 5 Speed "Mini Me" 45-50 MPG
