How to replace serpentine belt. - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 12-01-2012, 05:31 PM Thread Starter
curuxa's Avatar
Gents:
I need to replace my serpentine belt for the 6.7L 2010. I cannot find any instructions in the forums on how to do it.
If anyone can give advise and indicate a procedure, that would be lots of help.
Thanks.
2010 6.7L 2WD
Almost completely stock.
Dropped useless engine and exhaust parts on bumpy road.
curuxa is offline
The Following User Says Thank You to curuxa For This Useful Post:
NorCaler (12-02-2012)
post #2 of 7 (permalink) Old 12-01-2012, 05:33 PM
Second Most Important Member
TORK-STIK's Avatar
is there a routing diagram under the hood?
2007.5 6.7L THANKS TO, DANS DIESEL PERFORMANCE-EFI LIVE-WALLY@FTE-RICH@GLACIER DIESEL POWER-RANDY ELLIS DESIGN-DON THUREN FABRICATION-POLY PERFORMANCE-S&B-H&S-BFG-GENERAL RED LETTERS-MHP-B&G-FLO PRO-AMSOIL-EDGE-RECON-GENOS GARAGE-HELL BENT STEEL-BILSTEIN
TORK-STIK is offline
post #3 of 7 (permalink) Old 12-01-2012, 06:25 PM Thread Starter
curuxa's Avatar
No, there is no serpentine belt routing sticker anywhere. I do not have the service manual for this model year.
Got the Hane's for '02-'08 so the routing must be the same, just do not know for sure. Mine is a 2010.
2010 6.7L 2WD
curuxa is offline
post #4 of 7 (permalink) Old 12-01-2012, 06:40 PM
Take a picture of it from the top and front of truck and another one from under the truck. Then find the idler pulley either use a rachet or a pry bar. I would try just using the rachet if you can.
Sent from my SPH-D700 using AutoGuide.Com Free App
1BadCTD is offline
post #5 of 7 (permalink) Old 12-02-2012, 12:27 AM
lonestarwelder's Avatar
Go to auto zone and get the $16 dayco tensioner pulley and replace that too. You're going to need a buddy and a 1/2" drive long rachet.
The routing is the exact same as the 3rd gen.
My best advise is to take the tension off the belt and slip the belt off of the alternator first.
You must install the rachet to the belt tensioner from the bottom and passenger side of the truck. The hardest part is slipping the belt through the gap to get it off/on the harmonic balancer.
The tensioner has to come off in order to get the belt off/on as well. It's a 13mm bolt head, use a 3/8" drive rachet and shallow socket, or ratcheting wrench, it's kind of tight in there.
Good luck!
2015 3500 DRW Laramie CCLB 68RFE 4.10 4x4.
Cooper LT255/70R17 ST Maxx and 2" Stahl Steel spacers. 1.5" Traxda leveling kit. Mag-Hytec rear cover with 75/110 Amsoil.
SOLD:2010 3500 DRW Big Horn CCLB Auto 4x4.
lonestarwelder is offline
The Following 3 Users Say Thank You to lonestarwelder For This Useful Post:
Cummins Keep It (04-24-2014), Mudman1 (01-21-2014), NorCaler (12-02-2012)
post #6 of 7 (permalink) Old 12-02-2012, 09:34 AM
63boxtop's Avatar
No pics needed, there is already a tread on this also under water pump replacement
2010 Deep Water Blue CCLB Dually 4x4, 68rfe 3.73
63boxtop is offline
The Following 2 Users Say Thank You to 63boxtop For This Useful Post:
post #7 of 7 (permalink) Old 12-02-2012, 10:12 AM Thread Starter
curuxa's Avatar
Thank You lonestarwelder and 63boxtop:
Your replies are very informative, nevert thought of getting a new pulley, I guess that these wear out. As to the use of a buddy, it is great advise. Saw on Youtube that this fellow used a ViseGrip to hold tension, may work or may not.
Does not seem that difficult to do, but with the schematic it makes everything easier as it is almos impossible to take a picture of the setup unless one removes the radiator for space.
Thanks. I hope that this thread will be informative to others, as I did not find one in this forum that adresses this serpentine belt maintenance process.
Regards.
2010 6.7L 2WD
curuxa is offline
