My BHAF was getting sorta grungy on the outside:
UGHHHHhhhh!
SO, time to see what was needed to get the intake back up to snuff. Took off the Outerwears, revealing the underliner my wife sewed up for me while I waited for the Outerwears to arrive - I had also applied some K&N filter oil to that liner that was left over from my K&N filter days:
HMMmmm - not bad, but not good either - better pull it off too, and check out the actual NAPA BHAF filter media to see what it looks like:
WOW! Not bad at all - in fact, it looks as clean as when it came out of the original box!
OK. so a look around in the BHAF mount area turned up this surprise:
A closer look:
HMMmmmm - a contact point of wear, a "dimple" where the end of the BHAF has rubbed into the air conditioning line - not good!
(MORE BELOW)
White '02 Quad cab, NV5600, GAUGES! Comp, Walbro, DTT SS intake, Rip's 4 in. exhaust, Don M's 1.6's, DSS, Frantz oil bypass & fuel filters, Amsoil air filter, MOBILE Ham Radio-IC-706, 600 watt amp, '88 Kit 24 ft. 5er, 418 HP/978 Tq., 24 ft KIT 5er.
