Old 03-09-2008, 10:10 AM   #12 (permalink)
CharlesD
The verdict is in. I worked on the pump last night. First I placed a piece of rubber between the pump and where it was touching the sheet metal. This seemed to help a little but not much. I proceeded with the 5 gallon bucket test in attempt to detect blockage between the tank and pump. The pump was just as loud when isolated. I had lost hope but then it dawned on me to do the bucket test with the pump dismounted from the bracket. This made a noticeable reduction in noise. I took a can of rubberized undercoating and sprayed the inside of the bracket and the bed sheet metal where the pump was touching and where the bracket mounts. I also placed strips of rubber around the pump and between the pump and the sheet metal. Lastly I placed rubber boots on the mounting bolts. After all of this, it seems to be noticeably quieter although still louder than FASS pumps owned by friends, but more tolerable.
2000 Quad Cab Short Bed, Black, 5 Spd., Tint, Silencer Ring MIA, 4" Exhaust w/ 5" Tip, Muffler & Cat MIA, 34 PSI Boost, FASS 95, Fuel, Pyro, Boost Guages, Eagle Alloys w/ 33x12.50 Mud Terrains, AFE BHAF, Qaud XZT+ Aggressive Tune, Sport Conversion
CharlesD is offline   Reply With Quote
