Dodge Cummins Diesel Forum - View Single Post - Hey Fellas......It's Christmas!...Look what I found!
Old 04-20-2012, 11:59 AM   #95 (permalink)
TonyB
I just got my kit yesterday.
Starting to put together a parts list:
2) Adapter, -6JIC x 12mm
4) 3/8 pushlock x -6 FJIC, 90 degree
2) 3/8 Tube Compression x 3/8 F-NPT (Local hardware store)
2) 3/8 M-NPT x -6 JIC
4') Fuel hose - 4' is a conservative estimate
Anything I'm missing?
I'm also planning to tie the heater relay into the factory heater, as previously mentioned.
The kit mentions replacing the fuel pump module. Anyone have any background on this? Everything I've read indicates this isn't necessary. I figure I've got 57k miles so the factory pump should be sufficient. I also have a fuel pressure gauge and read 9-10 psi at idle, and ~5psi at WOT.
Thanks!
Tony
1996 VW Passat TDI; Avg 43mpg
2006 VW Jetta TDI; Avg 35mpg
2006 3500 Dually, QC, LB, Laramie, Gauges 16.3mpg, last checked fwy mpg.
TonyB is offline   Reply With Quote
