Suggestions on Leveling - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > General Forums > Suspension Discussion > 4wd Suspension
4wd Suspension 4wd Suspension Systems, Shocks, Springs, and More!....NO ADVERTISING!
Old 04-09-2010, 02:12 PM   #1 (permalink)
Cuz
Cuz's Avatar
I installed a 2" leveling kit on the front of my 3500 dually and its not even close to being level so I did some accurate measuring and found I need/want 3.5" but can only find 3"... Is there any way I obtain that extra 1/2" and is there anything else I need to be concerned about when going with 3.5" of lift using just spring spacers?
Thanks
Cuz
2006 Dodge Ram 3500 4x4 Quad Cab Dually LB 5.9L Diesel, 3" Thuren Front Spring Kit, Thuren Adjustable Track Bar & Stabalizer, 315/70-17's, Lund Tonneau, Predator Stage II
Cuz is offline   Reply With Quote
Old 04-10-2010, 08:49 AM   #2 (permalink)
Cuz
Cuz's Avatar
Correction, I need a 4" leveling kit, is there such a thing?
Cuz
Old 04-10-2010, 09:03 AM   #3 (permalink)
Not to my knowledge...I have the same truck as you and I installed skyjacker 2.5" coils that replace the factory coil springs in the front and mine sits level. They are called D-25 coils and and IMO that is a better way to level a truck with the front end as heavy as ours. You will need new shocks in the front as well, I installed skyjacker nitros...Good Luck.
06' DRW 4X4, G56, Smarty Jr, Megacannon, 5" Magnaflow TB, Ranchhand, Wet Okole, 22.5 Alcoas, Goodyear rubber, D25 2.5" coils, Skyjacker shocks, B&W, Ameraguard on everything
pearvalley is offline   Reply With Quote
Old 04-10-2010, 09:34 AM   #4 (permalink)
Cuz
Cuz's Avatar
Thank you!
Yes, I already have the Skyjacker Nitro's installed but the 2" leveling kit came up way short of being level.. If I put a jack under the front, I need 2" more and that will give me just a slight 1/2" rake in the front (I dont tow heavy loads anyways)..
My truck had a ton of rake in the front stock so my concern is if I buy the D-25 springs and still come out a little short. Then I may be back looking for that extra 1" to 1.5" again and tearing it apart for a 3rd time to put a smaller spring spacer in it... I guess I wont know until I try it...
Thanks
Cuz
Old 04-10-2010, 09:48 PM   #5 (permalink)
TheBeast's Avatar
You could always take out a spacer or two in the back. If you went anything bigger than a 2'' spacer you'll have to get control arms to keep your tires from hitting the fender
2006 QCSB
TheBeast is offline   Reply With Quote
Old 04-10-2010, 11:57 PM   #6 (permalink)
Alvarado6.7's Avatar
Why not just get some new coils that give u 2+ inches of lift and use them with your front spacers. You'd probably either need new shocks or get a shock mount extension fab'ed up for yours. Just a thought. Not sure what that does to the front end geometry without relocating some things. You would need some drop spacers for the front sway bar at a minimum but maybe alot more, I don't know for sure.
2008 3500 DRW 4x4 QC, 6.7, G56
Completely *UN-Stock
*List of mods available upon request
Alvarado6.7 is offline   Reply With Quote
Old 04-11-2010, 07:37 AM   #7 (permalink)
Cuz
Cuz's Avatar
What if I went past being level with a spring/spacer combo and then raised the rear a little, is there any easy way to just add a inch or two to the rear?
I'm just weighing out all my options here without going with a full lift..
Cuz
Old 04-11-2010, 11:33 AM   #8 (permalink)
CumminStrong's Avatar
Talk to Don at THUREN FABRICATION:
.: THUREN FABRICATION - HOME :.
He has a full 3" spring for a softer ride and he is very knowledgeable about helping you get what you are looking for.
03 CTD 2500 4x4 SWB 6spd / Thuren 3" Coils/ Thuren's 2.5 KING's/ EDS FABRICATION Steering Box Brace/ ISSPro on Pillar /AirDogII 165 / FTE 5" TBE -Resonator SS / Amsoil lube & ByPass110 / Smarty /EMS Offroad Waren Hub Conversion
CumminStrong is offline   Reply With Quote
