37" tire with level kit, how much trimming? - Dodge Cummins Diesel Forum
4th Gen Tire and wheel Discussion of tire and wheel options
post #1 of 15 (permalink) Old 01-06-2017, 11:28 AM Thread Starter
Bambam-x's Avatar
Okay, looking to up size to 37" tires when mine are finally done. Gonna be a 2-1/2" level kit and aftermarket 17x8 wheels with a 0 offset. I know that a positive offset is preferred but already have the wheels. So wondering how much trimming will be required to the inner fender liner and/or fender itself? Probably add pocket flares at this time as well, so not too concerned with the trimming.
Thanks
2011 Dodge MegaCab DRW 4x4 SLT White, 1-1/2" level kit, 285/75R17 Nitto Dura Grapplers on Ultra Goliath Wheels, EFI Live Draconian Tuned, GDP Pro-gate, ARP Studs, Pusher Intake system, GDP Grid Heater Delete, BD Exhaust Manifold, Edge CTS2
Bambam-x is offline
post #2 of 15 (permalink) Old 01-08-2017, 05:30 AM
You will probably have to trim a bit off of the pinch weld.
Ergovation is offline
post #3 of 15 (permalink) Old 01-08-2017, 12:56 PM
BR1
I would put longer control arms on, and with that offset you will still be trimming metal with the longer arms I'm betting.
2010 CCLB Big Horn Auto 4x4 20x9 Cepek Gunmetal 7 Cooper AT3 275/65/20, dynatrac pro-steer's, Carli TracBar, Carli arms, Carli Fox Commuters, Creative Box Brace, 3" Thuren springs, synergy shackle, Tom Woods front shaft, synergy steering, carli lower stablizer
BR1 is offline
post #4 of 15 (permalink) Old 01-08-2017, 01:14 PM Thread Starter
Bambam-x's Avatar
Was planning adjustable arms for sure. Just trying to get an idea of how much interference there will be. Thx
Bambam-x is offline
post #5 of 15 (permalink) Old 01-08-2017, 01:18 PM Thread Starter
Bambam-x's Avatar
What about 35's? Want the 37's but not sure it will work within my goals.
Bambam-x is offline
post #6 of 15 (permalink) Old 01-09-2017, 04:46 PM Thread Starter
Bambam-x's Avatar
One more question, how much trimming with a +20 offset wheel? Less to none from what I've been reading. Any thoughts.
Bambam-x is offline
post #7 of 15 (permalink) Old 01-09-2017, 05:25 PM
I got away with just zip tying the rear of the fender liner back and trimming the small part of the liner that bumps out around the pinch seam. Check out this link 37's on 20's bad rub
2014 CTD 2500 PW7 68RFE CCSB Limited
1baddrop is offline
post #8 of 15 (permalink) Old 01-09-2017, 05:35 PM
Fastest Welder in Texas
QMFB's Avatar
With nothing but a leveling kit, I'd stick with a 35" tire.
04 CCLB 4x4 DRW... 50% over sticks, 10mm CP3, AirDog 4g, 58/65/14 - 75/96/132, 103# springs, HD pushrods, ARP's, Fluidamper, Smarty S-06 tnt-r, ATS Stage 6, FirePunk Anteater STC, 5" one PC driveshaft... Etc. 674hp & 1,369 TQ.
QMFB is offline
post #9 of 15 (permalink) Old 01-09-2017, 05:37 PM
QMFB's Avatar
Plus, unless you do a diff gear swap to at least 4.56 you probably won't be happy with anything 37" and above. Lose power, mileage, and much harder on your drivetrain.
QMFB is offline
post #10 of 15 (permalink) Old 01-09-2017, 05:41 PM
cummin_hot's Avatar
+20 and 35's on my truck stock suspension and no rub. I would think the 37's with a level should be fine, maybe a little trimming of plastic.
2012 2500 Mega Cab True Blue EFI Live by CCS 5" sinister tbe H&S erg delete 35x12.5 Toyo AT2 Backwoods front bumper
cummin_hot is offline
post #11 of 15 (permalink) Old 01-11-2017, 04:13 PM
onewhistle got 37's under his rough country leveling kit without issue
I'm tempted to head this direction as well.
2017 2500 MegaCab 4x4
SoCalAdam is offline
post #12 of 15 (permalink) Old 01-21-2017, 08:26 PM
1ofakind03's Avatar
Thanks
i started on 35s no level with very minor rub at full lock. Then I ran 37s with no level and 18x9 -12 offset fuels. did some minor plastic trimming and i did some pinch weld but not much. on a level i would doubt youd need to do any pinch weld. for reference i sit on 38.5s right now with a 20x10 -24 wheel and 2" level. i cut the whole pinch weld out and some plastic and a bit of fender. still looks factory.
1ofakind03 is offline
