Code P2262 - Dodge Cummins Diesel Forum
post #1 of 20 (permalink) Old 08-16-2013, 05:04 PM Thread Starter
TheShark10's Avatar
Code P2262
I am getting this code P2262 on my 2010 6.7 off and on now and then. Anybody have any idea what it is? I have the Edge Juice with Attitude and it reads P2262 Turbocharge boost Pressure not detected-mechanical. Can anybody give me some feedback on this before I take it into the dealer? Thank you.
TheShark10 is offline
post #2 of 20 (permalink) Old 08-18-2013, 11:44 AM
#40Fan's Avatar
Dirty map sensor.
2011 2500 CC ST G56 LB MM 5" Flo-Pro 463
#40Fan is offline
post #3 of 20 (permalink) Old 08-18-2013, 12:29 PM
samson 6.7's Avatar
Mine threw the 2262 when the turbo was all sooted up, Dealer replaced it and all was good.
08, 6.7, QCSB, 373'S, G56 SWAP, SBDD 3250, SOURCE 2ND GEN 467/83/.9, STEEDSPEED, 5'TBE, ARP 425, GDP INTAKE, GRID DELETE, RAIL PLUG, CCV DELETE, S-67[23ME], INSITE CTS, 2' LEVELED, 35X12.5X17 MT'S,
samson 6.7 is offline
post #4 of 20 (permalink) Old 08-18-2013, 02:23 PM
lonestarwelder's Avatar
How many miles on your truck? I got that code shortly before the truck went into limp mode. Took in truck to dealer and they cleaned turbo (big waste, but factory makes them do that before they replace turbo). Two months later turbo gets replaced and runs like new.
2015 3500 DRW Laramie CCLB 68RFE 4.10 4x4.
Cooper LT255/70R17 ST Maxx and 2" Stahl Steel spacers. 1.5" Traxda leveling kit. Mag-Hytec rear cover with 75/110 Amsoil.
SOLD:2010 3500 DRW Big Horn CCLB Auto 4x4.
lonestarwelder is offline
post #5 of 20 (permalink) Old 08-22-2013, 01:18 AM Thread Starter
TheShark10's Avatar
I'm at 44k miles. I just got the call from the dealer to pick it up. They said they just cleaned the turbo. Hoping its all good and there's no lose of power.
post #6 of 20 (permalink) Old 08-22-2013, 01:23 AM
Don't wonder too far, the turbo is on borrowed time.
How often do you use the exhaust brake? The EB needs to be ran all of the time to keep the turbo from failing prematurely.
post #7 of 20 (permalink) Old 08-22-2013, 01:39 AM Thread Starter
TheShark10's Avatar
Hardly ever! Didn't know that! I'm sure that my Edge with Juice isn't helping either with soot buildup. I don't have any deletes on the truck either.
post #8 of 20 (permalink) Old 08-22-2013, 02:19 AM
Code P2262
So I took my truck in for this code and Dodges fix was to clean the turbo. I expected that would be the fix the first time around, but I've noticed that my truck doesn't seem to have the power it had before. Anybody else experience this same issue? Also, what is the process in cleaning the turbo?<br />
<br />
<br />
<font color="gray">Sent from <a href="http://www.autoguide.com/mobile" target="_blank">AutoGuide.com Free App</a></font>
post #9 of 20 (permalink) Old 08-22-2013, 02:19 AM
Keep doing what you're doing and wait for the new turbo to get put on (should speed up the process). Use the EB full time when you get a new turbo.
post #10 of 20 (permalink) Old 10-15-2013, 08:57 PM Thread Starter
TheShark10's Avatar
Ok guys, so P2262 came back after getting the turbo cleaned out at the dealer. I understand that they possibly may change the turbo out the second time it's brought in, but my problem now is I got 3 new codes!! P0204, P0205, and P0206!! I looked them up and correct me if I'm wrong, but it looks to be "Injector circuit open" on all codes. What exactly does this mean? What repair am I looking at? This is aggravating cause it seems I've had nothing but problems after installing my Edge Juice with Attitude unit. Is it because everything else is stock on my truck? No deletes? Frustrated now lol.
post #11 of 20 (permalink) Old 10-15-2013, 10:17 PM
firstwest's Avatar
sounds like they either forgot to connect something under the hood, or a connector has a bad connection
Did they also clean the T-map sensor (on the airhorn, 2 torx bolts)
Retired - 2007 6.7 Dually 2wd Auto - 393,000 Miles
Sold - 2008 Freightliner M2 Haul & Tow, 8.3 Cummins
Current - 2006 5.9 Dually 2wd 6spd 243,000 miles 11/23/14
firstwest is offline
post #12 of 20 (permalink) Old 10-15-2013, 11:01 PM Thread Starter
TheShark10's Avatar
I'm not sure on cleaning the T-map sensor. Is it something I can clean myself? If so, what solvent is safe for cleaning it? I'm going to check the connections on the fuel injectors to make sure there is a good connection. Hopefully that is all it is. Skeptical though since I've had the Edge unit has been in for almost a year now. But who knows.
