Front End Grinding??? When turning sharp - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > General Forums > Suspension Discussion > 4wd Suspension
4wd Suspension 4wd Suspension Systems, Shocks, Springs, and More!....NO ADVERTISING!
Old 12-04-2012, 07:28 AM   #1 (permalink)
Ok guys,
At first I thought it might be the lugs catching and slipping in the snow and ice as it only does it when turning sharp and driving slow ie...turning into a parking stall. After hearing it this morning I would like to get some opinions and see what your thoughts are. If it isn't the tires what would be making the noise, front wheel ujoints?
Sent from my iPhone using AutoGuide.com Free App
2008 Dodge Ram 3500 Big Horn Laramie Mega Cab Fabtech 4" Lift Kit c/w 35" Tires on 20" rims 6.7L. H&S Deletes and Black Maxx Tuner yet to be installed
99blackrt is offline   Reply With Quote
Old 12-04-2012, 08:45 AM   #2 (permalink)
I'd say axle u joints. Just a guess
Sent from my DROID X2 using AutoGuide.Com Free App
06 2500 5.9....G56,Valair DD ceramic,EFI,5in TB Straight,AFE Mega,CFM+,AirdogII,Pacer Smoked,EV2s,3" Carli,285/75-18 Toyo A/T,18" Pro Comps,6k HIDs
2011 CRF450....450B, Yosh, Decal Works, Cernics
Dodge238 is offline   Reply With Quote
Old 12-04-2012, 12:50 PM   #3 (permalink)
Unit bearings or the ^
2011 Ram 2500 Longorn..... 3in Carli Coils, Thuren Track Bar, Carli End-links, 5100's and 33's, Carli 7100 Steering Stabilizer, Carli Skid Plate,Carli mini-pack
and deletes waiting on my lazy you know what to get'er done......
vwp6269 is offline   Reply With Quote
Old 12-04-2012, 01:45 PM   #4 (permalink)
Suspension Specialist
Craig@StraptPerformance's Avatar
U-joints or hubs. If it was you're carrier, you'd be hearing it at all RPMs.
Put the front axle on jack stands and spin the tires. They should be quite. If you here a slight grind or even a rumble/crumble, it's your hubs. If they are quite, turn the wheels to one side and while spinning the tires, take a look at the U joints and see if you can notice any play. A dead give away on the U-joints (though not a definitive answer) is if you see any fresh grease or if the rubber on the joint caps has started to separate or crack. You can also put a pry bar on them to see if they have any additional play.
Craig @ STRAPT Performance - (602)773-6668
Specialized in installing of all things cool, especially Thuren and Carli products!
Carli | Thuren | King | Fox | Bilstein |Borgeson | BD | PSC | Mopar | Dynatrac | Moe's Custom Tie Downs
Toyo | Yokohama | Nitto | Falkin | Method | TrailReady | MHT | Fuel | KMC
FREE shipping on all suspension kits!
Click here to find us on Facebook!
Craig@StraptPerformance is online now   Reply With Quote
