Originally Posted by mattpopp
What do recommend for a 6.7. I would say within the next six months I should have about 500hp on the ground, at least that is my goal. by the end of next week i should be at about 460hp on the ground. Thats going to be down loader, Module, and a set of injectors(in a few months on those). I would like to run a 2 micron filter. the water seperator is not such a issue for me. I see alot of people run a 150/150, is that over kill?
The FASS 95/95-1007 Can hold up to about 600 HP. Our 95 series is going to come standard with a 3um filter starting last week. But if you wanted to, you could run the 150 GPH without issue.
Originally Posted by Dieseldust21
would go with the airdog and not the FASS. The Fass is old technology the Airdog is new technology and seperates air way better.
You come on to our vendor thread and post an idle comment like this; I imagine you can back that up with details?
Dan MacDonald
www.FASSRide.com
2001 2500, 4x4, Con OFEed, TBK, AFE Stage II kit W/ prefilter and 4" cowl mod. , FASS 150/150, Mach 2's, Drag Comp,
Currently running on B-100
'02 Jetta TDI 5 Speed "Mini Me" 45-50 MPG
