True lift with leveling kits? - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > General Forums > Suspension Discussion > 4wd Suspension
4wd Suspension 4wd Suspension Systems, Shocks, Springs, and More!....NO ADVERTISING!
Old 02-16-2010, 04:00 PM   #1 (permalink)
mello03's Avatar
I am looking to go with a leveling kit from Carli or Thuren most likely. Question is, what kind of lift will I actually get from these two leveling kits? Carli told me about 2 3/4 for their 3 inch springs. Any real world feedback on this? I talked to Thuren and obviously since his new coils aren't out yet I guess I won't know for awhile. He isn't sure on the 2010's. Lorenz, I don't know but I see where some are happy and some aren't. Same with Kore. Not ruling a kit out yet. I am about 2.5 inches lower in the front than in the back so I wish there was a 2-2.5 inch coil out there. I really just want to level it and not sag and get into replacing the rear leafs or adding blocks. I don't really want to go with spacers, but that might be my best answer till I feel like dishing out more cash. Any suggestions?
2010 CC TRX 4X4 68RFE 4.10
Carli 2.0 with sway, Bushwackers, Pattonfab Lightbar, Lightforce, AFE CAI, Centerline Grizzlies, 35" MT ATZs, and H&S MM w/OD
mello03 is offline   Reply With Quote
Old 02-16-2010, 04:25 PM   #2 (permalink)
Second Most Important Member
TORK-STIK's Avatar
i installed the 2 inch spacer and my truck sits 1/4 inch higher in the front. you cant see it though. 65$ for the spacers and it looks and drives great. so overall i got 2.25 inches of lift.
2007.5 6.7L THANKS TO, DANS DIESEL PERFORMANCE-EFI LIVE-WALLY@FTE-RICH@GLACIER DIESEL POWER-RANDY ELLIS DESIGN-DON THUREN FABRICATION-POLY PERFORMANCE-S&B-H&S-BFG-GENERAL RED LETTERS-MHP-B&G-FLO PRO-AMSOIL-EDGE-RECON-GENOS GARAGE-HELL BENT STEEL-BILSTEIN
TORK-STIK is offline   Reply With Quote
The Following User Says Thank You to TORK-STIK For This Useful Post:
mello03 (02-16-2010)
Old 02-16-2010, 05:33 PM   #3 (permalink)
I got 2.5" with the kore leveling kit,truck sits dead level and rides better....2003 3500. I had a 1500 that I leveled with daystar spacers that worked good.Depends on what you are looking for
stuthr is offline   Reply With Quote
Old 02-17-2010, 03:36 PM   #4 (permalink)
WUTNOIZE's Avatar
did u guys go for a wheel alignment after installing the kits
1997 3500 Dually 4x4 ,5 spd, 241DHD,410's,#10 Plate,Tuned AFC, Ajustable Boost Elbow, KDP Jigged, , 4" Turbo back, 19.5 Alloy Wheels/245/70R19.5, Level Kit, 5100 Bilsteins,BDD Tracbar/Steer box stab , Poly Bushings, Isspro Guages Pyro-Fuel-Boost1Orig Owner
WUTNOIZE is offline   Reply With Quote
Old 02-17-2010, 06:04 PM   #5 (permalink)
i did because I did ball joints and steering upgrade at the same time
Old 02-17-2010, 06:12 PM   #6 (permalink)
TORK-STIK's Avatar
my truck had just been aligned and it drove straight after level.
Old 02-17-2010, 07:31 PM   #7 (permalink)
WUTNOIZE's Avatar
the tire shop said that the 2 inch level would throw it out cuz of the trac arm. which i think hes right ...Thanks for your answers guys
Old 02-17-2010, 09:21 PM   #8 (permalink)
DustinB's Avatar
the track bar won't affect your alignment in the aspect of tire wear, it'll just throw your axle off center...
2012 Chrysler Town and Kuntry
Twanky Fo's wrapped in wide white walls
lifted 18"s by Two Up Offroad
DustinB is offline   Reply With Quote
Old 02-18-2010, 06:07 PM   #9 (permalink)
mello03's Avatar
Well I think I am gonna go with the Thuren setup but dont' want to spend big money on shocks. Question is can I go with the Be5-6646-h6 shocks or the 6681's. The 6681's say up to 2 or so inches, but if Thurens coils add 3 inches I might need a little more shock. Any thoughts?
Old 02-18-2010, 06:35 PM   #10 (permalink)
TORK-STIK's Avatar
i think you would need more shock than the 6681's. your truck will ride high in the front with 3 inch coils, unless thats the look you going for, california lean. call the supplier of the shocks and see if they can get longer ones.
Old 02-18-2010, 06:39 PM   #11 (permalink)
TORK-STIK's Avatar
a 2 inch level will not throw your alignment off. if its straight before it will be straight after. worn parts will make it out. everything is being done above the axle so as not to change the alignment.
Old 02-18-2010, 11:47 PM   #12 (permalink)
Project Bloody Knuckles
Skyd Ram's Avatar
iTrader Score: 8 reviews
If you go with the 6646's make sure that you get longer front bump stops. Because they have alonger collapsed length, you could easily bottom them out with the soft coils.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Dynatrac
H&S Performance | Flo Pro Exhaust| aFe | S&B | BMF Wheels| Air Dog | Amp Steps
TRUCKBOSS Sled Decks | Spicer | ARP | REV-X | RIGID Industries | LightForce | Baja Designs
888-886-2480
Skyd Ram is offline   Reply With Quote
