2012 Fuel filter change - Dodge Cummins Diesel Forum
post #1 of 86 (permalink) Old 01-13-2013, 02:43 PM Thread Starter
bigwave007's Avatar
I'm going to change the filter for the first time and wanted to know the proper procedure. Also do i need the special wrench or am i good with a 1 1/8" with a 1/2" inch drive. I bought the filter from napa on the fly and paid $58. Sound high? Thanks
12 3500 Diesel- Crew Cab-Long Bed-Midnight Blue-Black Diamond Plate WeatherGuard Box-Black Bed Rails-285/70/17 Good Year Wrangler -Leveled.
bigwave007 is offline
post #2 of 86 (permalink) Old 01-13-2013, 02:44 PM
Should have just bought one at the dealer
05 2500 4x4 Carli Dominator 3.0 Suspension Baja proven
94 2500 4x4 Carli performance 2.0 with full leafs
90 wrangler injected locked and caged crawler
bob4x4 is offline
post #3 of 86 (permalink) Old 01-13-2013, 02:58 PM
I used a 28mm, 1 1/8 might be a tiny bit big but should work if you're carefull not to round off the plastic. Pretty easy, don't forget to cycle the ignition without starting a few times.to prime it.
2012 RAM 3500 Laramie 4x4 G56 3.73 SB3250 Carli Pintop/Sway bar/Track bar/Full leafs 295/70/18s on Hostages, 35w Retroshop HID Projectors and fogs, a bunch of other stuff, oh and some other stuff fell off.
Ram2012 is online now
post #4 of 86 (permalink) Old 01-13-2013, 03:31 PM Thread Starter
bigwave007's Avatar
Do I need to drain the housing first or just loosen top and replace?
post #5 of 86 (permalink) Old 01-13-2013, 03:36 PM
Go Packers
camperman's Avatar
I order from truckhelp.com for oil & fuel filters. 1-800-407-1071. I ordered the LF16035 oil & fuel FS 43255. Oil filter was 13 & change, and fuel was 43 & change. I like this place for the reason that on orders $50.00 or more, they have free shipping. Took a week for my order to arrive. I use fleetguard filters for my truck. I see many order from genosgarage.com, but they do have shipping fees. I did price a fuel filter from my dealer, and he was way high priced, compared to truckhelp.com.
2012 SLT 3500, CCLB, HO, SRW 4x2, 4.10s, Mineral Grey, Pacbrake air bags, Fumoto oil valve, Cat/Cummins Dual Filter kit, Edge CTS Monitor.
camperman is online now
The Following 2 Users Say Thank You to camperman For This Useful Post:
Hawg Up (01-19-2013), NorCaler (01-14-2013)
post #6 of 86 (permalink) Old 01-13-2013, 03:46 PM Thread Starter
bigwave007's Avatar
Napa say's wix makes their filters so I tried it. What procedure did you use changing it?
post #7 of 86 (permalink) Old 01-13-2013, 04:00 PM
Go Packers
camperman's Avatar
At just a little over 5300 miles, I am still on the factory filter. From what I have read on here, first drain the water fuel seperator, then with drain still open loosen the filter cap, but do not remove just yet. That will allow for more to drain out. Make sure that you lubricate the new O-Ring with new motor oil. From reading other postings, make sure to not overtighten the fiter cap. Torque it to 22.5 ft. lbs. per owners manual. Sounds like you are on the ball changing your filter. Proper maintenence is the key for avoiding problems, and with any diesel truck, it gets pricey quick.
The Following User Says Thank You to camperman For This Useful Post:
bigwave007 (01-13-2013)
post #8 of 86 (permalink) Old 01-13-2013, 06:08 PM
heipps's Avatar
Ive changed it a few times now. You need a 1 1/8" shallow socket on a 1/2" drive to be able to get it off. The first time its crazy tight. Try not to use air as its plastic so you dont round off the points. Your local cummins shop sells the filters for 48 bucks. The filter also comes with very good and detailed instructions on changeing it
2010 2500 TRX4 Crew Cab SWB 68RFE 4.10 LSD. CCV DELETE. BAFFLE MIA. XRT PRO TV:6.8.26 (TOW, NO ATT, TIMING #3). FLOPRO DPF PIPE. MAG HYTEC REAR COVER. H&S EGR/COOLER DELETE. GDP PRO WASTEGATE. BD STEERING BOX STABILIZER. CARLI SS LOW MOUNT.
heipps is offline
post #9 of 86 (permalink) Old 01-13-2013, 06:29 PM
Put an extension on the factory drain hose and drain into a container rather than on the ground. Put some shop towels around the suspension under the filter because you'll still drip from the housing when loosening the cap. Loosen the cap while leaving the filter housing drain open. Pull old filter - if it's the original it might be tight so don't be afraid to tug. I used a new lint free small microfiber towel to mop up any remaining liquid from the housing before putting in the new filter. Close drain, lube new o-ring, replace filter & cap, cycle key 3 times while listening for the pump to prime each time. First startup might take several seconds but should start - then check for any leakage.
2012 Laramie 4X4 CCSB. mineral gray over silver 2 tone, slate leather.
Germs is offline
post #10 of 86 (permalink) Old 01-13-2013, 06:56 PM
griff44's Avatar
Yup I agree I buy all my filters directly from cummins, ccv $85.00
2010 3500 LARAMIE MEGA CAB, 6 SPEED HAND SHAKER, 6" BDS LONG ARM, SB 3250, H&S MINIMAX,5" TURBO BACK, 37/13.50/18 TOYO OPEN COUNTRY M/T, BD STEERING BOX BRACE, AIR RAID CAI, ARP 425, BAKFLIP G2, AFE DIFF COVERS, BUSHWACKER POCKET FLARES,BULLET PROOF MUD FLAPS, FUMOTO OIL DRAIN VALVE.
Norcaler tune performance/4
griff44 is offline
post #11 of 86 (permalink) Old 01-13-2013, 07:20 PM
I took a dremel to the little shields around the nut so I can easily get a crescent wrench on it... Much easier to have a crescent thrown behind the seat
U know what really sucks...when I first got my 12( Dec 11), I went to napa to get some spare filters... They were $17... Same price as the old 5.9... Then all of the sudden, the price doubled... Its like they figured since the 7.5 -2010 boys were having to pay for that expensive filter...so should we....
2016 Ram 2500 Laramie Sport Pearl White.. Stock for now
Megaramasaur is offline
post #12 of 86 (permalink) Old 01-13-2013, 08:07 PM Thread Starter
bigwave007's Avatar
Ok thanks. It's factory tight, I'll put the gorilla grip on it later. Thanks for the replies.
The Following User Says Thank You to bigwave007 For This Useful Post:
welldigger (01-22-2013)
