2500 front end trouble - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > General Forums > Suspension Discussion > 4wd Suspension
4wd Suspension 4wd Suspension Systems, Shocks, Springs, and More!....NO ADVERTISING!
Old 02-23-2008, 07:11 PM   #1 (permalink)
I am looking for some suggestions on the front end of my 2004 2500 Dodge
Less than 1 year ago I replaced all 4 ball joints on this truck because it was chewing tires up and the ball joints had a lot of play. I might mention that the truck only had 60k on it at that time. I started getting tire wear again and in less than 1 year I have a bad lower ball joint again. (80k miles now). I also have a front hub that bearings are out of on the other side.
I have been checking and it appears that Dodge is using the same ball joint in the 3/4 ton Diesel that they are using in the 1/2 ton gasoline trucks.
I love my Cummins diesel but I am sick of the weak front end on this truck . Does anyone know of an upgrade or after market kit I can put on this piece of junk to beef it up so I do not go broke putting ball joints and tires on it ? And how about the hubs any suggestions on them ?
I am about ready to get rid of the Dodge and get a Ford Powerstroke the way this thing is going.
HELP I DON'T WANT TO HAVE TO DRIVE A FORD AGAIN !!!
2004 6 speed 2500 4x4 Dodge Ram Cummins Turbo Diesel
ChunkDodge is offline   Reply With Quote
Old 02-24-2008, 11:52 AM   #2 (permalink)
The answer for the weak ball joints is almost here .Bad Mutha Ball joints - TDR Roundtable
Bob
05 2500 4x4 Carli Dominator 3.0 Suspension Baja proven
94 2500 4x4 Carli performance 2.0 with full leafs
90 wrangler injected locked and caged crawler
bob4x4 is offline   Reply With Quote
Old 02-24-2008, 11:54 AM   #3 (permalink)
Bob
Old 02-24-2008, 12:17 PM   #4 (permalink)
Hot Stuff's Avatar
But when Bob? And I suppose they shoulda be called "exspensive mutha"?
'03 Black 2500 QC/LB 4x4, 6 speed, SB3600 Dual Disc, 2" lift, Raceline Raptor wheels, 305/70 Nitto's, B&W turnover, Firestone bags, 5" str8 pipe, BHAF, 2nd gen intake, BD lift pump, spin on filters, pillar boost & pyro, and Smarty
[SIGPIC][/SIGPIC]
Hot Stuff is offline   Reply With Quote
Old 02-24-2008, 12:30 PM   #5 (permalink)
I don't think they have finalized the price yet,but when you consider only having to do it once the price of the part will be a small part of the equation.
I was really tired of worring about will I get one more trip before the clunking comes back.The huge increase in bearing surface and the hi tech aerospace anti friction coating works for me.
Bob
Old 02-24-2008, 12:34 PM   #6 (permalink)
Hot Stuff's Avatar
Sounds good. I'll be due for some this summer sometime. Hopefully they're out by then.
[SIGPIC][/SIGPIC]
Old 02-24-2008, 01:40 PM   #7 (permalink)
I am of the opinion that Dodge should be forced to do a factory engineered upgrade on these front ends . We should not be having to spend a ton of $$$ fixing front ends on vehicles that are this new. Is there any interest in getting something underway to make this happen ? I am willing to check into what it would take if there is enough interest.
Old 02-24-2008, 01:48 PM   #8 (permalink)
wrench71's Avatar
what tire pressure do you run on the front?
04 2500 4x4 extang tri fold.smarty jr. 5in lift 33's and buit tranny with billet triple disc converter.
wrench71 is offline   Reply With Quote
Old 02-24-2008, 01:48 PM   #9 (permalink)
I doubt there is anything you could do, but it would be worth a look into.
I have replaced all 4 ball joints, front axle u-joints, steering stabilizer, and sway bar end links on my front end. Napa sells ball joints and front axle u-joints that are greasable, that is what I put on mine. I am hoping that if I keep them greased they will last longer.
2004 Dodge Ram 2500 4x4, Black, Laramie, HO 305/555, 48RE, 3.73's, American Racing Rims with 285/75-17's, Lorenz 2" leveling kit, Bilstein 5100 Shocks, Edge Juice w/ Attitude, IceBox Cold Air Intake, 4" Aero Turbine Exhaust, CFM+ Intake, FASS 95/95
04Dodge is offline   Reply With Quote
Old 02-24-2008, 01:50 PM   #10 (permalink)
Hot Stuff's Avatar
That'd be nice but kind of a pipe dream getting chrysler to do anything. I to hope that greasable ones will last longer. That's what I'm gona probly put on mine when I hafta do them. Unless those "bad mutha's" are out. might try them if they're not TOOOO much.
[SIGPIC][/SIGPIC]
Old 02-24-2008, 02:47 PM   #11 (permalink)
I run 65 PSI with a 265 75 17 Firestone Destination MTR
Old 02-24-2008, 02:59 PM   #12 (permalink)
I put the MOOG greasable joints in less than 1 year & 20k miles ago and they are gone already. I do know that the Feds. can force Dodge to do a recall and I think if we could get enough people pushing for it that we can make it happen. I am researching to see if we can make something happen with a petition of some kind if not that then I will find out what we need to do.
I also feel that the lift pump should be a forced recall because when you take it in under warranty they are putting a retro kit on to fix the problem. (why retro it if it ain't a problem and since it is a problem why not do a recall ? )
Powered by vBulletin® Copyright ©2000 - 2012, vBulletin Solutions, Inc.
