How do you jack up a lifted truck? - Dodge Cummins Diesel Forum
4wd Suspension 4wd Suspension Systems, Shocks, Springs, and More!....NO ADVERTISING!
post #1 of 20 (permalink) Old 09-20-2012, 08:14 PM Thread Starter
iTrader Score: 10 reviews
Hey guys, I'm looking into re-doing my rear leaf springs (sagging) and possibly adding a 1/2" coil spacer up front to my current lift.
How do I safely go about jacking up the frame? My floor jack won't go that high.
Also, I'm trying to decide between add-a-leafs and a shackle drop. Do I need to worry about driveshaft angles with a shackle drop?
1996 2500 CCLB 4x4, 3.54, 47RE
wcbcruzer is offline
post #2 of 20 (permalink) Old 09-20-2012, 08:18 PM
sredish's Avatar
Jack up under the axles or point where ever u can then use jack stands under the frame. Then let off the jacks where needed.
2007 MegaCab - Suspended by Thuren, rollin' 37s. Sharadon Stage III trans, Solteks and REAR A/C.
sredish is offline
post #3 of 20 (permalink) Old 09-20-2012, 10:06 PM
Suspension Specialist
Craig@StraptPerformance's Avatar
Stands under the frame, jack up under the pumpkin and slide in your stands. From there, take off the wheels and droop out the axle. Move the jack to whatever side you are going to be working on with a jack stand on the other side and use the jack to lower the axle enough to get your blocks or whatever you will be working on taken care of.
Use 6 ton jackstands on the frame. They're bigger, studier and taller. 3 ton jack stands just don't cut it for workin on leafs without putting the axle on the ground... especially if you have some lift.
Craig @ STRAPT Performance - (602)773-6668
Specialized in installing of all things cool, especially Thuren and Carli products!
| King |
| Bilstein |
| BD | PSC | Mopar | Dynatrac
Toyo | Yokohama | Nitto | Falkin |
| TrailReady | MHT | Fuel | KMC
FREE shipping on all suspension kits!
Craig@StraptPerformance is offline
post #4 of 20 (permalink) Old 09-20-2012, 10:17 PM
ramsport59's Avatar
I love my Bumper Air Jack....Slid it under the hitch and up we go. Wish it would lift the heavy cummins tho.
Rick
01 2500 II PhatShaft 62/14, Edge Juice & DAP 150s, HD Transmission, Single Disc Convertor, Raptor 100, 4" Turbo Back Exhaust, BHAF, 4.10s with 35's...
ramsport59 is offline
post #5 of 20 (permalink) Old 09-20-2012, 11:27 PM
sredish's Avatar
Rick
what is the point if you can't lift your diesel truck...?
sredish is offline
post #6 of 20 (permalink) Old 09-20-2012, 11:41 PM Thread Starter
Ok what if I filled two 5 gallon pails up with concrete and set my jack stands on top. Good idea or bad idea?
Or would it be better to make a 12" tall platform out of wood?
post #7 of 20 (permalink) Old 09-21-2012, 12:03 AM
sredish's Avatar
do you know how to crib wood? like 2x4s or 4x4s...? there's a rating for wood and cribbing and it's quite strong. every bit as strong or stronger than concrete in some cases.
or just spend less than a couple bills on some proper jackstands.
10 Ton Jack Stands (Set of 2)
or slightly taller
http://www.gregsmithequipment.com/10...Stand-Set-of-2
sredish is offline
post #8 of 20 (permalink) Old 09-21-2012, 12:03 AM
Cribbing can be pretty stout if ya do it right.... which since your suggesting it, I'm going to assume you know the do's and don'ts.
Personally, I don't like concrete because its failure isn't slow. At least metal bends and wood squishes.... concrete just goes boom!
Sent from my DROID4 using Tapatalk 2
| King |
| Bilstein |
post #9 of 20 (permalink) Old 09-21-2012, 12:14 AM Thread Starter
Safety is my number 1 concern. I kinda liked the idea of cribbing because I have these powerbuilt bottle jack stands that would allow me to raise or lower the frame at will (without axle attached), but after thinking about it I probably won't need to anyway. So I guess I'll pick up a pair of high jack stands and call it a day. Seems to be the safest (and easiest) option.
Thanks for all the input guys. Some great ideas in here that gets the mind thinking.
post #10 of 20 (permalink) Old 09-21-2012, 12:16 AM Thread Starter
Oh kinda off topic but do you think 30" is enough frame height to be able to drop both axles?
Just wanna be sure..
post #11 of 20 (permalink) Old 09-21-2012, 12:25 AM
sredish's Avatar
Just measure your frame height at ride height and figure how high you'd lift to get up in air and figure which stand you'll need. I like the truck to be up high when I'm working on it.
sredish is offline
post #12 of 20 (permalink) Old 09-21-2012, 12:26 AM
On a second gen, you actually don't need as much height as a 2003+ because of the lack of droop in the front from the upper control arm mount and shackle mounts in the rear. That in mind, 30" is more than plenty.
I've used HF 6 Ton jackstands size I was old enough to drive and never had a single problem... plus they're very affordable.
| King |
| Bilstein |
