Originally Posted by Racing4funn
It unhooked and plastic bagged because I have the FASS hooked up but its pushing very little fuel out and is always wet with fuel. I think the tank is pressurizing and pushing a small amount. If this is the case then this summer with more heat is going to make it worse.
Did you drain the filter head using the water drain? I bet that is your issue. Fuel will slosh with stop and go driving.
Dan MacDonald
www.FASSRide.com
2001 2500, 4x4, Con OFEed, TBK, AFE Stage II kit W/ prefilter and 4" cowl mod. , FASS 150/150, Mach 2's, Drag Comp,
Currently running on B-100
'02 Jetta TDI 5 Speed "Mini Me" 45-50 MPG
